E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 07 335i is acting weird throwing some codes.
Reply
      10-15-2014, 11:08 AM   #1
JTinNC82
27
Drives: 2009 135i
I was driving the other night and car seemed a lil funny like it had a lil miss to it and gave it a lil gas and started sputtering bad and check engine lights was flashing. Then it just went away and seemed normal. Then it seemed today it was acting a lil funny again. I was running map 4 and switched it to map 2 and didnt notice it as much. Not sure if I have a O2 going bad, fuel pump, plug or coils. Here are the codes i pulled that night.
      10-15-2014, 10:01 PM   #2
X_Drive
X_Drive's Avatar
Japan
263
Drives: E46, E91, F21
A faulty ignition coil will cause those symptoms. A way to verify this is to cross-swap it with another coil, say cyl #1, then see if the misfire migrates with the coil in question. If it doesn't then you can start looking at other things. However, it's probably a coil that is starting to fail.
HTH
      10-16-2014, 10:34 PM   #3
JTinNC82
27
Drives: 2009 135i
Looks like its an o2 going bad. Ive cleared code and keep getting the o2 behind cat 2 showing up. Gonna try to replace it and see what happens
Reply
e90post
