01-21-2020, 01:10 AM | #1 |
67
Rep 141
B&W settings
Hello, anyone have good B&W overall settings for 8er? (Mode/eq) I personally try to set it for hiphop/electric and with regular settings of high and bass it seems to lack of some fat in sound. I personally try studio/bass 8/treb 5-6 and little more in eq to bass freqs, but still lack of fat in sound, in low volume sound even more poor
01-21-2020, 02:23 PM | #2 |
641
Rep 628
Drives: 2019 BMW m850i Coupe
Skh I had a set of issues going on which impacted my B&W see my post
https://f92.bimmerpost.com/forums/sh....php?t=1671087 |
Al Pină1839.50 |
01-21-2020, 05:40 PM | #3 | |
1840
Rep 1,487
The B&W in my 750 thumps like crazy and has commendable low frequency response, down to at least 50hz for sure. There's no reason yours shouldn't sound at least as good, as your smaller cabin would be easier to fill with rich bass.
Blessed Beyond Measure
Ozzie8641.00 Slayerkillhate66.50 |
01-22-2020, 10:20 AM | #4 | |
1599
Rep 2,935
01-22-2020, 07:48 PM | #5 | |
4260
Rep 4,327
01-22-2020, 09:34 PM | #6 | |
4260
Rep 4,327
I have my B&W system dialed in for the mostly classic/hard rock and jazz of my FLAC source (1TB USBC SSD drive in the console). However, when I streamed Tones and I "Dance Monkey" via Amazon Music Plus Ultra HD (decent source) the low-end was impressive with the all midrange configuration. Core Hip Hop on the other hand is centered around a low bass response that midrange drivers will struggle to emulate as their focus is tight bass and the midrange of the audio spectrum. I've owned several B&W home audio speakers in the past and large drivers (aka subwoofers) are not their play whatsoever. Considering the lack of detail as to truly what goes into a B&W system within the 8 series I am going to draw a few parallels in my theory. 1st given the Diamond tweeter branding it has some components from the 800 series. Also, given the newtis.info documentation I will assume it is an 8x2 (midrange plus tweeter) for a total count of 16 speakers which matches the published specs. For the midrange drivers this is likely the Continuum bass/midrange included in their bookshelf 805 D3s and their 603's. Sizing is a guess but I'll assume 6.5 or 6" given the 805 or 603 configuration. If it is a true to form equivalent of the 805 D3s (aka Diamond branding) this means a low-end of 34Hz which would track to my experience to date. Not earth shattering lows but tight performance and gets the job done. I have yet to pursue the software update and audio fix Ozzie8 (and Resjudicata) have done but will do so at my first scheduled maintenance. I'll once again assume that it effects the 3 crossovers driving the frequency dispersion across the midrange drivers and tweeters as a software update alone cannot enable lower end frequency response of the midrange drivers whatsoever as that is driven by the laws of physics. Last edited by bloozemanAZ; 01-23-2020 at 08:48 PM.. |
01-22-2020, 11:26 PM | #7 |
641
Rep 628
bloozemanAZ can you send photo of your equaliser settings - would appreciate. thanks for the interesting detail on the B&W did not appreciate the engineering and the material provided with the car is somewhat lacking. the interference in my car I believe was driven by the car engine active sound system, it was knocking out all sorts of reproduction from the B&W and it is my guess the software correction was to reset active sound.
01-23-2020, 09:06 PM | #8 | |
4260
Rep 4,327
This would in theory track to the 3 published crossovers in the BMW specs as one of the crossovers would drive all the lower-end frequencies to the center console and rear drivers. I can hear the bass in my driver seat coming from the front and hence the search that ended with the newtis.info and discovery on all midrange drivers in the car. |
Ozzie8641.00 |
01-24-2020, 06:25 PM | #9 |
641
Rep 628
That was an interesting observation and I can now get appreciate and feel the sub/bass coming from the front. That's helped me with some of the adjustments too, as I have been trying to get more sub kick but always feeling there was something I was missing as I could not feel it under the seats or behind. Dropping the middle settings on the equaliser as helped me get a better sub/base boost from the front. So thanks for the insight.
