12-18-2020, 11:39 PM | #1 |
1604
Rep 2,937
tire size
In the M850i the 20" p zero are stock tires.
245/35R20 and 275/30R20. I know people put 21" and lowering springs, so I'm guessing stock - you can probably gain an fraction sidewalls? Does anyone know if 245/40-20 and 275/35-20 will run without problems? |
12-19-2020, 12:52 AM | #2 |
605
Rep 909
As far as the variance goes (40 vs 35 on FRONT and 35 vs. 30 on REAR), below are the results.
FRONT Will fill out the wheelwell by extra 12 mm. Acceptable for most cars Negative scrub radius (about -4 mm). Almost no difference. Please be aware that calculated value is approximate. When speedometer reads 60 km/h actual speed will be 62.2 km/h REAR Will fill out the wheelwell by extra 14 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims Negative scrub radius (about -5 mm). Scrub radius will be changed by -5 mm, this may affect the car's handling. Please check manufacturer recommendations. Please be aware that calculated value is approximate. When speedometer reads 60 km/h actual speed will be 62.5 km/h I usually turn to this site it's very precise and you get the decisive values and parameters in regard to variance between stock and the desired setup: https://www.wheel-size.com/calc/ Also consider there will be added weight as well. Technically you can drive it and should not have any issues as scrub radious is minimum and many cars (setup) come with a slight negative scrub radius already. Though, I'd ask a professional tire/car shop just to be 100% on the safe side before installing. |
Slack Beries41.00 bloozemanAZ4275.50 |
12-19-2020, 09:28 AM | #3 | |
1604
Rep 2,937
FBMWWINS604.50 bloozemanAZ4275.50 |
09-11-2021, 07:26 AM | #4 |
118
Rep 449
Did you try this setup?
Current BMWs;'18 M2, '20 R1250GS Adventure
Past BMWs;'22M850 Conv, '19 SG M5(ED 5/19),14 Ionic Silver i3, '16 S1000XR, '16 Azurite Black M5, '07 G650X-Challenge, '10 R1200GSA, '15 Mineral Gray M4, '14 S1000R,'10 Alpine White 135ia M-Sport, '13 Carbon Black X5 50i, '10 Carbon Black M5, '07 Graphite K1200GT, '08 335ia, '05 545i, '04 R1150R, '03.5 M3 Cabrio, '00 540ia, '97 M3 sedan, '97 540ia |
09-11-2021, 12:43 PM | #5 |
1604
Rep 2,937
BeamerandBimmer117.50 bloozemanAZ4275.50 |
09-11-2021, 02:56 PM | #6 |
131
Rep 320
This is a genuine question, apologies if I seem dumb, what's the benefit of running oversized tyres? Have the wrong speedo reading would drive me OCD crackers but I obviously don't get the whole picture.
Now- 2021 G16 840i
Last- 2017 G30 530d Prev- 2013 F30 330d |
09-11-2021, 07:06 PM | #7 |
1604
Rep 2,937
Looks. It looks like you put lowering springs or bigger wheels on it. Gives the appearance of a full wheel well. 21" vs 20" tires.
09-12-2021, 02:48 PM | #8 |
56
Rep 82
09-13-2021, 10:30 AM | #10 |
1918
Rep 2,010
Drives: 2022 i4 M50
Don't worry, it's wrong anyway. I think there's something like a 5% tolerance. You could also tell iDrive you have a bigger wheel to try to offset the bigger tire, but I believe you're getting some free miles on the odometer if you don't as well.
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
Resjudicata1604.00 bloozemanAZ4275.50 |
11-16-2021, 12:09 AM | #11 |
546
Rep 456
Debating going 21" or 20" with bigger tires. I know you decided to go with the bigger tire option, any pics?
Resjudicata1604.00 |
11-16-2021, 05:00 PM | #12 |
136
Rep 115
Also, if you live in a pothole town, the larger sidewall protects the rim a bit more from damage.
11-17-2021, 01:48 AM | #13 |
Rep 8
11-17-2021, 08:36 AM | #14 |
253
Rep 270
I feel like if I squint really hard when I hit a big pothole, it prevents the tire/wheel from getting damaged 😅
11-17-2021, 08:49 AM | #15 |
4552
Rep 3,515
Way better to lift your feet off the pedals and floor and pinch real tight.
2022 M8 Comp Convertible
01-21-2023, 09:02 AM | #17 |
705
Rep 245
Drives: MY24 Porsche Taycan
I still have stock 20” wheels, but replaced the stock run flat summers with Continental ExtremeContact DWS06+ with 40 front/35 rear sidewalls. Looks a lot better, rides better and is much quieter. No decrease in handling. Had the setup for 10 days.
MY24 Porsche Taycan | Neptune blue | Black |
MY24 Audi SQ5 Prestige | Mythos black metallic | Magma red Nappa Retired: MY23 BMW 840i Coupe | MY21 Audi SQ5 | MY19 Audi A6 |
01-22-2023, 03:11 PM | #18 |
705
Rep 245
Better shot I did today. After her first foam bath and wax.
01-22-2023, 03:25 PM | #19 |
4276
Rep 4,352
Excellent and as previously stated my next go to when the new set of P Zeros run their course. Always ran Continentals on my prior sport sedans with all the grip needed for every day plus spirited driving. Plus throw in the extra tread life and a total win-win.
Accentu8705.00 |
01-22-2023, 03:30 PM | #20 |
4276
Rep 4,352
Hit one yesterday in an unknown areas of town which was more of a crack in the street vs a pothole so didn't see it until too late. Friend in the car with me got an ear full of WTF and a couple of further rants. He has no clue what a pothole can do on 20" rims with little rubber between them and the road.
01-22-2023, 03:33 PM | #21 |
4276
Rep 4,352
Which brings up a point from older threads in which oversized tires caused issues with X drive and the dealers not wanting to cover the drive train issues due to that. Is this setup of sizing immune to that?
01-22-2023, 04:06 PM | #22 |
271
Rep 189
Did you bend a rim? The upsize in tire has been no issue from my dealership (bmw of Manhattan) they did it for me and suggested it.
snowbimmer5269.00 Accentu8705.00 |
