BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion 1/4 mile Track
      03-28-2023, 09:49 AM   #1
foma1
foma1's Avatar
69
58
Drives: BMW M8 coupe
1/4 mile Track
What’s up guys, wanted to see if anyone has hit the Track yet. I went for my 2nd time this past weekend. I found it very hard to Launch this car. Granted I have some work done and the more power the harder it is especially in stock tires. I wanted to see if anyone else has hit the Track and if so what was the outcome. My best time was 11.00 but I know for sure the cars gonna go faster, because I’ve done far better on the streets with a Draggy. But getting out the hole is the key. I had 4 tries and I was spinning hard off the line or lots of wheel hopping. Can’t wait to go back, I think my car can do a very low 10 sec pass all day.
      03-28-2023, 09:58 AM   #2
Tenac
Tenac's Avatar
4540
3,507
Drives: All
A trick I've used in the past is have someone video tape one from each side of the track. Kinda shocked you are spinning on a track compared to a street though... I know some slip will keep the hop away but depending on the power you are putting down you might have to put different tires on for the track.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
foma169.00
      03-28-2023, 10:16 AM   #3
foma1
foma1's Avatar
69
58
So my car put down 749 whp so I may do a mild drag radial on the rear, I think I’m gonna grab 2 rear 18” wheels to put on the rear. I’m sure it will hook after that.
      03-28-2023, 10:22 AM   #4
Tenac
Tenac's Avatar
4540
3,507
Drives: All
I think that's a good start for sure.
2015 M235 Manual
      03-28-2023, 12:01 PM   #5
foma1
foma1's Avatar
69
58
You wouldn’t happen to know the smallest size wheel we can fit on our rears do you?
      03-28-2023, 12:22 PM   #6
Tenac
Tenac's Avatar
4540
3,507
Drives: All
sadly no, but if you have the ceramic's you might not be able to go past the 20"..... Might be worth a quick search on the forum.
2015 M235 Manual
      03-28-2023, 01:40 PM   #7
bbradyc5
BMW Noob
369
196
Drives: 2020 BMW M8 Comp
With CCB’s you can’t go any smaller than 20”. I plan on spec’ing out a small brake conversion setup on the rear that will allow me to run as small as a 17” wheel out back
      03-28-2023, 01:52 PM   #8
Dr Thrillride
1399
1,070
Drives: 2022 M8cs
I have CCBs and Apex 19s all round.
Tenac4539.50
foma169.00
      03-28-2023, 02:06 PM   #9
bbradyc5
BMW Noob
369
196
Oh man I’m so curious how those fit. Looking at rears I originally thought I’d be able to put a 19” on there but it looks like almost zero clearance with the 20” 706M (winter setup) wheels i have in there now. Can you shoot me exact wheel model/spec you have out back?
Ben
      03-28-2023, 02:34 PM   #10
Bulent Ali
Turkey
161
200
Drives: M8 competition coupe
10.8 seconds is the fastest stock it will do1/4
      03-28-2023, 02:38 PM   #11
foma1
foma1's Avatar
69
58
I agree, but I’m not stock. 749 wheel
      03-28-2023, 04:33 PM   #12
Bulent Ali
Turkey
161
200
The S63 engine can take alot of power tune but the transmission can't take the same amount . If you can achieve under 10 seconds , that will be impressive. Hit sticky tires may do the trick . Mind the transmission 🙏
      03-28-2023, 05:08 PM   #13
Tenac
Tenac's Avatar
4540
3,507
Drives: All
I don't think he is anywhere near that worry, Friedrichshafen AG says the transmission in stock is good to 770ish ftlbs and that is probably playing it somewhat safe (that considers the ability to launch the M8). Though I think what would keep him back from under 10's will be the midrange, the M8 is terrible here mostly due to weight and gearing.
2015 M235 Manual
      03-28-2023, 11:19 PM   #14
downeykp
117
104
Drives: 22 M8 coupe 2019 Colorado ZR2
Try lowering tire pressure to maybe 20psi. More tread on the pavement = more traction.
      03-29-2023, 07:28 PM   #15
foma1
foma1's Avatar
69
58
Yes the Trans is definitely not the issue, launching the car is my problem. My 60ft sucks. I’m extremely confident that my car can get to high 9 with a good 60ft. I’ll post slips next time I go. I’m gonna order tires 1st, thinking Nitto 555R, my boys M3 made 1088 whp and those tires helped him hook up on a 9.09 pass… 1.57 60ft.
Tenac4539.50
      03-29-2023, 07:30 PM   #16
foma1
foma1's Avatar
69
58
I was at 26lbs, I think 20 is too low for a PS4, when I get my Drag Radials ill do 20lbs.
      03-29-2023, 07:33 PM   #17
foma1
foma1's Avatar
69
58
My best pass so far
      03-29-2023, 07:35 PM   #18
foma1
foma1's Avatar
69
58
Atco raceway
Appreciate 3
Tenac4539.50
kris1858555.00
      03-29-2023, 09:03 PM   #19
limeypride
limeypride's Avatar
4425
4,109
You’re not wrong, that 60ft does suck especially on prep’d.
What’s the mod list on your M8?
Your trap speed seems too low, though, if you’re looking for 9s in the future.
      03-29-2023, 09:09 PM   #20
foma1
foma1's Avatar
69
58
Yup, I have to get used to the car on the Track. I have Catless downpipes, project Gamma intakes, M performance exhaust, and a custom E30 Tune. 749 whp on a mustang Dyno
limeypride4425.00
      03-29-2023, 09:41 PM   #21
foma1
foma1's Avatar
69
58
I dnt have the CCB, do you know the smallest wheel and is there a rim or wheel size you recommend. I’m thinking 18X10 if it could fit.
      03-29-2023, 09:47 PM   #22
bbradyc5
BMW Noob
369
196
Dr Thrillride says he was able to fit APEX 19’s on with CCB so my assumption is that with non ceramic you likely should be able to fit 18’s but I’m guessing someone else on here could confirm who’s actually tried an 18” square setup
foma169.00
