06-05-2023, 10:48 AM | #23 |
4539
Rep 3,507
Well at least you not trolling.... anything before 23 is pre LCI and anything mid 20 is locked sadly. But they do offer for all a piggy.
2022 M8 Comp Convertible
06-05-2023, 07:35 PM | #24 |
1399
Rep 1,070
Drives: 2022 M8cs
I just know a bit and definitely no expert. I didn’t decipher what the OP posted. I’ll leave the expert Dasky to help out.
06-06-2023, 06:45 AM | #25 | |
175
Rep 125
I will add that even though my car is a 2019 the DMEs were locked . Carbahn decent little difference from stock but to me isn't worth much. Mine has been E30 tuned for 1 year. 0 issues and night and day from Carbahn or RC. The first 2.5 gears are conservative to stay safe. Top of 3rd the turbos come alive. |
Chris415-M850I24.00 |
06-06-2023, 06:48 AM | #26 | |
175
Rep 125
Here's my last 1/4 mile pass. https://youtu.be/A95bdIX6yCU |
06-06-2023, 10:56 AM | #27 | |
4425
Rep 4,109
Based on your video, I'd estimate you're losing 0.05 of a second every shift relative to a full-blooded M which accounts for ~0.2 to 0.25 seconds by the time you hit the 1/4 mile--have you considered getting a transmission tune, too (assuming one is offered for the M850)? You'd be down in the low 10s if you could get that ZF to shift more quickly. |
Draxxas175.00 |
06-06-2023, 11:23 AM | #28 |
175
Rep 125
I've tried every possible way to launch harder but my tires won't hold after 2k rpm . This was 1800 rpm. On the dragstrip ( Nicely prepped) Still spins with full Launch mode activated but not horrible unless I let it build boost. So within a sec after foot to the floor I release and it's pulled a 1.55 60ft. That was a 10.51 @133 and da that day was 2550 (80 degrees) . My tires are all season so definitely not ideal for hole shots. I just like the pulling power when merging onto highways 😊
It does have a tranny tune but can't tell you other than removing some torque limiters what it really does. First couple shifts I know are kind of slow but seems instant after. Guess the only way to have the M8 trany is to get the M8 ❤️😅 |
limeypride4425.00 Chris415-M850I24.00 |
06-06-2023, 11:00 PM | #29 | |
1399
Rep 1,070
Drives: 2022 M8cs
Chris415-M850I24.00 Draxxas175.00 |
06-07-2023, 12:28 AM | #30 |
24
Rep 25
Drives: 2019 Bmw M850i XDrive
Draxxas
What is e30 tune and where is it located ? How many miles have u put on it since U had it really impressed with 10:5 over 11:1 At carbahn tune SUPER IMPESSIVE 10:5 😍😍 |
06-09-2023, 03:26 PM | #31 |
175
Rep 125
I don't exactly understand your question. An E30 tune is taking a specific amount of E85 and mixing it with 93 octane to come up with an E30 mixture. For example 6 gallons of 93 octane with a 3 gallons of E85 will roughly be your E30 mix. There's an app or apps for this calculation but you also need to know what the E85 measures at because it can be anywhere from e70 to E90. I've had the tune for over a year now and probably put 15,000 miles on it.
06-09-2023, 06:43 PM | #32 |
24
Rep 25
Ok great that makes a lot of scence
What kind of. Tune do my you have ? I am following some 1 with a carbahn tune Stage 1 and he’s running 11:1 in quater Miles I def prefer a 10:5 time ?? Draxxas |
Draxxas175.00 |
06-09-2023, 07:59 PM | #33 |
24
Rep 25
Draxxas
What is the name of your tune ? |
06-11-2023, 12:31 PM | #34 | |
175
Rep 125
They were all smiles in that car. 😁 My entire setup was under 2500.00. It was done at Performance Eurowerks in Chicago Illinois. Love the fact that it would take an extremely fast car to beat me off a redlight. I can hit a 2.9-3.0 0-60 every time. |
06-11-2023, 12:35 PM | #35 |
24
Rep 25
Do you no what a carbahn tune
Runs in quater miles I Seen some 1 run a 11:1 with it But I wonder if u can get a a better run Then that I would perfer at lease To run a 10:90 in quater mile Also what kind of tires would you Recommend for drag strip Would I need just to change rear Are all for of them thanks again Draxxas |
06-11-2023, 12:49 PM | #36 | |
175
Rep 125
06-11-2023, 12:53 PM | #37 |
24
Rep 25
What is a real tune in bay area ca
Who would you recommen Draxxas |
06-11-2023, 12:56 PM | #38 |
175
Rep 125
06-12-2023, 09:24 AM | #39 |
175
Rep 125
06-16-2023, 09:22 AM | #40 |
175
Rep 125
Someone stole Chris 😳😳😳
snowbimmer5210.50 |
06-17-2023, 01:49 AM | #41 |
24
Rep 25
Lol I thought I replied I did not do it yet gonna do it next week got very busy but am going with carbahn most likely
Found a few different tunes but no Warranty scares me also gonna ad Down pipes xhp3 transmission Bms filters dinan turbo inter coolers And resernator delete with x pipe All happens soon will post when everything Is done don’t think I’ll run a 10:5 but I Think I’ll get in the 10:90 11:0 witch Is fine for me but u are the faster on The internet all over the world pretty sick Can’t lie !!! Draxxas |
Draxxas175.00 |
06-18-2023, 01:23 PM | #42 | |
140
Rep 524
I settled on the RK tunes. Going in a week or two. They do it in house, have results, and are able to modify their own tune whereas some of the other tunes are immutable and the results are a mystery or fall short of what is advertised. The Carbahn tune is shady simply due to them advertising a tune that applies to 2 different Motors. A 2018 m550 is not the same as a 19 or 20 m850i or the 2020 m550i. Something in their marketing doesn't add up and it doesn't seem wise to take a chance on their tune. |
