M2 Technical Topics > Track / Autocross / Dragstrip > Tracking With OEM Wheels
      04-01-2018, 11:38 PM   #1
look585
look585's Avatar
312
478
Drives: M2CS
2020 BMW M2 CS  [10.00]
Curious of any of you guys tracking with your oem wheels?
      04-02-2018, 12:51 AM   #2
nd2002
nd2002's Avatar
179
295
Drives: 2017 M2
Yup
      04-02-2018, 01:13 AM   #3
MR_M2
519
444
Drives: 2017 M2 6MT, 2022 X7 M50i
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Yes, don't forget to take off the bmw roundels.
      04-02-2018, 09:12 AM   #4
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
381
731
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
Plan on using my stock rims, with stock tires (Continentals) for the first track day of the year at Palmer. But will probably switch to a Dedicated set at the end of the season. Just want to burn off the Continentals to replace with Michelins.
CrashFL137.50
      04-02-2018, 09:13 AM   #5
greasypeanut
230
254
Drives: F87
I tracked my oem wheels with no issues. Switched to dedicated 18“ track wheels in December though
      04-02-2018, 09:24 AM   #6
look585
look585's Avatar
312
478
Drives: M2CS
I was going to get 18 also. I have some other wheels coming for the road.
Thinking just take the oems and fit them with some Cup 2 tires. The difference between 18 and 19 can't be that drastic, can it?
      04-02-2018, 10:23 AM   #7
dvas
dvas's Avatar
518
582
Drives: 2017 M2 - Mineral Gray, 6spd
Did a full season (10+ days) last year on OEM wheels with SC2s in stock sizes. No issues other than really poor front tire wear. I've since moved to a dedicated track wheel setup on Apex 18x10s fitted with some NT01s 275 all around.
M2C_PLUS1774.00
      04-02-2018, 03:57 PM   #8
M2guru
384
573
Drives: 2018 M2
2018 BMW M2  [10.00]
Due to melting I assume?
      04-02-2018, 05:41 PM   #9
look585
look585's Avatar
312
478
Drives: M2CS
Are you running camber plates?
      04-02-2018, 05:42 PM   #10
dvas
dvas's Avatar
518
582
Yes, 2.7 neg camber up front, could use some more for the SC2s. Also lowered a little with Bilstein PSS10.
      04-02-2018, 05:51 PM   #11
look585
look585's Avatar
312
478
Drives: M2CS
Wow! That much camber up front and still eating up the fronts?
      04-02-2018, 09:40 PM   #12
dvas
dvas's Avatar
518
582
Yeah, that was my experience. Corded first set of SC2 fronts within the first three days on track with the M2 with stock camber/suspension. With camber/suspension I was able to get more days out of them but they still corded on the outer edges with plenty of meat in the middle and inner edges after 7 or so days (some days were rain days).
Depending on your pace, driving style and tracks you frequent, your experience may be better or worse.
Having said that, the car handled very neutral and had good grip in the dry. The wet not so much, easy to hydroplane over any standing water. PSS are much better through standing water IMO.
      04-02-2018, 10:45 PM   #13
Twt
Twt's Avatar
634
650
Drives: 2017 M2
All of this depends on how much effort and money you want to spend on going faster. I have over 30 track days running the car from stock at the beginning it's current set up with MP coilovers, camber plates, 18 square, and slicks. The GC camber plates set at -3.2 really help with turn in and tire wear. The 18 square set up gives me many tire options at all price points ,with the ability to rotate.
M2guru383.50
      04-02-2018, 11:37 PM   #14
MR_M2
519
444
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Heat + cornering forces. Roundels are plastic caps.
M2guru383.50
      04-12-2018, 09:31 AM   #15
pal
pal's Avatar
433
753
Drives: Z4 M Coupe
Do you drive the car daily and to/from tracks with -3.2° of camber? No inner wear from this?
What size and offset of wheels are you running? I am assuming tires are 275/35/18 which is fairly common and provides many choices.
Thanks.
      04-13-2018, 07:54 AM   #16
Twt
Twt's Avatar
634
650
Drives: 2017 M2
Thanks.
The car is not my DD but I do drive it on the street a lot which includes trips to various tracks. ...so I leave the alignment alone. I run the Tire Rack 18/9.5 square set up when not on OE wheels. I actually prefer the 265/35/18 square set up...less spacer...no rubbing and good tire options.
CrashFL137.50
      07-24-2018, 10:09 AM   #17
chief1richard
381
731
2018 M2  [0.00]
Any issues with noise or vibrations with the Ground Control Camber plates? I have read in this forum 2.75 is max negative camber you can get with GC Plates. I"m considering the same 18" square set-up, but with stock suspension. Would there be any issues with 265 tires rubbing in front?
      07-25-2018, 12:51 PM   #18
dcmac
dcmac's Avatar
442
468
Drives: '18 LCI M2
Yep I'm tracking with OEM wheels and PSS tires. Outside of them wearing pretty quick!
No plans to have a dedicated track set but I will be switching to RE71s next summer w/ coilover and camber plates.. and winter tires for the offseason. Both on stock rims.
m2