01-24-2020, 07:38 PM | #10 |
4260
Rep 4,327
Forgot to take the pics this morning as was running late so just shot them in the garage. One thing I forgot to mention earlier is I found the best overall sound profile (aka surround logic) to be Concert. Being a 2-channel audio guy I had originally utilized Studio.
In fact one of my only issues with the B&W is you cannot disengage the surround logic. In my wife's 2017 X5 with upgraded H&K (the stock system was miserable and I was not able to test out the B&O option prior to ordering) disengaging the surround logic provides the best sound possible. Not sure I would have invested the $4K for the B&O given it is her daily driver and I'm not in the driver seat very often but the $900 for the H&K is golden when I am. Side note of one nice thing I'm appreciating with the M850i is that no matter what volume I have when I park the car at startup it is set to a lower reasonable setting. Guessing this is an iDrive 7 vs 6 feature as in my wife's X5 if we are going somewhere in it together I always drive and with my key recognized it fires up my last settings and volume of audio which blasts us both until I can turn it down. Thankfully she has gotten used to the experience. That said this brings up another point already mentioned, i.e., with all midrange in the M850i the bass does not open up until you are at least 50% of max volume. Given that I'm the only person in the car this is not an issue and during the commute I'm there or higher as the sound is amazing. All depends on what I'm listening to but regardless it always puts a smile on my face and what better way to start off the day. Lastly on the way home today I was listening to Ozzy's Boneyard on SiriusXM which is generally pretty good audio wise. Just thought it was apropos as I took the pics for Ozzie8 and you can see the station in them. Last edited by bloozemanAZ; 01-24-2020 at 07:51 PM.. |
01-24-2020, 08:16 PM | #11 |
641
Rep 628
thanks man
01-24-2020, 09:04 PM | #12 |
641
Rep 628
These are my settings - for those that like plenty of sub/bass - it works for me.
01-24-2020, 11:59 PM | #13 |
4260
Rep 4,327
That equalizer setting will definitely drive more bass but you're missing out of some of the midrange magic included in the source material. Caveat being I'm an audiophile snob (yes I admitted it ) being a professional musician in my past life.
01-25-2020, 03:09 AM | #14 |
641
Rep 628
I have the musical talents of a three toed sloth. Will tweak things your way.
02-01-2020, 07:29 PM | #15 |
4260
Rep 4,327
On the drive home Friday with Phil Collins' "I Don't Care Anymore" sourced from FLAC and the amazing low-end drum coming from the front console I realized there is more speakers in it than originally thought. I looked around the car and visible are: 2x2 center console (behind iDrive screen), 2x2 in the front doors, 2x2 in rear seats and 2x2 on the rear deck behind the seats. Add the visual up and that is 14 speakers. So where are the 2 missing speakers? I can only assume they are 6" if not 6.5" drivers in the front console but not visible. Granted at 6'6" I cannot even fit in the lack of rear seats to hear the sound spectrum from there but from the driver seat there is more bass at that source from my POV than the single 2x2 visible console speaker can deliver.
02-01-2020, 08:52 PM | #16 |
641
Rep 628
From B&W - picture of 8 series coupe speaker layout
02-02-2020, 10:03 AM | #17 | |
109
Rep 150
2020 BMW M850 Gran Coupe
2019 LR Discovery HSE 2009 BMW 650i Cabrio 1999 Mercedes SL500 1980 Mercedes 450SL |
Resjudicata1599.00 |
02-02-2020, 06:09 PM | #18 |
4260
Rep 4,327
Yes, Ozzie8's diagram clearly indicates that. B&W did a great job with the crossovers in the car as when sitting in the drivers seat the bass truly sounds to be coming from the front console and there is no low-end rumbling coming from under the seats.
Resjudicata1599.00 Van_bimmer108.50 |
02-02-2020, 09:02 PM | #19 |
641
Rep 628
I agree - very surprised there was anything under the front seats.
02-03-2020, 03:58 PM | #20 |
109
Rep 150
I ordered the B&W on my m850 GC, really looking forward to trying your's and Ozzie suggestions when my car arrives! its gonna be along wait.
02-03-2020, 06:17 PM | #21 | |
123
Rep 97
02-03-2020, 07:31 PM | #22 |
4260
Rep 4,327
