09-23-2016, 09:05 AM | #1 |
71
Rep 178
What engine oil is your BMW running?
Hello everyone,
This is just a general question. BMW has four options for engine oil and I'm sure as many of us are aware, you have to top up your engine oil occasionally between oil changes. BMW recommends Castrol engine oil (according to the knob in the engine bay). So my question is: What oil do you prefer for your BMW, and what would be best for an F30 335i when it comes to topping up? (ie: do you have a brand/viscosity preference and why?)
2014 335i | 6 MT | M-Sport | X-Drive | MPE | Black Sapphire Metallic | Coral Red | MHD 2+ | DP/CP | KN Intake
09-23-2016, 09:09 AM | #2 |
7478
Rep 10,120
Remember ONLY top of when it says +1. The electronic gauge is a measure of 1 liter of oil and NOT of the entire oil pan. In my 335 I only had to add once between an oil change and that was due to a slight OFHG leak. At this time ALL my gaskets have been replaced and I never have to top off between changes. Although I do change my oil ever 6k miles.
IF you are using this interval and have the need to add a liter of oil then you might have a leak some where.. |
VRG_135838.50 |
09-23-2016, 09:34 AM | #3 |
935
Rep 1,930
you might want to post this on the 335 page.
BMW recently switched from Castrol to shell now on the 10W60. People here with M's are limited to those and Liquid Moly |
09-23-2016, 09:48 AM | #4 |
423
Rep 887
Castrol is what's in there now from the dealer. Next oil change, I will be going to an Indy (car's warranty\free miant. is up) and it will be Lubro Moly.
09-23-2016, 09:50 AM | #5 |
34
Rep 485
Mobil 1 0w40. Made for high heat German cars, and lab tests on BITOG.com show low wear metals on nearly any engine. Mobil doesn't claim the BMW spec anymore. I like 10k mile oil changes, and can get Mobil 1 0w40 for dirt cheap every where.
My car is the N20 in a X1 s28i. I see they have a BMW Longlife-14+ spec for 0w20 to improve mpg 3%. I consider 0w40 the thinnest oil that I'll run, and holds its film strength under stress. Some other oils that are listed as 5w30 are actually approx thickness cold or hot. Last edited by 0w40X1; 09-23-2016 at 10:07 AM.. |
09-23-2016, 12:18 PM | #6 |
71
Rep 178
I saw the 0W40 in the OM and that's what I'm running right now. Seems to be pretty fuel efficient, and to my understanding they also call it BMW longlife 01 on the label. So here are the next questions:
Would it be okay to mix different oil? Let's say for argument's sake your dealer put 0w40 and you top up with 5w30 which is listed on the OM, would that matter at all? Would it be better to have a thinner oil, or a thicker oil? Also, would the oil viscosity change based on seasons or use the same year round? Should we be switching our oil to thicker/thinner ones through the winter vs. Summer? |
09-23-2016, 12:37 PM | #7 |
1412
Rep 3,211
I'm stickin with European Formula Castrol until someone satisfies LL-14
You cant get it for as cheap as MobileOne but the fact MO is sooo damn cheap at WallyWorld really has me wondering how cheaply made it really is.. |
09-23-2016, 03:04 PM | #8 |
31
Rep 136
There is a sticky thread on this.
http://www.e90post.com/forums/showthread.php?t=529230 Make sure it's specified for BMW LL0-01, which is what you want if you're running your car on American gasoline. BMW LL-04 certified is not specified for use within the US due to the high sulfur content in our fuel. More reading: http://www.bimmerforums.com/forum/sh...l-5W-40/page3&
2010 335i Coupe E92 N54. JB4, Burger dual cone air intakes, ER chargepipe with Turbosmart blow off valve, AMS intercooler, catless downpipes, Koni yellow shocks and struts with H&R springs. Stoptech rotors, pads, and lines, KMC691 bronze in 19" 35mm offset, Pilot Super Sports 235/35/8.5 and 265/30/9.5, LED angel eyes, EL interior accent lighting,Stereo (Helix DSP, Arc Amp, Jehnert subwoofers, Morel woofers and tweeters), Formula1 tint.
