11-28-2023, 03:44 PM | #45 |
15
Rep 39
+38 is what I would recommend with an 11". It's what I have with no poke.
11-28-2023, 03:57 PM | #46 | |
15
Rep 39
I do not get any Poke. I can only deal with that on my truck. LOL The offset is +38. on my summer set. My winter set is +45. Those rims are a half inch less width. Last edited by ElloM8; 11-28-2023 at 04:06 PM.. |
11-28-2023, 04:03 PM | #47 | |
15
Rep 39
I love the 22"s for the summer but they are trash at high speed. They run perfect up to 100MPH. Start to vibrate at any speed above that. Now that I have the stage 1 tune and the speed restrictor removed I can run it with my winter tires a little better. |
11-28-2023, 08:41 PM | #48 |
140
Rep 524
I should have specified, 11" rears on the m850. The M8 has shorter rear axles so less offset is needed. I was thinking 20x11 et 47. That should put it flush but unsure about the inside rubbing.
11-30-2023, 07:22 PM | #51 |
140
Rep 524
That 40 offset seems off. By flush, do you mean popping out a bit? The way I figured was a 47 offset to be flush. I run a 9.5 with 28 offset now and it's flush. I'm using that as the reference.
12-02-2023, 11:23 AM | #52 |
15
Rep 39
Any chance you could post a pic of that? I'm not sure my idea of "flush" is the same as yours. I'm not trying to be a prick, I'm honestly curious. The fact that you got a 275/30 on a 9.5" rim & an of ET21 up front without any poke is shocking. The M850 is not forgiving.
12-07-2023, 01:59 AM | #54 |
29
Rep 65
Sorry forgot to mention it is an M8.
By flush I mean not popping out like how it should look from the dealer, like it is meant to be like that (factory/oem), otherwise normal vs an aggressive stance popping out or it being in, which looks off. Yeah, it is dropped on h&r springs 1.3" all around. no rubbing when fully locked, or so little it doesn't affect anything. however, the rubbing to be considered with is the front lip because it catches on everything and not just driveways but even dips or pretty much any time you are not at a 0 degree even flatness lol. I have to take driveways super slanted and still sometimes hear it scratch. Yeah, I can post some pics soon, haven't taken any yet. |
ElloM815.00 |
12-07-2023, 10:45 PM | #55 | |
233
Rep 93
02-11-2024, 05:33 PM | #56 |
140
Rep 524
I just placed my custom forged wheels order, crossing my fingers these offsets are correct!
For the m850, with m8 front fenders, I went with: 20x10, et 20 for 295/30/20 20x10.5 et 41 for 305/30/20 Should fit flush, especially when lowered. I'm running KW V3 so once the wheels are on, I can lower it another .5" in front, and .3" in rear. I really like Carbahn's M8 look and stance, that was my inspo. |
