02-21-2024, 01:31 AM | #1 |
50
Rep 32
Mix PZero and PS4S on M8C
My front tires need a swap. I have PZeros on the car (came with it) and unfortunately i replaced the back tires last season and forgot to make sure they change to PS4S (should have changed all 4 to PS4S then).
Will it hurt the car (M8C - xdrive wise) when i put PS4S on the front and keep the PZeros on the back? |
02-22-2024, 02:34 AM | #2 |
1290
Rep 1,658
Not advisable to mix
maechthildt49.50 |
02-22-2024, 09:03 AM | #3 |
19364
Rep 10,166
I have zero experience on mixed tires but Im sure the different tread patterns even with AWD will drive you a bit crazy over the road as each set will grab the grooves of the road differently.
02-22-2024, 04:43 PM | #4 |
250
Rep 268
From a diff perspective you should be alright if you’re the same left to right so no issue with xdrive. Front to back will probably just be annoying as mentioned. Maybe even a harmonic distortion with road noise mixing between the two sets and odd handling.
