02-05-2018, 04:10 AM | #1 |
17
Rep 23
530e Max Performance Mode - Help
Hi All,
So I just picked up my 530e and am still playing around with the multitude of options & settings for A) The Most Economical Mode and B) The MAX performance mode. I am struggling with the latter and am not convinced that the battery and engine are working together to produce the best performance. This is what I THINK are the correct settings for maximum output but would like other 530e owners to validate : - Auto E-Drive - SPORT MODE - TRACTION OFF (As much as Poss) - Flick gear lever to the left - At Least 50% battery power remaining So when I plant the accelerator it seems to have 2 modes. When you 'think' you have floored it you then need to press it much harder and you can feel a second kind of clunk - is that Kick-Down? And should it feel slightly clunky when engaging? I could be wrong but I suspect that you are not getting full power of both the petrol and electric engine unless you are in that kick-down mode. Sorry if this is all basic knowledge but would appreciate anyone elses take on this theory. Cheers! |
02-05-2018, 07:46 AM | #3 |
17
Rep 23
@lnaukkar - Is it normal to feel that extra click/notch in the accelerator pedal as you plant hard for Kick-Down? I hadnt realised that you literally have to shove your foot down and presumed that I had been flat out so far. In reality that was just the petrol engine and not the additional combo of the battery engine.
02-05-2018, 08:42 AM | #4 |
25
Rep 118
I think every BMW has got the click at the end of the acceleration pedal, thats not a "530e thing"
That click is kickdown. Otherwise you just get full throttle, but with the click you are also forcing transmission to choose the optimal gear for full on acceleration. |
02-06-2018, 03:56 AM | #6 |
25
Rep 118
Of course you should get full electric + petrol without kickdown.
You can verify using the power display (shows you the power and torque output) or edrive status display (shows you whether car uses petrol, electric or both). |
02-06-2018, 07:59 AM | #8 |
3086
Rep 4,210
I have programmed one of my memory buttons to bring up the edrive status display.
