02-17-2019, 03:49 PM | #1 |
133
Rep 229
Coolant level
Owner's manual describes some kind of min/max coolant level gauge, which does not appear to exist. Does anyone know how to check the coolant level?
02-18-2019, 02:38 PM | #2 |
208
Rep 602
Well there is no gauge per se, or dip stick float device, but simply mix up in a clean container with nice tight seal, [I used a portable hiking water bottle] 50/50 of BMW rad fluid, and distilled water. When you use it, you can seal remaing mix and it's ready if needed next time.
Then shine a light thru passenger side of the white rad water container, light pointing to center of motor. You can then see how water level is indicated inside at seam. Hi tech, nice that. BUT just make sure your rad water level is up the seam, in middle of white container, and its fine. |
02-22-2019, 05:19 PM | #3 |
2352
Rep 2,829
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
You can't find that but the system will tell you if your low....just added some coolant 2 months ago.
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
02-22-2019, 06:33 PM | #4 |
133
Rep 229
My dealer mechanic said it should be up the crease on the side. They topped it off for me.
17 m2: CSF Turbo FMIC, Fabspeed DP, BM3 Stage 2, VRSF Charge Pipe, Schroth quick fit, Vorshlag CC plates, Apex 18x10, BMS Clutch Stop.
