Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Light malfunction message 2020 330i xdrive
      06-13-2020, 09:56 PM   #1
cattt
Drives: Bmw 330i xdrive
2020 BMW 330i  [0.00]
Right front light malfunction message just showed up when i started the car but everything seems to be working fine so should i be worried
      06-13-2020, 11:03 PM   #2
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
3,521
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Since the lights work, did you try turning the car off and back on again? Did the error disappear?
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      06-14-2020, 12:59 AM   #3
cattt
Ya the message did go away after i turned it off and on again but i guess i bugged out because i gave it a wash with a pressure washer a few days ago and wondering if that messed something up
      06-14-2020, 01:57 AM   #4
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
3,521
That ideally shouldn’t cause problems. I’ve pressure washed mine many times and never had any issues. Did you clean the engine bay too?
Current:
      06-14-2020, 02:37 AM   #5
cattt
Nope i didn’t clean the engine bay i just did a quick exterior wash for the first time honestly. I didn’t expect the washer to cause any problems either since it supposedly puts out around 1500 psi, unless would that be a bit too much for a car?
      06-14-2020, 10:34 AM   #6
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
3,521
It could be the pressure washer but I think there’s an increased probability that it was just a random error that hopefully won’t pop up again. If you have an obd scanner, scan and see if error codes are present?
Current:
      06-15-2020, 12:02 AM   #7
cattt
I hope its not the pressure washer, what psi is your washer running at? I wish I had a scanner but that’s probably true it may have just been error message because it hasn’t popped up ever since
      06-15-2020, 12:08 AM   #8
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
3,521
Karcher pushing around 2000 PSI. Zero issues so far.
Current:
      06-15-2020, 03:09 PM   #9
cattt
Oh gotcha I heard good things about the karchers. I really appreciate all the help thank you!
VipinLJ1941.50
      06-15-2020, 03:10 PM   #10
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
3,521
You’re welcome! Let us know if this issue pops up again.
Current:
cattt1.50
g20
