11-04-2019, 12:35 PM | #1 |
Rep 74
Drives: BMW 330i G20 2019 Sportline
Central Gateway G20
am experinecing an intermitent fault code at ZGW ( central gateway). I erase these code but after certain time it reappear again. Error code is supposed to be a faulty conector. When I perform ISTA plan measures, it says there is no fault present. There are no other symptoms in the car.
What happen if reset this control module? Can it help? Thanks |
11-04-2019, 03:15 PM | #2 |
117
Rep 219
Drives: '19 G20 330i & '19 G01 X3
I can't tell you for 100% certainly, but I believe that is one of those faults that occurs. There isn't anything you can do about it. It just happens.
11-05-2019, 05:21 AM | #3 |
Rep 74
11-05-2019, 01:48 PM | #4 |
117
Rep 219
I know in my G01 the ZGW will throw that error, you can clear it, and it will come back occasionally. I don't believe it is anything to worry about. Hopefully someone else can shed some light on what this is.
