2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Oh My!
      07-20-2014, 07:57 PM   #1
Ohio Army Man
14
147
Drives: 2014 M235i
Oh My!
Had jb4 running for a month... No problems.
Installed MPE... No problems
This afternoon... Installed BMS intake...
5 minutes drive no problems.
6th minute....problem.
CEL came on... Then Drivetrain Malfunction... Maximum output not available.
Could not connect to JB4 at all... (Have done many times in the past)
I completely removed the JB4... No help... I disconnected and reinstalled the factory intake...
No help.
Car is now completely factory, with MPE...
CEL STILL ON
DRIVETRAIN MALFUNCTION... Still going on...
Any damn clues anyone?
      07-20-2014, 08:40 PM   #2
kerm1t
169
926
Drives: 17 M3 ZCP Stage 2
No help.
CEL STILL ON
not a big deal, ur car will probably go into limp mode. its most likely a bad connection, ground or power. happened to me as well.
make sure u have EVERYTHING connected properly
      07-20-2014, 08:42 PM   #3
Ohio Army Man
14
147
Drives: 2014 M235i
So... What do I check for?
I guess it's limp mode...
Maxium power not available.
Took it for a spin.. See if it may reset itself.. 8 miles... No help.
What did you do?
      07-20-2014, 08:50 PM   #4
ska///235i
***** noob
ska///235i's Avatar
1369
10,479
2006 325xi  [0.00]
What did you do?
You forgot to reconnect the O2 sensor
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-20-2014, 08:57 PM   #5
Ohio Army Man
14
147
Drives: 2014 M235i
Where is that located?
      07-20-2014, 09:05 PM   #6
Ohio Army Man
14
147
Drives: 2014 M235i
There were two factory connections to reconnect, correct?
      07-20-2014, 09:44 PM   #7
ska///235i
***** noob
ska///235i's Avatar
1369
10,479
2006 325xi  [0.00]
The connector at the intake...did u reconnect?
2006 325xi (Sold)
      07-20-2014, 09:52 PM   #8
Ohio Army Man
14
147
Drives: 2014 M235i
Please forgive me, as I didn't hook it up. However, when disconnecting it.. I reattached two BMW connections.
Both on the right side of the car.
1) back on/close to the firewall, had to remove engine cover to access it
2) behind the air box and down.
Does that make sense?
      07-20-2014, 10:23 PM   #9
dt20011
dt20011's Avatar
262
528
Drives: 2014 M235i
I was told if you touch the actual sensor on the O2 sensor itself it goes bad. Maybe that's the case?
      07-20-2014, 10:36 PM   #10
ska///235i
***** noob
ska///235i's Avatar
1369
10,479
2006 325xi  [0.00]
My bad, i meant MAF sensor. Did u disconnect that?
2006 325xi (Sold)
      07-21-2014, 05:14 AM   #11
Ohio Army Man
14
147
Drives: 2014 M235i
I did remove and replace for the intake.
Don't remember specifically if I touched the sensor.
      07-21-2014, 07:26 AM   #12
Delnari
Delnari's Avatar
256
1,040
Drives: 2014 MG F22 Auto
Not this will clear the CEL, but when you add/remove the JB4 it is recommended to remove power to the car by disconnecting the battery. I did this procedure everytime I have installed a device or remove one; always disconnect the battery.
Disconnect the battery for 1 hour and reconnect and see if the CEL will clear itself. If not, you will need an OBDII reader/reset tool to clear the fault.
      07-21-2014, 07:27 AM   #13
Ohio Army Man
14
147
Drives: 2014 M235i
Did that
      07-21-2014, 09:42 AM   #14
dharo1
dharo1's Avatar
215
661
Drives: Previous: F22 M235i ; F80 M3 ;
Did that
Any luck? Did you replace the chargepipe as well?
      07-21-2014, 10:29 AM   #15
Ohio Army Man
14
147
Drives: 2014 M235i
Update #1...
Took it to a local shop, their showing the codes... They clear them... Instantly the codes come right back.
This is fantastic.
NOT2DAY117.00
      07-21-2014, 10:31 AM   #16
alz0rz
What goes here?
alz0rz's Avatar
452
1,356
Drives: 2019 G30 M550i
Would be helpful if we knew exactly what the codes were.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      07-21-2014, 10:33 AM   #17
Ohio Army Man
14
147
Drives: 2014 M235i
Good point. Sorry, I'm flustered.
Give me a few... Just pulled into another shop..
I'll see it on theirs again.
      07-21-2014, 10:40 AM   #18
ska///235i
***** noob
ska///235i's Avatar
1369
10,479
2006 325xi  [0.00]
If all connections are good (no air leaks) then the MAF is reading to much air mixture causing CEL.
I have seen alot of this (bsm intake) cel issues.
2006 325xi (Sold)
      07-21-2014, 10:54 AM   #19
Boxman911
Boxman911's Avatar
United Kingdom
12
60
Drives: 2014 M235i
Reading this is really putting me off buying a jb4. It could however be possible there is a fault that is nothing to do with your upgrades. If you can't sort it out with the advice above then I would get it back to stock and take it to BMW.
      07-21-2014, 12:15 PM   #20
Ohio Army Man
14
147
Drives: 2014 M235i
Warning to all....
Turbo pressure sensor bad...
      07-21-2014, 12:29 PM   #21
ska///235i
***** noob
ska///235i's Avatar
1369
10,479
2006 325xi  [0.00]
Warning to all....
No expert but i think the intake prbly allow to much hot air and trigger the sensor
This is why i dont like hot air intakes on turbo cars
2006 325xi (Sold)
      07-21-2014, 12:47 PM   #22
Delnari
Delnari's Avatar
256
1,040
Sounds like you need to leave everything stock; which you said you did. Double check all you sensors.wires are connected properly; reseat them. Try clearing the codes again. If same code comes up then you will need to take it to BMW for diagnostic check. Be prepared get charged for the repair work.
2addicts
