01-31-2017, 10:16 AM | #1 |
242
Rep 535
530e 12v battery charging
My i3 has a small 12v battery for running accessories and it's charge is maintained from the high voltage propulsion battery. On my 2015 528i, I use a maintenance charger to keep the 12v battery fully charged while idle, as the "regenerative charging" system does not do a good job of keeping the 12v battery charged in short trip city driving.
My question: Does anyone know if the 530e will have a similar maintenance charge from the high voltage battery to the 12v battery? I understand that BMW has been automatically replacing the 12v batteries in the 528i at the second service because of premature battery failure due to inadequate charging of the 12v battery. |
01-31-2017, 03:12 PM | #2 |
1312
Rep 10,185
Havent got the G30 documents for the Hybrid yet, but if its similar to the 7 Series like a lot of other G30 systems then it uses a charger in the trunk to look after the auxiliary battery.
The charging unit is controlled by the DME to charge the battery at any time it is required, including when the car is plugged into its external charger. It is connected to the high voltage system via a DCtoDC converter.
BMW if you are reading, I need a job, Please. |
02-01-2017, 12:57 PM | #3 |
242
Rep 535
Thanks--that's good. Keeping a charge on the hi voltage battery will keep the 12v battery topped up, as well. I noticed in the 5 series reveal last week that the non-e 12v battery is out of the spare tire well and back in the front on the passenger side of the firewall. Guess that's what allows a "delete" option for the run flats and a mandatory $150 "add" for space saver spare. I doubt that many dealers will stock cars with the non-run flat tires, so it means that I will have to order mine, when the time comes.
02-01-2017, 01:47 PM | #4 | |
1312
Rep 10,185
The main battery is still in the trunk. Depending on equipment fitted the regular G30 can actually have 3 batteries Same as G11 7 Series
02-22-2017, 06:16 PM | #5 | |
49
Rep 108
http://www.bimmerfest.com/forums/sho...5&postcount=12
2017 X5 xDrive40e - Driver Assistance Plus, Adaptive LED Lights (decoded VLD + Glare Free High Beam), ACC Stop & Go, Night Vision, 275/40R20 315/35R20 Pirelli PZero + Pirelli Scorpion Ice & Snow
2018 330e - Driver Assistance Plus, Adaptive LED Lights (decoded VLD), Active Blind Spot Detection, ACC Stop & Go, Parking Assistant, Side/Top Cameras, HUD, Comfort Access, 225/45R18 255/40R18 Pirelli Cinturato P7 + Winter Sotozero Serie II Last edited by MochiEater; 02-22-2017 at 06:34 PM.. |
02-22-2017, 07:14 PM | #6 | |
49
Rep 201
02-23-2017, 09:41 AM | #7 |
242
Rep 535
Thanks to all. I saw that the delete run flat option was removed from the 530e and suspected that the well was being used for other purposes. Just drove a new 530 with the M Performance package and 19" run-flats. The ride was much better than with the 18" Run Flats that came with my F10. Others have stated that each generation of run flats gets better and it looks like the G30 run flats fit that prediction--to the extent that I will not feel the need to take off the run flats when I go for a lease pull forward for the 530e this Dec. Thanks for the real life info on the 12v. charging. Guess I can retire my Cetek next Dec.
02-23-2017, 12:08 PM | #8 | |
49
Rep 201
02-25-2017, 11:40 AM | #9 |
242
Rep 535
It had the "M performance package". Don't know if that includes DDC. The new configurator is so difficult to use that I won't even try to go back and look until I have something else to look for (like when the 530e configurator comes up--I know it's up on the forum, but BMW doesn't have it on it's web site, yet).
