2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning 228i stalling when warm after charge pipe and intercooler install
      10-01-2015, 11:36 PM   #1
rodent47
23
Drives: f22 228i mineral grey
Hey guys this is my first post so I apologize if this is posted in the wrong section, if it can be moved to the right section
Current mos list;
BMS stage 1 tune
Injen intake
Oil catch can
ER charge pipe
ER intercooler
So after I installed the ER charge pipe and ER intercooler I went on a test drive and first run the charge pipe hose came loose (t bolt clamp wasn't tight enough) so after I fixed it I went on a test drive, drove it normally in comfort mode and then in sport +, all seemed fine. After an hour I turned on my 228i (8-speed auto) to test drive again and put on some gas after but it kept stalling when turning it on and if I give it a little gas it wouldn't stall.
I put on a scanner and it gave me a pending code p0172 (system too rich bank 1)
Any ideas what it could be, it was fine before the intercooler and chargepipe
Only stalls when its warm.
      10-02-2015, 04:35 AM   #2
B.a.f
228i - 2015-03
France
13
66
Drives: 228i M Sport
Lambda sensor problem ?
      10-02-2015, 11:51 AM   #3
rodent47
23
Update: it only stalls when its warm, turned it on in the morning and did not stall at start
      10-03-2015, 02:42 AM   #4
rodent47
23
Could it also be that my BMS stage 1 isn't up to date? I bought it from some else and the previous owner did not include the USB cable so I have not been able to update since I bought it, which is almost a year ago.
      10-03-2015, 10:50 AM   #5
OpenAir
OpenAir's Avatar
432
887
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
Your FMIC shouldn't have anything to do with this...did you accidently knock a sensor loose or pop a connection?
      10-03-2015, 10:54 AM   #6
rodent47
23
I don't think so, but last night I reconnected all the cables to make sure but still the same thing, also some times when i go on a green light it feels like it stutters
      10-03-2015, 02:32 PM   #7
OpenAir
OpenAir's Avatar
432
887
Can you pull codes?
      10-04-2015, 12:14 AM   #8
rodent47
23
Can you pull codes?
Today I fixed an issue where the vacuum hose was not all the way in.
So the stalling went away when warm for now, but the car still shakes a little more than before and still pulling out the code p0172 system too rich bank 1
There is no CEL
      10-04-2015, 12:27 AM   #9
rodent47
23
Also when I give it a little gas and let off there is a small clunk on the left side if the engine (facing the car)
      10-04-2015, 04:48 AM   #10
B.a.f
228i - 2015-03
France
13
66
According to a topic a few lines away from yours, stuttering could be solved by using colder spark plugs ...
      10-04-2015, 12:02 PM   #11
rodent47
23
I guess I will give that a try tomorrow, thanks for letting me know hopefully this fixes the issue as I haven't been driving my 228i since the issue started around 5 days ago
      10-28-2015, 02:34 PM   #12
Luminous
Luminous's Avatar
743
893
Drives: 2019 M5 Competition
Try reinstalling the stock intake and see if that changes anything. I know several people with n55s experienced rough idling due to aftermarket intakes, might be the same with n20s.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      11-11-2015, 07:44 PM   #13
OpenAir
OpenAir's Avatar
432
887
Did this get resolved?
2addicts
