BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion 1200 Mile Service for M8; Not M850i or Alpina B8
      01-12-2023, 04:51 PM   #1
dhoggm3
dhoggm3's Avatar
269
1,282
Drives: 850i C, Gated R8 5.2, E63
Can anyone tell me why this might be? I know the engines are slightly different, but why the mandatory 1200 mile service for the M8 and not for the B8 (or M850i either)??
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune
Alpina B8, zero performance mods
      01-12-2023, 05:16 PM   #2
Tenac
Tenac's Avatar
4540
3,507
Drives: All
This topic is so deeply covered in many many threads across all of the models. The bottom line is with the M engines the level of tolerance is much tighter on metal to metal surfaces. The metal itself is NOT the same alloy found in similar models. This can be due to many factors but some being simply weight and strength to withstand the forces from the M line and what it's target market of say track goers. That said the Oil they dispatch from factory with M models has a very high level of zinc and does not withstand typical punishment from daily driving or track use. It is used to ensure metal to metal surfaces blueprint to each other without getting over worked and to stay clean. Zinc is one of the best additives to help an engine be slippery and when in high levels the metal absorption is better. Issue with zinc in oil is if left in too long or under too much stress it turns to ash and can clog oil ways and ports easily. Hence the break in period and why BMW is strict on it.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
Appreciate 14
Vic5519365.00
TheGreatM82174.50
Volcanic168.00
jargon194.50
hinckley3492.50
dhoggm3268.50
AP2783.00
JRHolt39.00
      01-13-2023, 06:30 AM   #3
dhoggm3
dhoggm3's Avatar
269
1,282
Awesome explanation. Thank you.
      01-13-2023, 10:20 AM   #4
Twinturbostroker
65
34
Drives: M8C & 335is
Schools out..
Thank you for taking the time with these details.
BMW serviced the differential on my 1200 mile break in. SA had the oil set aside for my break-in service appointment and another tech used it. Turned into a little drama at the dealership, which ended with the tech whom procured the differential fluid for my service driving to the another county 50 miles away in order to restock the fluid to complete the break-in service on mine.
      01-13-2023, 10:26 AM   #5
Tenac
Tenac's Avatar
4540
3,507
Drives: All
Originally Posted by Twinturbostroker View Post
Schools out..
ooof that is a bummer but at least they worked to make it right.
2015 M235 Manual
      01-14-2023, 12:32 AM   #6
M8CompSoCal
M8CompSoCal's Avatar
303
187
Drives: 2023 M8 Competion Coupe
I’m 5 weeks into ownership and have 335 miles. I just want to get past the break in haha…
      01-14-2023, 08:59 AM   #7
snowbimmer
snowbimmer's Avatar
5223
1,799
2022 M850 GC  [10.00]
335 miles???
Man, that's just a Thursday afternoon......
Appreciate 3
sullic72.00
Accentu8703.50
M8Bimmer1272.50
      01-14-2023, 10:12 AM   #8
M8CompSoCal
303
187
Originally Posted by snowbimmer View Post
335 miles???
Yeah I know… I guess I don’t do much driving.
snowbimmer5222.50
      07-09-2023, 10:03 PM   #9
Tenac
Tenac's Avatar
4540
3,507
Drives: All
Originally Posted by NauM View Post
So I heard a bmw tech say that alpinas come broken in from factory is that true. Just picked mine up and I want to know cause it doesn’t require the 1200 miles break in service.
Most of the none S series motors from BMW do not come with a standard break in of 1200 miles.. The wife's X3 M40i doesn't but her X3M did. They are not ran in at factory as in operationally but they have much more loose tolerances and standard oil. Meaning lower ZINC levels, so that oil holds to up to the typical daily use. Double check the owners manual or feel free to get a oil change at the 3k mark if it makes you feel better about it. Honestly that is what I do with any car that does not require a procedure.
2015 M235 Manual
NauM0.00
