05-11-2018, 01:35 PM | #1 |
12
Rep 4
2018 M550 Engine Replacement
Hey all,
Long time lurker of the forum, always appreciate the info. Finally have something post worthy and its unfortunately bad news. Looking for some general guidance here. Brought my 550 into the dealership this morning due to some uncomfortable clicking/tapping noises coming from the engine bay most audibly at cold start and a drivetrain malfunction error that was happening just about every time I got on the highway in the past week. I'm 6-7 months into the lease and am barely past 1600 babied miles without a single attempt at even trying launch control yet and was just told that the issue was serious enough that the engine needs to be replaced in its entirety. They stated they'd be calling back hopefully by end of day regarding replacement engine availability and the results of the final tests, but assuming the engine does in fact need replacing, has anyone been through a similar situation? Is there any chance at the car being replaced instead or am I just looking at a long repair? Also assuming the shipping and repair would take weeks, do I have any standing to at the very least request something a little nicer than the standard loaner? Appreciate any and all feedback. Would love to just be better informed/prepared for when they do call back. Thanks, Tim |
05-11-2018, 03:15 PM | #2 |
3086
Rep 4,210
As long as they give you a new engine, and not a reconditioned or used one, it should be fine. I would in fact praise the company for being willing to replace such an expensive engine.
It shouldn't take that long to replace an engine unless the delivery is delayed. As for loaners, that is primarily a dealership issue. Considering what an expensive car you have, I would certainly ask for a somewhat equivalent loaner (I doubt you will bet a 550 but you should be able to get a 530i as a loaner). If your dealership won't give you a decent loaner, speak to the service manager or the general manager. |
05-11-2018, 10:41 PM | #3 | |
156
Rep 386
2018 750I XDrive. Loaded with Every Package.
Black on Black. |
05-12-2018, 03:17 AM | #4 |
Live for today tomorrow never comes
1990
Rep 9,499
It will be the Valvetronic motor this has happened a lot on the E80 M3.
No engine replacement required if so.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
05-12-2018, 07:25 AM | #5 |
12
Rep 4
Thanks for the feedback guys. I'm still waiting to hear back from the dealership for final confirmation and will definitely look to get something nicer and a better estimate on how long they think it will be there for service.
As for the noise, this is what it sounded like on mine, unlike the video posted mine only happens when the engine is on though, and does increase with rev. |
05-12-2018, 07:39 AM | #6 | |
1990
Rep 9,499
05-12-2018, 02:07 PM | #7 |
19
Rep 29
Is this a problem on M550i ?
Heard from another owner of an M550i that he had the same problem. The dealer say that it was problem with cylinder 7. And the factory had order replacement of 69 new engines...
Anyone knowing more about this ? Could this be another reason why they have stoppet the delivery of M550i in europe ? |
05-12-2018, 03:32 PM | #8 | |
376
Rep 1,223
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
05-12-2018, 05:29 PM | #9 | |
6659
Rep 15,858
I've heard this sound before. Part way through the video as the revs increase, we hear a sort of 'off beat' change. My E39 M62 V8 engine had to be replaced as it developed a very similar sound track. Was damage to one cylinder, both piston and bore had scored, causing piston slap. Mine got worse (louder) as the engine warmed. We first thought it was a HVA, but the odd 'off beat' gave doubts and it sounded a bit lower in the engine. BMW's UK engine guy couldn't really identify the true cause, in my engine. But the signs were the cylinder had been running hot, (discoloration, different to the other cylinders in the bank) and the inlet valves were getting loose in the guides, (only in the bad cylinder). Whether it was a breakdown in lubrication due to the heat, or carbon dropped into the cylinder, we couldn't determine. Needed a new engine as both block and one head were damaged. Will be interesting to see exactly what the problem is. |
05-13-2018, 01:14 AM | #10 |
Quadrex
1094
Rep 1,424
Drives: W212 Mercedes=Benz E Class
Wait, this car in the video sounds like a Lombardini boat motor or either way they mistakenly put it in there
Sorry ,hope you get this sorted out
05-18-2018, 07:07 PM | #11 |
12
Rep 4
Hey guys,
