08-27-2014, 11:17 AM | #1 |
270
Rep 513
JB4 Stage 1 Require Scanner Cable?
Hopefully I'm not beating a dead horse here...I've searched and searched and have still not found the answer.
I only have BMS Intake and M Perf Exhaust on my car. I'm interested in the BMS N55 Stage 1 because I'm not adding DP or any other mods, and it's plug and play (no splicing/tapping). My one concern is if I will need the Scanner tool from BMS (http://www.burgertuning.com/scanner.html) to delete tuner detection codes if the BMS N55 Stage 1 even shows those to the ECU. Last edited by qballis; 08-27-2014 at 01:23 PM.. Reason: No such thing as JB4 Stage 1... |
08-27-2014, 06:59 PM | #7 |
Joint Chiefs of Staff
24198
Rep 190,805
As stated above no you do not need the scanner tool
08-27-2014, 07:02 PM | #8 | |
270
Rep 513
Do I need the BMS USB cable to upgrade firmware on the Stage 1? I just bought one used from someone with a 5 series (Stage 1 Harness B). |
08-27-2014, 07:24 PM | #10 | |
270
Rep 513
08-27-2014, 07:26 PM | #11 |
262
Rep 528
I edited my original post. Yes it's static so I would assume you wouldn't need it. The SMEs here could give you the correct answer. Stage 1 is plug and play. Only way to "upgrade" is to purchase stage 2....EWG/FF wires...USB.
08-28-2014, 09:33 PM | #13 |
12971
Rep 18,716
With a BMS Stage 1's latest board, you can use the usb cable to do a datalog only.
The earlier BMS Stage 1 doesn't have the serial port to connect to.
09-03-2014, 08:39 PM | #14 |
248
Rep 430
Does this modification voids the BMW warranty? To the guys that already have a modification like this one, do you remove it before taking the car to the dealership? Do you guys know of any risk with this modification? I have not upgraded the intake on my M235i just yet. I'm leasing, what do you guys recommend I should do as far as modifications on the M235i?
09-03-2014, 08:40 PM | #15 | |
270
Rep 513
