11-22-2023, 08:36 PM | #23 | |
1423
Rep 1,098
Drives: 2022 M8cs
M8C F9240.50 |
11-22-2023, 08:41 PM | #24 |
41
Rep 25
I did the RK Autowerks engine build which upgraded the rods and bearings. I have been happy with the engine build so far.
Dr Thrillride1422.50 |
11-23-2023, 12:24 AM | #25 |
417
Rep 89
Drives: x7 and M8GC
I’ve been on a stage 3 custom tune I did on my own for the past few months now. Motor isn’t built, stock internals. So far I haven’t noticed any issues with it. Took me a minute to really narrow down the settings between the shift speeds and throttle blips but finally at an enjoyable setting for daily use while having the quickness between gear shifts. Only thing I will say is the up shifts are pretty fast and most noticeable during the flash.
Stage 3 Settings I have activated on XHP: Throttle blip Kick down Torque Reduction Upshifts Take off on 2nd Gear as standard Active Lin bump Stop n go Have not touched any of the torque limiters and don’t plan to. Hope that helps. |
M8C F9240.50 |
11-23-2023, 07:51 AM | #28 | |
41
Rep 25
11-24-2023, 12:45 AM | #30 | |
417
Rep 89
Drives: x7 and M8GC
Yes, for both 0-60 and 60/130, I noticed gains. Just don’t have a draggy report of it yet. Waiting to see my buddy who has the gps module to compare stats.
M8C F9240.50 |
11-24-2023, 12:49 AM | #31 |
417
Rep 89
Drives: x7 and M8GC
11-25-2023, 12:16 PM | #33 | |
786
Rep 453
M8C F9240.50 Dr Thrillride1422.50 |
11-27-2023, 07:44 AM | #35 |
14
Rep 51
Drives: e63 650i, F10 535i, E93 335i
I have used xHP on several of my BMWs, E93, F10, E63, and now on my M850ix GC. I have been really impressed with all the tunes I have ran. I can't give much evaluation on the M850i because I put the tune on within 3 days of buying it. I trust the brand enough that I blindly put it on the G16 without reading any reviews and no disappointment here.
2012 535i M-Sport PWG, Wagner FMIC, VSRF no meow, chargepipe, Walbro 450 with custom fuel lines, MHD map e30 2+, JB4 (monitor and logging only now), xHP Stage 3, K&N drop-in, Paddleshift retrofit
11-28-2023, 12:35 PM | #36 |
417
Rep 89
Drives: x7 and M8GC
Correction. Gears 2 to 8 is 1000nm, not 1200nm. But gear 1 is 800nm. Across all 3 stages regardless of versions. Had to dig up an old email.
12-13-2023, 07:35 AM | #37 |
114
Rep 282
I just got the maps and license along with the wireless xHP adaptor.
I am however unable to get a WiFi signal from the xHP blue adaptor. Plug it in, get the car in ignition on mode and nothing after 5 minutes several attempts. I have been using my digital key (phone) and not sure if that has something to do with it. Wil.try with a physical key next and see. |
12-14-2023, 07:17 AM | #38 | |
114
Rep 282
I am using a Google pixel and ran into a weird issue. It's not picking up the WiFi signal being broadcasted by the xHP wireless adapter. Nothing shows up on there. Wondering if you can share what the WiFi signal is called when the xHP blue adapter is connected to the car? Thanks for your help, will pm as well. |