Just wanted to update the thread to say the problem has been resolved and the engine replaced. Have to give some props to the service guys at BMW Peabody, as they had this diagnosed and the engine replaced in just under a week! Happy to have it back for the weekend! Here's the diagnosis for those that were interested: SES: C/ S SERVICE ENGINE SOON LIGHT ON C/ S C/ S DRIVE TRAIN MALFUNCTION KEEPS COMING ON FOUND SERVICE ENGINE SOON LIGHT CURRENTLY ILLUMINATED CONNECTED BATTERY CHARGER AND RAN VEHICLE TEST. FOUND FAULT CODE 168201 KNOCK SENSOR 3 SIGNAL T00 HIGH. RAN TEST PLAN FOR KNOCK SENSOR. RAN CHECKS FOR KNOCK SENSOR, FOUND NO ELECTRICAL FAULTS IN KNOCK SENSOR SYSTEM. TEST PLAN RECOMMENDED TO CHECK FOR ENGINE MECHANICAL DAMAGE. LOUD KNOCKING NOISE PRESENT FROM LOWER END OF ENGINE. CHECKED ENGINE OIL LEVEL, FOUND TO BE AT MAX ON BOTH IDRIVE AND DIPSTICK. DRAINED OIL TO VERIFY LEVEL, FOUND 9.5 QUARTS IN ENGINE. FOUND OIL TO BE SHINY/METALLIC IN APPEARANCE. PERFORMED COMPRESSION TEST. FOUND CYLINDERS 1-4 AT 215-220PS1. CYLINDER 5 AT 170 PSI AND CYLINDER 6 AT 210 PSI. CYLINDERS 7 AND 8 AT 220 PSI. CYLINDER 5 HAS NOTICEABLY LOWER COMPRESSION THAN OTHER CYLINDERS, PERFORMED LEAKDOWN TEST. FOUND CYLINDERS TO HAVE 4-5% LEAK DOWN EXCEPT CYLINDER 5 WHICH HAS 15% LEAKDOWN. USING BORESCOPE INSPECTED CYLINDERS WALLS OF CYLINDER 5, FOUND MAJOR SCORING PRESENT. |
05-19-2018, 01:13 AM | #12 |
1990
Rep 9,499
Glad you got a nice new Engine, lets hope all goes well for you now, enjoy.
05-19-2018, 02:56 AM | #13 | |
6659
Rep 15,858
Not surprised at the source of the problem, sound track was like my engine as I posted above, that odd 'off-beat' rattle. |
05-23-2018, 05:59 PM | #14 |
1708
Rep 2,539
That engine sounded terrible. Glad it got taken care of. I would expect no less from BMW when faced with such glaring manufacturing defect..
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness.... |
07-27-2018, 06:29 PM | #15 | |
1990
Rep 9,499
07-28-2018, 07:40 AM | #16 |
1708
Rep 2,539
Lawyer up perhaps?
07-28-2018, 11:37 AM | #17 |
583
Rep 573
Drives: 2018 G30 540i
When reading posts lile these, I am very glad I decided to lease the 540i.
Will be my first lease, and definitely not the last. Modern cars have become so high tech, that the chance of a failure has become very real. Now, with the lease, after 3 years I give it back and don't have to worry about motor plan comments. Last edited by mk1-fan; 07-28-2018 at 11:38 AM.. Reason: Grammar |
07-28-2018, 01:16 PM | #18 | |
1708
Rep 2,539
Subject for a different thread... OP: Consider also asking for additional warranty coverage for the huge inconvenience. Seems to me, BMW is honoring the warranty. Speak to an attorney just in case...
High Flier102.50 |
07-28-2018, 07:56 PM | #20 | |
103
Rep 231
Ask for a history of the new engine...miles, problems, etc. And like 530i driver said, tell them you want additional coverage for the trouble. I don't think you will have any problems with the replacement. |
07-29-2018, 04:01 AM | #21 |
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
512
Rep 1,280
Would it possible for him to ask BMW to return some cash due to obvious fall in value of the car or turn the contract to a PCP so that the car has a guaranteed future value the car would be returned at a certain mileage. Otherwise I do not see how OP is not going to sell the car for a substantial loss in the future.
I am almost sure, insurance companies in the UK usually replace a new car with substantial damage with a new one So logically speaking without the above contacts an extended warranty would only cover the OP for future failure in functioning of the car but not the certain immediate fall in value of the car.
Acceleration is heavenly
07-29-2018, 12:10 PM | #22 | |
1708
Rep 2,539
The extended warranty is money in the OP's pocket. It is a free insurance policy in case that replacement engine fails 50K-80K miles down the road. If he doesn't ever uses it and he sells the car (Assuming the extended warranty is still active) it will add value and a vote of confidence for the next buyer of the car. Again, I believe the OP should explore further legal options at his disposal. But it seems to me asking for an extended warranty from BMW (Which are very good from first hand experience) will go a long way in restoring his confidence in the car. That extended warranty will pay itself many times over even with just a couple of visits. Here in the US you pay a small deductible per visit, usually $50, and BMW pick ups the rest of the tab. I have had repairs worth $5000 at the dealership and my total cash outlay for that repair visit was only $50 Asking BMWUSA to do anything above replacing the engine 100% under warranty is an act of goodwill. Be polite but firm and ask them not only to make good on the warranty (Which they are contractually obligated to abide to by law) but also to restore confidence/faith in the product via goodwill. Best of luck to the OP.
