2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M235 JB4 install need help
      10-25-2014, 06:07 PM   #1
TB///M3
76
389
Drives: 16 ///M3
Need some reassurance that i did everything ok.
I got the JB4 stage 2.
There are 4 connections, due to our car having an electronic waste the blue cables are not used? So 3 out of 4 is connected?
After connecting the the battery back, i got a couple of warnings, first the stability control, time, and sos malfunction. I drove around a bit and the time and stability went away, accept the SoS malfunction. Anyone know how to fix that? I searched and didn't see anything.
I haven't mapped any settings yet, i want to put some miles first to make sure everything is fine.
      10-25-2014, 07:37 PM   #2
G-Mann
G-Mann's Avatar
413
678
Drives: M4CX
Not sure which harness you got but the newer harnesses they removed one of the harnesses leaving 3 harnesses, along with the power and ground wire and then the two wires you tap into the CAN wires with. If you have a 4th harness it is not needed.
What I have connected are two harnesses, brown and rainbow, the blue harness I am not using. I then have the power and ground wire connected and the two wires that tap into the two can wires.
I would shoot an email over to Burger for further assistance they are very quick to respond.
2022 M4 Comp X
2021 M440ix - Sold
2015 M235 - Sold
      10-25-2014, 07:43 PM   #3
TB///M3
76
389
Drives: 16 ///M3
What I have connected are two harnesses, brown and rainbow, the blue harness I am not using. I then have the power and ground wire and the two wires that tap into can wires.
Yea, i connected the can wire, i have a manual tranny, the brown, rainbow, and powers. I left out the blue.
I went for a drive again and the sos malfunction went away. So all the codes are fine now.
      10-25-2014, 07:49 PM   #4
TB///M3
76
389
Drives: 16 ///M3
For the manual there's no indicator like the autos. To be clear, hold down the - volume button for 6 seconds, then +volume to select map?
Then to reset it back to 0, hold down -volume for 6 seconds and tap the -volume again to set back at 0 map?
      10-25-2014, 08:04 PM   #5
G-Mann
G-Mann's Avatar
413
678
Drives: M4CX
I don't think they have the steering wheel controls active yet and they are beta testing that feature now. I never got them to do squat on my car and there is another thread floating around where somebody spoke with burger and confirmed with them they are not working for us yet.
I had to install the JB4 software and connect up my laptop to confirm maps and switch them.
It might not be a bad idea to get a data log and shoot over to burger to confirm all is good. I had them evaluate my data logs Today for a bit of peace of mind.
Glad to hear all is good and hopefully you have had a chance to get on it.
2022 M4 Comp X
2021 M440ix - Sold
2015 M235 - Sold
      10-25-2014, 08:16 PM   #6
snodgrass23
snodgrass23's Avatar
16
111
Drives: 2015 EB m235i
The new firmware posted a day or two ago does have working volume controls for changing maps. I'm running it now and it works well. As mentioned though, the manual transmission car won't have the blinking lights for confirmation.
aFe Momentum Intake, Dinan springs
      10-25-2014, 08:30 PM   #7
TB///M3
76
389
Drives: 16 ///M3
So...i didnt get the usb cable, so, i wont know what firmware im running.
How do set maps if not on the volume control?
      10-25-2014, 09:07 PM   #8
qballis
270
513
Drives: G80 Comp xdrive
Buy the cable.
      10-25-2014, 10:01 PM   #9
G-Mann
G-Mann's Avatar
413
678
Drives: M4CX
Originally Posted by qballis View Post
Buy the cable.
^^^^^^^ Get the $15 cable. Very unlikely you have this latest firmware and you will need the cable to upgrade the firmware.
2022 M4 Comp X
2021 M440ix - Sold
2015 M235 - Sold
      10-25-2014, 10:14 PM   #10
Delnari
Delnari's Avatar
256
1,040
Drives: 2014 MG F22 Auto
Got the same message when I installed the Dinan system the first time. Disconnect your battery again and unplug everything. Reconnect your plugs and double-check your connections and then re-connect the battery. This cleared my SOS malfunction message and never came back again.
      10-26-2014, 12:24 AM   #11
TB///M3
76
389
Drives: 16 ///M3
I will get the usb cable, but for now, how do i switch maps for a manual? The gas pedal method?
      10-26-2014, 08:26 AM   #12
qballis
270
513
You don't. The latest firmware is what allows you to change maps without the USB cable. You need to USB cable to update to the latest firmware.
You're stuck on map 1 for now until you get the cable.
      10-26-2014, 08:46 AM   #13
TB///M3
76
389
Drives: 16 ///M3
What if i want to go 0 map setting?
      10-26-2014, 09:48 AM   #14
qballis
270
513
You can try holding down volume for 6 seconds depending on what firmware you received the JB4 with, but with a manual there is no way to tell what map you're in.
2addicts
