BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions m sport brakes
      12-21-2016, 03:27 AM   #1
robfen
121
54
Drives: i4 and 550e
m sport brakes
Hi Everyone
Would anyone care to speculate if the m sport brakes would fit ok with
an 18 inch wheel? Only available with 19 inch wheels on UK Configurator...
Cheers
      12-21-2016, 06:46 AM   #2
E90Fleet
South Africa
1312
10,185
Drives: BMW
M Sport brakes require 18" wheels
You can see this on the German configurator aswell ( add M Brakes to a standard car and it automatically adds 18" wheels)
M Performance brakes require 19" wheels
The actual brake disc sizes are
540i Euro
Standard brakes are Front 348x36 Rear 345x24
M Sport brakes are Front 374x36 Rear 345x24
M Performance are Front 395x36 Rear 370x24
530i Euro + 530d Euro
Standard brakes are Front 348x30 Rear 345x24
M Sport brakes are Front 348x36 Rear 345x24
BMW if you are reading, I need a job, Please.
Mikej0h48.50
      12-21-2016, 07:01 AM   #3
remmib
remmib's Avatar
Norway
1569
29,202
Drives: 2013 F10 520d M-Sport
Should not 17" fit over the smaller M sport brakes on the 530, I see they won't fit on the 540i.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      12-21-2016, 07:43 AM   #4
E90Fleet
South Africa
1312
10,185
Drives: BMW
The parts system says no to 17" wheels if the car has M Sport Brakes.
Remember it is a different caliper design for the 530i M Sport brake( Fixed vs Floating)
So the caliper may be larger causing them not to fit 17" wheels
      12-21-2016, 09:32 AM   #5
remmib
remmib's Avatar
Norway
1569
29,202
I was thinking the calipers might be different, but the 348 mm diameter itself shouldn't be a problem. Do you think it's barrel clearance or spoke clearance that's the problem with 17".
      12-21-2016, 10:21 AM   #6
E90Fleet
South Africa
1312
10,185
Drives: BMW
May be the barrel to the different caliper
The spoke clearance is not much different between the different wheels
17" 7,5J ET:27
18" 8.0J ET:30
M18" 9.0J ET:44
      12-21-2016, 10:34 AM   #7
robfen
121
54
Drives: i4 and 550e
thanks
Thats great info especially the german configurator.
I'll probably get the msport and pick up a set of 18s separately
as the roads here are poor
Thank everyone.
      12-22-2016, 06:46 AM   #8
E90Fleet
South Africa
1312
10,185
Drives: BMW
For info,
G30 Caliper Manufacturers:
Front
Standard 1 Piece 4 Piston - Continental
2 Piece 4 Piston - Brembo
Rear
All - TRW
      12-27-2016, 02:54 PM   #9
remmib
remmib's Avatar
Norway
1569
29,202
I was looking at the M sport brakes (blue) on the M550i and the M performance brakes red).
I notice the calipers looks to be the same just different colors. But I assume the M sport brakes are 374 mm for the M550i as it is for the 540i, but the M performance brakes are 395 mm.
So how can the same caliper fit different sized rotors?
      12-27-2016, 03:28 PM   #10
.BMW.
.BMW.'s Avatar
Sweden
1863
5,140
Drives: BMW F11/F31
Similiar for F30.
The M Sport brakes has 340 and 370mm front rotors depending on engine. The M Performance brakes has always 370mm front rotors.
The calipers for 340 and 370 rotors looks the same from the outside but the mounting points on the inside is different to fit different rotor sizes. Therefore there are two different part numbers for the blue front M Sport brake calipers for F30.
I guess the same is valid for G30 M Sport and M Performance brakes.
540iSUP704.00
      12-28-2016, 06:01 AM   #11
E90Fleet
South Africa
1312
10,185
Drives: BMW
Why do you assume 374mm ?
The M550i comes standard with 19" wheels. This may be because of the brakes.
So they may be 395mm standard.
      12-28-2016, 06:46 AM   #12
remmib
remmib's Avatar
Norway
1569
29,202
I just thought the M550i looked slightly smaller than the M performance brakes, and 19" was also standard on the f10/11 M550d, but it could still fit 18" winters.
I don't know if this is still the case with the new M550i, or if BMW really has gone for 19" as minimum wheels size.
Here's the 540i M sport with 374 mm brakes, but it's hard to see if it's the same as the M550i because of all the spokes.
      12-29-2016, 06:00 AM   #13
E90Fleet
South Africa
1312
10,185
Drives: BMW
Will have to wait for it to appear on the parts system before we can confirm.
So maybe only late January
      01-09-2017, 06:06 PM   #14
remmib
remmib's Avatar
Norway
1569
29,202
One more of the M550i.
      08-13-2022, 05:18 PM   #15
FullBolton
FullBolton's Avatar
78
66
Drives: BMW G30
  [0.00]
2017 BMW 540I  [0.00]
https://youtu.be/O0UMXyiwdpY
5post
