03-08-2020, 11:36 PM | #1 |
28
Rep 92
Share Your Bootmod3 Custom Burble Settings
I am curious to hear what custom burble settings everyone is running with their Bootmod3 tune.
Be sure to mention your down pipe + exhaust set up and which Bootmod3 map you’re running. Here are my current burble settings below. Stock down pipe, Dinan Resonator Delete, Dinan Exhaust. Stage 1 93 octane map.
2024 BMW X3M Comp ~ Individual Gentian Blue
06-22-2020, 04:42 PM | #2 |
Rep 5
Drives: 2014 BMW M235i
Wish more people had replied to this! I'm flashing bm3 for the first time tonight and will let you know what settings I end up sticking with. Are these the settings you still run today? I kind of want a more natural sounding backfire so I was thinking high aggression and low duration would achieve something like that.
06-22-2020, 05:24 PM | #3 | |
28
Rep 92
FYI. Pro Tuning Freaks does not recommend running the burble aggression setting higher than 5.6 with the stock downpipe to avoid damaging the catalytic converter.
09-25-2020, 12:48 AM | #5 | |
28
Rep 92
https://youtu.be/yEutWAQZDF8 https://youtu.be/2e5MHHANfAw
09-25-2020, 10:30 PM | #6 | |||
17
Rep 72
Sounds like a Beast! What Exhaust are you runnin? I currently have MPE. |
09-25-2020, 10:32 PM | #7 |
17
Rep 72
01-13-2021, 04:36 PM | #11 |
117
Rep 243
Very important to mention downpipe + exhaust configurations... Someone with catless dp + straightpipe exhaust will get significantly more pronounced burbles/pops off a lower aggression setting vs someone that has OEM cats+muffler.
'15 235i - Moddedededed
01-14-2021, 11:06 AM | #12 |
5585
Rep 5,386
Be very careful with those burble tunes on cars with cats. There is much evidence that shows that the aftermarket burble tunes set to more aggressive burbles will melt the cat over time.
MLJR235116.50 |
05-15-2021, 10:15 PM | #14 |
New BMW owner
326
Rep 845
OTS map Stage 1 93 octane. Sport +. Canyon runs. I'm finding the burbles seem to last myb 3-4s. Is this the default of the OTS? It's a lot longer than factory (OEM). I don't like all that burbles, seems like the car is broken. A little goes a long way IMHO.
When I look at the setting it just says 1.5s though. In addition, why is the setting only for Sport, there's none indicated for Sport +.
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
