05-21-2019, 06:19 PM | #1 |
689
Rep 6,854
▀▄▀▄ Vivid Racing | Eventuri Black Carbon Intake System BMW M5 F90 17-19
Vivid Racing Presents: Eventuri Black Carbon Intake System BMW M5 F90 17-19 Contact Me Directly for Exclusive Pricing! Jacob@vividracing.com | +1.480.966.3040 x254 | www.vividracing.com[/b] Product Information: SPECIAL PRICING FOR A LIMITED TIME The F90 M5 Eventuri intake system was developed through extensive real world testing and airflow simulation analysis. It demonstrates the perfect balance between allowing for unrestricted airflow with our semi-open filter housings whilst maintaining low IATs through cold air saturation with our scoop and shield combination. Our large front air scoops transfer ambient air directly into the intake area thus ensuring the engine doesn�t suffer from heat soak. In addition, our gold heat-reflective lined shields have integrated flow guides which direct the ambient air from the scoops into the filters. We have also managed to increase the inlet tube cross-sectional area by over 30% compared to the stock intake as it feeds through the openings in the strut braces. This allows the turbos to work more with less restriction and reduce the waste-gate duty cycles. Features: - 2 x Carbon Fiber Venturi Housings with Integrated Tubes - 2 x Bespoke High Flow Generation 2 Filters - 2 x Aluminium Inlet Cowls - 2 x Carbon Fiber Air Scoops - 2 x Laser Cut Heat Shields lined with Gold Heat Reflective Material - 2 x Laser Cut Air Ramps integrated into the Heat Shields - High Quality Silicon Couplers and OEM Spec Hose Clam |
