03-29-2018, 12:29 PM | #1 |
BMW obsessed
9601
Rep 10,891
IND | F90 M5 Painted Hood Roundel | Installation Procedure
Step 1: Apply a solid ring of painters tape around the hood roundel to create a barrier between the paint and factory unit. Step 2: Use the supplied piece of fishing line to work your way around the circumference of the roundel. This will break the adhesion of the double sided tape that secures the roundel. Step 3: Carefully pull up the roundel to release it from its retaining tabs. You may use a bondo spreader to help pop it free. Keep the factory grommets in place to re-use them. Step 4. Clean the residue from the OE double-sided tape with a clean cloth and adhesive remover. Ensure the area is clean and dry before installing the IND hood roundel. Step 5: After discarding the ring of painters tape from the hood, expose the double-sided tape on the IND roundel and, with uniform pressure, press the new piece into place.
03-30-2018, 08:52 AM | #3 |
BMW obsessed
9601
Rep 10,891
We should have them ready within a couple of weeks, if not sooner.
trackday96154.50 neohh168.00 |
04-07-2018, 04:22 PM | #5 | |
BMW obsessed
9601
Rep 10,891
Hope this helps. Matte Black, Gloss Black, and Black Chrome
04-07-2018, 05:05 PM | #6 |
261
Rep 472
thank you!
IND-Distribution9600.50 |
10-25-2018, 09:16 PM | #9 |
1721
Rep 1,915
Drives: 2023 M5C
Is the front or the rear roundel larger? I ordered both the hood and trunk painted roundels, but the larger one doesn't have any adhesive on the back of it...
