05-24-2017, 08:58 AM | #1 |
4185
Rep 3,077
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Monitoring Engine Vitals on iDrive Display
I am sharing this info out confirming I was able to code under Expert Mode the screen sharing for Android. I use iPhone's but have always had an Android around to use Torque which displays lots of info needed.
This will help on track days. Searching around I found the following list of parameters which I coded in Expert Mode using the BimmerCode APP. Thanks to Almaretto and Gabrola I coded all these parameters to be aktiv and now my iDrive menu is showing the Screen Mirroring option. Had trouble initially connecting the phone but it was because its an older Android, tried with Galaxy S6 and S5 and it works. Did mine using Bimmercode app.. It wasn't all straightforward to find but in expert mode under the display module I just typed in the parameters and the Bimmercode app narrows them down for you, then set them to aktiv.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii Last edited by BAN_M2C; 07-03-2017 at 03:51 PM.. |
05-24-2017, 10:46 AM | #2 |
2814
Rep 3,696
That's killer. Can you still run background apps like BMW Laptimer while this is active? If so, do you have more detailed instructions for some of us newbies?
Thanks! |
05-24-2017, 11:56 AM | #3 | |
4185
Rep 3,077
I dont use M Laptimer since I actually have the Performance Analyser but that uses an OBD2 dongle so I cant use them together. I have been in contact with the Performance Analyser developers to suggest letting the app display many of these parameters together this way I dont have to resort to this solution and still be able to record my runs. I understand Torque allows recording vid also so I will try it. I do believe you can still run apps in the background, I will confirm by running Music apps while mirroring this and see if the audio still runs thru the cars speakers.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
Mr 294.00 |
05-25-2017, 06:13 AM | #5 | |
4185
Rep 3,077
I found a thread on the e90 forums about custom Torque PIDs and someone put ont together for a 335. Need to read more about using those customs PIDs.
Follow me on IG
06-08-2017, 09:47 AM | #6 | |
1779
Rep 4,516
Good work. For a JB4 user controlling Jb4 via BT on android JB4 app, would screen share work so JB4 app display - see below - shows on idrive ?? BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
06-08-2017, 09:52 AM | #7 | ||
4185
Rep 3,077
Follow me on IG
06-29-2017, 10:38 AM | #8 |
2051
Rep 3,714
Does M laptimer show oil/water temps? I use AIM solo for timing but I wouldn't mind keeping M laptimer up if it shows this critical info.
07-03-2017, 03:37 PM | #9 |
4185
Rep 3,077
Not sure about the Laptimer but the Performance Analyser does. But it doesn't display it as multi gauges. You can have them data logging during the runs.
Follow me on IG
07-03-2017, 03:50 PM | #11 |
4185
Rep 3,077
Yes, I did mine using Bimmercode app.. It wasn't all straightforward to find but in expert mode under the display module I just typed in the parameters and the Bimmercode app narrows them down for you, then set them to aktiv.
Follow me on IG
07-03-2017, 04:03 PM | #13 |
4185
Rep 3,077
When you are searching for the Parameters in Bimmercode under expert mode the app provides you an area at the top where you can type the parameters in for ease of finding them. Pretty similar to the search ESYS provided.
Follow me on IG
07-03-2017, 09:18 PM | #15 | |
4185
Rep 3,077
I figure if this works as I expect during track days, I might jump back to the Android world again. Never been locked on any of them have moved from iPhone/Android couple times.
Follow me on IG
07-03-2017, 11:49 PM | #16 | |
325
Rep 240
'02 E39 M5-Gone
'07 E60 M5-Gone '07 E64 M6 Cab-Gone '17 F87 MG M2-Gone '19 F87 SO M2C |
07-04-2017, 12:13 AM | #17 |
4185
Rep 3,077
Yes, iPad or iPhone.. I setup Bimmercode on the iPad.. easier to code and navigate on the bigger screen..
Follow me on IG
07-04-2017, 02:15 AM | #19 | |
4185
Rep 3,077
Probably same reasons why you can't screen mirroring from iOS devices to TV's directly without an Apple TV
Follow me on IG
07-19-2017, 03:33 AM | #20 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
You could also code the options into the car using a laptop + ESYS + appropriate coding cable, you wouldn't need an iPhone/iPad for that. Bimmercode is just an alternative (easier to use) than ESYS.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. |
07-20-2017, 09:33 AM | #21 |
82
Rep 156
This wont work on my car!
I followed the steps, the Screen Mirroring option is present, and I can connect to the car with my phone, but as soon as I choose the Screen Mirroring option from the Media section of the iDrive, it asks me to Add a Device! Device has already been added, so I dont know why this is happening. Anyone have a clue? |
07-20-2017, 09:41 AM | #22 | |
535
Rep 1,011
bottom right icon is what it looks like from the drop down on most android phones: |
