BMW 5-Series (G30) Forum Cosmetic Modifications M5 "Style" Rear Diffuser on M550
      04-23-2020, 08:30 AM   #1
Titan2004
28
79
Drives: M550i/M50i/488/Maybach/RR
Slapped this on yesterday. I like it better than OEM gray diffuser (that I'm having wrapped today in gloss black as a back - up)
      04-23-2020, 08:46 AM   #2
Rotherd31
User Name
Rotherd31's Avatar
1178
844
Drives: 2023 G83 BG/FR/ 963M wheels
Titan: Can we have some more pics from straight on, etc? Also a link for it, cost, finish and fitment, etc. And maybe some detail on removing the OE lower cover piece. There's been some limited discussion on the removal, but a more detailed description would be beneficial. Maybe a pic of the backside of the OE one showing the clips or tabs, which would show what direction one applies pressure to remove it. Like you, I don't care for the dark gray either and I am in the process of converting all the cerium to gloss black. The only items left are this lower rear trim piece and my wheels. Thanks much!
      04-23-2020, 09:46 AM   #3
Titan2004
28
79
The new diffuser requires cutting and sanding of outside edges by exhaust tips in order to clear M550 tips. If you've got some skills and patience with a dremel and are detailed, it will turn out fine. If you don't, do not purchase this diffuser as it will not clear M550 tips. I had to install and yank off 5 times and in the process broke one clip. I'll have another diffuser in about a week and will show where and how it needs to be cut (more will be cut on next diffuser for additional tip clearance). For $189 I was pleased with how well it fits (I knew it wouldn't clear tips) and the next one should not take me more than an hour now that I know what I'm doing
eBay: $189 Rear Diffuser For BMW 5 Series 17-19 M Sport Bumper G30 Glossy Black M5 Style
My original diffuser is getting wrapped today so once I get it back I'll post pics of the backside clips and suggestions for removing
      04-23-2020, 12:19 PM   #4
Rotherd31
User Name
Rotherd31's Avatar
1178
844
Titan: Thanks so much for your reply and additional information. It was very helpful and I look forward to further information/modifications and photos of both pieces.
      04-24-2020, 03:22 AM   #5
Zito
20
Drives: BMW M550i
That looks really good, well done! ����
      04-26-2020, 09:10 AM   #6
Titan2004
28
79
Here are some backside pics of M550 OEM rear diffuser.
First, remove screws from bottom edge of diffuser using socket #8. Very easy to do and don't forget the ones on the farthest, bottom edges.
Next, start on the drivers side and pull diffuser straight out with a quick tug. You can reach your hands underneath and/or inside exhaust cut out for best grips. There are 2 clips on the vertical edges. Start with bottom and work up to second clip. Quick, sudden pulls work best.
Once the first side of diffuser is loose you can use a push - pull method and work your way across the top applying slight pressure to the bumper with one hand as you give a quick tug at each diffuser clip with the other. Pulling on diffuser at a point away from a clip and without applying some pressure on the bumper increases chances of clips breaking.
Once all top clips are removed, the passenger side vertical clips along the edge should be easy to remove.
As you remove the diffuser, try to keep it straight and level until fully removed. This will reduce the chances of clips breaking.
I had mine wrapped so that is the black vinyl you see in the pics around the edges.
Rotherd311177.50
maDjzo861.50
      04-26-2020, 09:49 AM   #7
Rotherd31
User Name
Rotherd31's Avatar
1178
844
Thanks much for the description and pics Titan! Now I have a much better idea on the removal process. Sure nice to know that the upper portion of the bumper cover doesn't need to be removed to get at the lower section.
If you end up putting your OE wrapped back on your car for a look, I'd love to see a pic of that.
      04-26-2020, 10:19 AM   #8
Titan2004
28
79
Sure thing and good luck with the removal if you decide to do so. It's very simple actually. I probably got long-winded with my explanation but I had some time
      04-27-2020, 12:54 PM   #9
Rotherd31
User Name
Rotherd31's Avatar
1178
844
Not at all long winded IMO. It needed to be such to accurately describe how to remove it! Thanks again! Now when my body shop opens up again, paint will come next.
      05-12-2020, 06:16 AM   #10
VK_Technician
32
Drives: 18 BMW M550IX
OP did you get a chance to fit the new M5 diffuser yet
      05-12-2020, 09:18 AM   #11
Titan2004
28
79
I did. Trimming and sanding still took a couple of hours on this second diffuser. The fitment is better and all clips intact
      05-13-2020, 01:04 PM   #12
Zito
20
Drives: BMW M550i
It looks fantastic! Where did you get the diffuser as I want to order as well.
      05-14-2020, 11:03 AM   #13
Titan2004
28
79
Thank you!
It does take some significant cutting and sanding so 550 tips fit
      05-14-2020, 05:30 PM   #14
VK_Technician
32
Looks great! So you're saying the outer portions of the diffuser were touching the tips?
      05-14-2020, 06:37 PM   #15
VK_Technician
32
I just realized that you have the exact look I'm going for! Cerium silver trim replaced with black and 728m wheels! Where did you order the wheels if you don't mind me asking.
      05-15-2020, 07:19 AM   #16
Titan2004
28
79
Thanks, exactly! Needs to be carefully trimmed
      05-15-2020, 07:25 AM   #17
Titan2004
28
79
Found them on eBay. New takeoffs with 30 miles on them. The wheels led me to replace all cerium with gloss black. Then I didn't like the white in the BMW emblems so for now I have black overlays until I decide what to do for those
      05-15-2020, 09:17 AM   #18
VK_Technician
32
Nice! Yeah I'm in search of black trim as we speak, I'm not a fan of the silver.
5post
