BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion Battery not charging?
      03-13-2024, 02:50 PM   #1
twinrink
21
47
Drives: BMW 530i xdrive
Hi
I got M850 and last week i swapped the trunk main battery for new one and registered via bimmerlink.
Driving the car daily for 20 miles and today few days later there is message battery low.
Seems the car is not charging.The small battery in engine bay wasn’t changed.
What can be wrong?
The IBS sensor is bad?
Alternator?
      03-13-2024, 03:19 PM   #2
Hornethandler
26
22
Drives: 2023 M850i; 2019 MB SL450
Can you put a voltmeter on the charging posts under the hood and measure the charging voltage?
      03-13-2024, 03:25 PM   #3
twinrink
21
47
Charging voltage with engine on?
      03-13-2024, 07:24 PM   #4
Hornethandler
26
22
Yes. The engine needs to be running for the alternator to supply charging power to the battery. The voltage measured at the jump posts should be between 13/14 volts DC.
      03-13-2024, 07:55 PM   #5
twinrink
21
47
While engine is running it is reading 12.2 Volts
Either alternator or ?
      03-13-2024, 08:15 PM   #6
Tenac
Tenac's Avatar
4539
3,507
Drives: All
If there are no devices between your measure points and the alternator its the alternator...
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
      03-14-2024, 06:25 AM   #7
Hornethandler
26
22
Agreed. I suspect there's some sort of protection device (fuse) between the alternator and battery, so I'd start looking there first.
If at all possible, measure directly at the alternator, or at some point (connector) before the battery. In other words, chase the voltage back to the alternator.
Tenac4538.50
      03-14-2024, 09:19 AM   #8
Tenac
Tenac's Avatar
4539
3,507
Drives: All
The controller that alters the voltage should be in the rear of the car along with the starting battery. So like you said if you can get to either before that where the alt comes in first or the back of the alt would be best.
2015 M235 Manual
      03-14-2024, 10:42 AM   #9
twinrink
21
47
I’ll try to measure by alternator but it is difficult to reach.
Other suspicious place would be IBS sending wrong data
      03-14-2024, 02:12 PM   #10
Tenac
Tenac's Avatar
4539
3,507
Drives: All
Something you should also try, car not running measure battery voltage. Then start the car measure again it will rise to 13-14v.
2015 M235 Manual
