07-23-2016, 01:18 PM | #6 |
3079
Rep 5,579
You need a drain plug gasket which comes with oil filter sold at BMW dealer.
And you need a large enough socket to loosen the oil filter cover cap. And you just need a piece of semi rigid plastic to funnel the oil from the drain plug pass the under body panel into the drain pan - you'll see what I mean when you get under the car - but you don't really even need that. And if you lift the car many ramps will scrape the M package front air dam, and if you lift from the sill a plastic or special pad adapter so you don't chew up the rubber sill lifting pad. |
07-23-2016, 02:10 PM | #7 | |
560
Rep 1,503
But double check.
FBO M235i r
F80 M3 |
07-24-2016, 08:16 AM | #8 |
626
Rep 1,753
Consider getting a magnetic drain plug the first time you do it. I haven't done one yet, but I'm coming up on 6k miles. Considering doing one. I already had the dealer do one for me after break-in though, so idk if I need another before my scheduled one.
I've done some searches and the most detailed one I can find is for a M4. Does anyone have a pic of which plug to loosen? Aren't there two plugs behind that door? I have a 6MT.
07-28-2016, 03:50 PM | #9 | |
560
Rep 1,503
FBO M235i r
F80 M3 |