09-23-2016, 03:11 PM | #9 |
34
Rep 485
I'm using Mobil 1 till they pry it from my cold dead hands. LOL
To the previous posts. I was a fuel and oil distributor for Exxon, and I tested the factory fill in my X1 s28i. It was very good, and nil break in metals. I changed to Mobil 1 0w40, and then, changed back to 5w30 BMW for the free oil change. I'd say you could run half of each if you wanted. After studying 0w40 to death, it has just about the right thickness for anything unless someone says they have super tight engine, and needs thinner 0w20. I'm in hot desert, and I'm never running 0w20 even though many cars can get good lab results. This difference is: if you drive4 for economy everywhere 0w20 might work, but if you're gonna try out the high power part of car 0w40 is about as thin as it should be. I'm pretty sure nobody has made a fake Mobil 1 for Wallyworld. Mobi wouldn't stand for it, and like their fuel they buy and test their stuff out in the market place. |
09-24-2016, 03:13 PM | #10 |
6659
Rep 15,858
I'm in the UK and my dealer was using Castrol.
With BMW now moving over to Shell, my last oil service (N55 engine) had a red stamp on the worksheet, specifying Shell Helix. Not seen the exact spec' being used, but assume it is something like Shell Helix Ultra 0W-30 or 5W-30; as these are to BMW LL-04. Will be interesting to see if there is any difference in oil consumption. To date consumption negligible. |
09-24-2016, 03:45 PM | #11 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
I've done stock bmw oil it's entire life until 80k just switch to the shell rotella t6. It's inexpensive and has good reviews especially with turbo cars and trucks. That being said iirc bms said all they use is mobile 1 and have had no issues. There is so much discussion about oil. Get a good one and change it often if you are pushing the car is the best advice I can give.
09-24-2016, 03:59 PM | #12 | |
European Editor
10594
Rep 22,992
0w40X1
Also... I use to run Mobil1's 0w40 European Blend oil(bought on Base/PX). But then I started to read some threads on 1Addicts back in 2009, touring the German Castrol(also 0w40) blends... so I tried some(even though it was more expensive)... I was shocked at how much quieter the engine ran on cold start(much less metallic noises) and more importantly the oil temps ran almost two needle widths cooler!! I was sold on German Castrol ever since! insanecoder I've also read on BTOG forum that Mobil1 isn't what it used to be. I think running a top tier oil brand like German Castrol, Shell Helix, Motul, Amsoil or Redline is the way to go. Also using short oil change intervals(OCI) is the way for a long living BMW engine. Too many times you see people with dirty vanous sensors due to long OCI's. Dackel
09-24-2016, 04:01 PM | #13 | |
European Editor
10594
Rep 22,992
Besides... if your changing your oil more often than 10K miles/once per year, I wouldn't be too concerned with the LL rating(s). The BEST oil is FRESH oil.
Jim_B14.50 |
09-24-2016, 08:15 PM | #15 | |
31
Rep 136
Some supporting documentation from BMW TIS, and another source: http://www.bimmerforums.com/forum/sh...2#post28267232 http://www.bimmerforums.com/forum/sh...7#post28268737 Read note #2 at the bottom: http://s34.photobucket.com/user/esca..._2009.png.html
oolas3388.00 |
09-24-2016, 09:20 PM | #17 | |
1412
Rep 3,211
I use 0w-30 Belgian Castrol.. Ill check out moving up to 5W.. |
Dackelone10593.50 |
09-25-2016, 12:04 AM | #18 |
34
Rep 485
If you look up viscosity weights you'll see that some 0w30, 5w30, and 0w40 are all about the same viscosity at operating temp.
I think Mobil 1 0w40 might even be thinner than Castrol 0w30, but they are mostly close to ideal vis. Shell Rotella T6 is a diesel oil with good additives for all that carbon, so will work great with gasoline engines, too. It seems that there are many oils out now that won't hurt engine, but aren't necessarily spec'd for them. |
Dackelone10593.50 |
09-25-2016, 12:09 AM | #19 |
1412
Rep 3,211
I'd rather focus on the full synthetic oils not the halfies or dino-oil dressed with tons of detergents..
0W thin BMW likes to make its efficiency #s but yea I wouldn't mind a 5W for alil more protection |
tomjonesBT33177.00 |
09-25-2016, 09:39 AM | #20 |
17364
Rep 18,757
310,000 miles on BMW 5W-30 and OE filters. Just did my 23 oil change yesterday.
09-25-2016, 10:01 AM | #21 | |
34
Rep 485
5w40 is thicker at 14.2 cst @ 100 deg C Widman.com has a graph to play with. |
09-25-2016, 11:49 AM | #22 |
1Addict
3237
Rep 7,897
Motul 8100 Xcess 5w40
