AT: Long pull left paddle to shift into lowest safe gear? |
10-04-2014, 09:45 AM | #1 |
33
Rep 104
How does this work / Is this working for anyone?
I can't seem to figure out how to get it to downshift into the lowest possible gear by long pulling as it says in the manual when in manual mode. Doing so just seem to shift down to the next sequential gear. Seem to recall the CA saying that the 8AT wouldn't always shift down sequentially but that's what it seems to be doing from what I can see. Thanks |
10-12-2014, 10:15 PM | #2 |
33
Rep 104
Anyone? In the manual it says this:
Shift down into the lowest possible gear: pull and hold left shift paddle. But doing so only seems to result in one sequential shift down, not any further. |
10-14-2014, 02:37 PM | #3 |
20
Rep 294
Pull and hold the paddle and floor the gas pedal. I didn't know about this feature. Thanks for the tip.
10-14-2014, 05:53 PM | #5 |
***** noob
1369
Rep 10,479
Is this confrmed...anyone had it worked?
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
10-14-2014, 06:30 PM | #7 | |
***** noob
1369
Rep 10,479
2006 325xi (Sold)
10-14-2014, 08:47 PM | #9 | |
413
Rep 678
Pikcachu can you describe how to do a kick down.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
10-15-2014, 01:14 AM | #12 |
20
Rep 294
10-15-2014, 09:33 AM | #13 |
18
Rep 88
Drives: 435ix Performance Edition
LOL... know your revs and snap the paddle more then once it will never let you select to low a gear
10-15-2014, 07:57 PM | #14 |
33
Rep 104
I'm not sure I understand that comment. My interest was that the manual said something, the CA said something, ostensibly paid for that something and am unclear on how it actually works. There are easier / more straightforward ways as you and others mention to gear down.
Tried your suggestion FlyingFinn - it does not seem to work if within the first 1/3-1/2 of the throttle pedal range. I did not mash the throttle to the floor as you suggested, so perhaps that is the deciding factor? Will have to test when I have some clear road to try it on. Hopefully that will help to identify the exact pattern to do this. |
10-15-2014, 08:24 PM | #16 |
***** noob
1369
Rep 10,479
lol another misinform from bmw
2006 325xi (Sold)
10-15-2014, 08:32 PM | #17 |
13
Rep 114
I tried it last night and if you do the hold and tap the gas pedal hard (not floor it) it will automatically shift down the the lowest gear it sees fit ONCE, but will not continue to shift down after. (i.e. if decelerating at, say, 2k rpm in 6th, hold the down shift and tap the gas pedal hard it might skip down to 3rd).
10-15-2014, 08:48 PM | #19 |
13
Rep 114
10-15-2014, 10:29 PM | #20 |
183
Rep 926
I like using the gas pedal to do this. It will not put the car into manual mode. downshifts become controllable through the gas pedal (lowest gear) and upshifts remain automatic.
Fun for street I'm sure for track use you would want to leverage the paddles in manual. |
10-16-2014, 10:49 AM | #21 | |
20
Rep 294
