05-15-2017, 12:33 PM | #1 |
2814
Rep 3,696
Camber Plates vs Coil Overs
Hey guys.
I need some more negative camber in the front (like most everyone here). Is this best achieved with camber plates or coil overs and lowering the car? Pros/Cons to these two approaches? (Cost, comfort, performance, etc). Thanks! PS. I understand that these are two different upgrades. I'm looking at this as: if coil overs will take care of the negative camber issue, then I could apply the cost of installing plates towards coil overs, assuming comfort isn't negatively impacted and the performance upgrade to coil overs is worth the additional cost over just plates. Last edited by ZM2; 05-15-2017 at 03:52 PM.. |
05-15-2017, 05:04 PM | #2 |
300
Rep 379
It turns out you need camper plates to adjust camber in the front no matter what. If you where to install coilovers without camber plates you will still be at stock camber.
From a cost perspective, you can just install camber plates with the stock suspension. There are pros and cons to this approach though. Cons: -You will be buying camber plates that may only work with the stock strut mount. They will not work with most coilovers -Should you decided to install coilovers you will need to pay the some of the same labor twice. -No change at all in comfort / ride Pro: -Savings of not buying coilovers -Maintenance costs of some coilover kits after XX number of track days, total miles or racing time (Ohlins R&T as an example requires servicing 10 hours of racing time, max of 20 hours or approx. 18,000 street miles). -Major change in comfort, some for the better. -Much better for the track of course I installed Ground Control plates without coilovers. I am planning on moving to the M Performance coilovers over summer or next spring. The GC plates with the stock mount support both stock struts and the MP coilovers.
BMW CCA and PCA HPDE Instructor
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 Last edited by M2joey; 05-16-2017 at 02:00 PM.. |
05-16-2017, 09:24 AM | #3 |
2814
Rep 3,696
Great breakdown. Thanks isjoey.
I think I'll go with the Vorshlag plates for now and add the MP coilovers and corner balance down the road. PS. You were looking good at Summit this weekend with just your plates and 4S's! I think I may try 265/285 4S's and hopefully no rubbing with the plates installed. Are you able to see how much clearance you have with your 255's upfront? |
05-16-2017, 01:56 PM | #4 | |
300
Rep 379
Certainly cannot go wrong with Vorshlag. I also had corner balance / weighting done, for two people and a full tank of gas. Should have had it for an empty tank of gas as every time I look I am out of gas. Thanks. Seemed to be good, front wear is pretty good/even, little more wear than I thought I might have on the outside of the fronts but not bad. I think I will be going with 265/285s next time. You will be fine with 265 up front with or without camber plates. I have noticed a few people are doing this without any issues.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
05-16-2017, 02:23 PM | #5 |
2814
Rep 3,696
Cool. I'll definitely go ahead with a track focused alignment when the plates are installed in a couple weeks. Any tips on settings?
Also, how much was the cost and benefit for the corner balance? Just trying to decide if I do that now and again later with the coil overs, or just wait. Thanks! |
05-16-2017, 04:02 PM | #6 | |
300
Rep 379
Front: Camber = -2.5 to -2.8, stock is -1.3 Total Toe = 0.00 to 0.10 - some are running 0.00, stock is 0.16. You might want to stay a little conservative and take a smaller step like 0.10. Rear: Camber = -1.8 to max of -2.0, stock is -1.8/-1.6 Total Toe = Seeing specs in this forum with 0.16 to 0.20, which is very aggressive. My shops system pulled 0.26 from BMW. I am still working on validating the US specs as my M2 had 0.21 stock. The alignment was very out of wack all around stock. Google the benefits of corner balancing. Most shops will include the corner balance/weighting as part of the alignment. RRT, where I go, charges $175 for a "aggressive alignment" that includes corner balancing.
ferrylo761.50 |
05-19-2017, 09:37 PM | #10 | |
634
Rep 650
05-20-2017, 07:58 AM | #11 | |
300
Rep 379
05-22-2017, 03:36 PM | #12 | |
793
Rep 1,367
