07-30-2021, 07:45 PM | #1 |
Rep 2
E32 wheel compatibility with other models
I have a 1988 735i and struggle to find wheels for it. Can I broaden my search to e34 or e38 wheels? Would they fit?
07-30-2021, 11:25 PM | #2 |
83
Rep 106
Jacksonavenue6.00 |
07-31-2021, 07:01 AM | #3 |
BMW Owner Since 1971
2269
Rep 1,416
Drives: 1964 700 Sport Cabriolet
Just check the offset. Any E39 wheel will require a 2mm spacer for the hub (inexpensive).
07-31-2021, 11:36 PM | #4 |
2163
Rep 4,109
08-01-2021, 08:32 AM | #5 |
2269
Rep 1,416
They will fit just fine if you purchase a cheap set of (aluminum) spacer rings to fit over the hub-centric location. I have E39 wheels on two E28s and have had them for years. I also own two E39s so I understand the issues. Thanks for your contribution.
08-02-2021, 01:13 AM | #6 | |
Rep 2
08-02-2021, 01:19 AM | #7 | |
2163
Rep 4,109
But everyone is different I guess. |
08-02-2021, 04:39 PM | #8 | |
1368
Rep 1,532
OP--I don't know the offset range for e32 specifically, but you can use a variety of options as long as it's a 5x120 and has similar offsets. I have e31 turbines on my e34, it's a 5mm lower offset and looks good. Edit: looked it up an e32 is typically around a 7" width and 20mm offset. Anything close to that will work. You can use a calculator like willtheyfit.com to visualize the differences between your stock wheels and potential replacements.
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6 |
08-03-2021, 07:54 PM | #9 | |
2163
Rep 4,109
You can have every wheel technically redrilled but than again... what's the point? Plenty E34 wheels out there which are plug and play for the E32. |
08-07-2021, 09:08 AM | #10 |
Rep 4
I agree with you
I did agree with this point of yours.It ll fit with a set of aluminum spacer rings to fit over the hub-centric location.
12-26-2023, 07:05 PM | #11 |
Rep 8
Drives: 2019 G12 740i M-Sport ;'13 M6
I fit a set of X3 wheels to the E32. I did have to put spacers to correct the backspacing, but I think they compliment the car nicely as if they could have come with the car. I don't have any rubbing issues and the car rides nicely as if it were on stock wheels and tires.
12-27-2023, 07:26 AM | #12 |
4097
Rep 3,212
12-27-2023, 09:40 AM | #13 |
2100
Rep 1,487
Here's a e32 with 16" E38 style 5's, they are cheap and plentiful and tire sizes give a nice ride.
