11-25-2020, 06:00 PM | #1 |
114
Rep 84
H&R Springs Issue
Just received my H&R springs for my M8 coupe, but I think the set was mismatched. I received 2x 28686-2 (front) and 2x 28686-1 (rear). The part number ending in -1 is supposed to be F90 M5. Before I start disassembling my suspension, just wanted to make sure I received the right parts. Thanks!
11-25-2020, 06:23 PM | #2 | |
19355
Rep 10,166
You must have received a bad batch or a poorly restocked box.
11-25-2020, 08:47 PM | #3 | |
114
Rep 84
11-26-2020, 08:30 PM | #4 | ||
///M
133
Rep 184
Drives: M8C/Taycan Turbo/Roadster 2.0
Also I just noticed Vic55 you flipped it around. We have the -1 part for the REAR not the FRONT. Last edited by Jenner; 11-27-2020 at 04:50 PM.. |
11-27-2020, 12:33 PM | #5 | |
114
Rep 84
If anybody else has had the same issue, please chime in. |
11-27-2020, 02:37 PM | #7 | |
///M
133
Rep 184
11-27-2020, 02:54 PM | #8 |
///M
133
Rep 184
I found this on the H&R website:
WHY DO THE H&R PART NUMBERS ON THE SPRING BOX NOT MATCH WHAT IS ON THE SPRINGS? The part number on the box is the product part number. The part number on the springs is a component part number. If you would like to verify your product/component part numbers, please call H&R at (888) 827-8881. Please have the following information available: year, make, and model of the vehicle application, the product part number found on the box, and the individual spring component part numbers. http://www.hrsprings.com/technical |
11-30-2020, 10:26 AM | #9 |
114
Rep 84
Turns out we have the correct springs after all. From H&R:
Thank you for contacting H&R regarding your spring set. I apologize you were not able to get ahold of anyone. We were closed for the long weekend for Thanksgiving. The kit 28686-2 is the kit number. Our kits are comprised of individual springs, which do not always match the kit number. http://www.hrsprings.com/technical WHY DO THE H&R PART NUMBERS ON THE SPRING BOX NOT MATCH WHAT IS ON THE SPRINGS? The part number on the box is the product part number. The part number on the springs is a component part number. If you would like to verify your product/component part numbers, please call H&R at (888) 827-8881. Please have the following information available: year, make, and model of the vehicle application, the product part number found on the box, and the individual spring component part numbers. I have looked into the build for 28686-2 and you do have the correct springs. Best Regards / Mit freundlichen Grüßen Jake Tuttle Sales, Social Media & Technical Support H&R Special Springs, LP. 4108 Bakerview Spur Bellingham, WA 98226 Office: 360 738 8881 Fax: 360 738 8889 |
11-30-2020, 10:30 AM | #10 | |
19355
Rep 10,166
11-30-2020, 10:40 AM | #11 |
114
Rep 84
There have been a couple forum members that have posted their drop with this kit. I'll install and snap pics once my spacers arrive from IND this week.
12-01-2020, 09:31 AM | #12 | |
19355
Rep 10,166
Let me know what you find out and apologies for being the guinea pig here since I dont have the car yet.
12-01-2020, 01:26 PM | #13 | |
114
Rep 84
Unless I'm mistaken, both of these are on the same H&R springs: https://f92.bimmerpost.com/forums/sh...22&postcount=8 https://f92.bimmerpost.com/forums/sh...2&postcount=30 Last edited by brzn; 12-01-2020 at 01:53 PM.. |
12-01-2020, 01:36 PM | #14 | |
///M
133
Rep 184
The H&R website does not list any available parts for the M8 Coupe or M8 Grand Coupe. They list spring parts available for: M8 Convertible F91 and M8 Competition Convertible F91 (note that when you select the M8 Competition from the drop down the only chassis listed is F91) Check for yourself: http://www.hrsprings.com/application...s/4/2329/2020/ Clearly they will work based on others on the forums installing them on coupes, but they may not be optimized for the F92 which is why they don't list them. Last edited by Jenner; 12-01-2020 at 02:01 PM.. |
12-01-2020, 01:48 PM | #15 | |
114
Rep 84
Nevertheless, I have just come across an F92 M8 specific part #, although it isn't listed on H&R's website or sold in the US - 28686-3. Looks like they provide a 20mm drop at all 4 corners: https://www.tuningblog.eu/en/kategor...-coupe-303310/ |
12-01-2020, 01:58 PM | #16 | |
///M
133
Rep 184
I went to their German website: h-r.com/de and it shows up as the correct part number for the F92 coupe: Item No. 28686-3 BMW M8 F8CM Coupe (4WD) Lowering VA 20 mm Lowering HA 20 mm Comments only with adaptive damper control / only with adapt. damper control, incl. competition / incl. Competition Looks like it just came out a month or so ago. According to their website (as well as the article you linked) only 20mm or 0.75" drop front and rear. For some reason the F91 is listed as 30mm or 1.2" drop but this is probably a typo on the convertible. |
12-01-2020, 02:02 PM | #17 |
114
Rep 84
And an update on the 28686-3 from H&R:
Thank you for bringing that to my attention. That kit is what would be used for the F92 M8 Competition Coupe. We are working on bringing that spring set over from Germany to offer in the US. Our current listings as you know, are just for the competition convertible. I do not have a time frame for the kit to be offered, but I would hope early into the new year. |
12-01-2020, 02:04 PM | #18 |
///M
133
Rep 184
So now that we finally have this drama resolved (you got me all concerned when I had the correct parts all along!) what will you do with your springs?
12-01-2020, 02:24 PM | #19 |
114
Rep 84
I'll install the F91 springs I received for now. Will revisit getting the correct springs on in the future, if I end up keeping the car long enough.
12-03-2020, 12:32 AM | #20 |
114
Rep 84
Got the springs installed today... seems to ride just like stock, even at triple digit speeds. The front looks great - hoping the rears settle a bit more. Just waiting on my spacers to get in now.
IND-Distribution9585.50 mgod483.50 |
12-03-2020, 07:06 AM | #21 |
///M
133
Rep 184
Interesting rake, hope the rear is lower on my convertible. Thanks for the pics!
12-03-2020, 10:34 AM | #22 |
19355
Rep 10,166
It appears that the convertible springs are just that for the vert with the heavier fat rear.
Still looks good but can you show some more closeups of the rear?
