06-01-2014, 05:09 PM | #1 | |
Retired BMW Genius
2888
Rep 3,404
2015 Ford Mustang Gains 300 Pounds Over Outgoing Model
06-01-2014, 07:06 PM | #2 |
1112
Rep 12,442
There's a 15+ page thread on Mustang6G.com. To summarize:
1) Ford has not released any official specs for weight or power output. 2) There was an interview back in 2010 where a Ford engineer was hoping to shave close to 90kg from the outgoing S197, but that was back in 2010. Coupled with completely misleading rumors from the likes of publications such as [the now defunct] Edmund's Insideline that the S550 platform would be about 1.5ft shorter in length, the community has assumed that there would be a 200-300 pound reduction in curb weight. The S550 is actually very close dimensionally compared to the S197; lower, similar length, and wider in the rear. 3) IRS does NOT add 200-300 pounds, contrary to what a bunch of ignorant people tend to post. For some reason, there is frequent referencing of the '03 Cobra's switch from a solid rear axle to IRS as the reason why it weighed an extra few hundred pounds more than the vanilla GT. What people don't take into account is that it had beefed up running gear and things like a supercharger, which will add significant weight. The IRS in the 2015 is an integral link type, unlike the "control blade" suspension in the Cobra. It's also much more aluminum-intensive, and should realistically add no more than ~100 pounds from the outgoing SRA. 4) What does need to be taken into consideration are the updated regulations that the S550 has to meet; particularly the safety standards for both US and EU markets. Structural reinforcement and the four additional airbags is not something that's easily overcome, despite heavy use of aluminum in the hood, front fenders, and (I think) trunk lid. 5) Steeda didn't give us specific weight figures, nor did they strap it to a dyno and give us WHP/TQ numbers, which should be as easy as 1-2-3 for them. Why be vague with something as important as this if they know the answer? If anything they have pre-production models. Not that weight should change significantly with a greenlit production model, but still. 6) Some have made good points coming up with ideas as to why Steeda would do something like this, which would throw out any likely NDAs. Maybe they're anchoring the weight at something that's initially shocking, so that Ford can come out and announce a marginal weight gain. This way it makes a much softer blow and doesn't completely disappoint the large crowd that was expecting a weight loss. 7) There has been a clear statement from a Ford rep that the S550 GT with a PP outrunning a Boss 302. That could mean anything, but what we can infer is that such a weight gain like this rumor would make it extremely difficult to meet that initial claim. Food for thought. 8) The C7 is 100 pounds heavier but far better in (I think) every parameter compared to the C6. Chassis stiffness/rigidity and powertrain tech is extremely important nowadays. If weight has gone up, is it in the right areas? How about unsprung weight? There's a lot to think about with these latest batch of rumors. We should just wait for Ford to release the full sheet of numbers, and, most importantly, wait for real world testing and eval.
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
06-01-2014, 07:16 PM | #3 |
I am Gundam
186
Rep 1,211
This will be interesting if true once the Camaro switches to Alpha. Though wonder where GM is cutting costs to cheapen the platform for the Camaro....
I'm also not sure on if the 6th gen Camaro is Alpha (ATS) or Alpha+ (CTS) based. |
06-05-2014, 09:41 PM | #4 |
One cam is enough
130
Rep 6,801
The rumors were dumb to believe. Brains are good for using, a weight loss like that would require extensive exotic materials. Then it's pushed upmarket and loses all its bang for the buck credibility. That would be pretty asinine.
06-06-2014, 09:40 AM | #5 |
146
Rep 1,201
This was a rumor. Confirmed an 'estimate' by morons at Steeda.
And the GM Alpha platform is still very heavy. (the base 4cyl ATS is still around 3500lbs)
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
06-06-2014, 09:59 AM | #6 | |
I am Gundam
186
Rep 1,211
ATS 2.0L= 3373 lb. ATS 3.6 V6= 3461 lb. 320i= 3295 lb. 328i=3410 lb. 335i=3555 lb. Only the 320i is lighter than the ATS equivalent. The weights listed are with the automatic transmission since GM doesn't state what the ATS 2.0T weighs with the optional stick. Last edited by quagmire; 06-06-2014 at 10:05 AM.. |
06-06-2014, 10:09 AM | #7 |
342
Rep 1,325
06-06-2014, 01:19 PM | #8 |
431
Rep 3,888
Too much of "German Engineering" Marketing. Cars cannot be light, if they have to fulfil all the customers "need" so as the regulations, which are for our safety (in most cases). The M3/M4 (F8X) has a weight loss compare to previous generation, but nowhere near as "advertised". The C Class (W205) lost weight, but a lot is tricky, like was the Cayman R (987). The 458 is way heavier than the given dry weight of 1380 kg. The Huracàn has a far better chassis than the outgoing Gallardo, a lot of use of exotic materials, yet is heavier than the Gallardo. Want a light car? Alfa Romeo 4C. But that car has nothing, so not a deal either for most. 100 kg more or less don't change a lot, for most.
Performance is more important than weight, but given the same performance, sure we'd all prefer the lighter car. |
06-06-2014, 02:11 PM | #10 | ||
146
Rep 1,201
I know for a fact that the 335i doesn't weigh that much (mine was 3390ish on the scales with a 1/4 tank of gas). Get your numbers from someplace else. The turbo 4banger ATS (the only one that actually matters in this discussion) weighs almost 3500lbs, I can see a completely stripped down version dipping under 3400, but it'd be a loud rattletrap. The V6 engine in the ATS probably weighs more than a LS3/LT1. Quote:
06-06-2014, 02:22 PM | #11 | |
15
Rep 432
06-06-2014, 03:17 PM | #12 | |||
I am Gundam
186
Rep 1,211
5 series: Overall length: 193.1" Width: 73.2" Wheelbase: 116.9" CTS: Overall length: 195.5" Width: 72.2" Wheelbase: 114.6" Are you going to call BS to those numbers and that you took a ruler to the 5 series and CTS? Quote:
06-06-2014, 05:49 PM | #13 |
15
Rep 432
European Unladen weight is the same as US curb weight, except it's 90% fuel capacity but also factors in the weight of the driver (68kg) and minor cargo (7kg).
06-06-2014, 06:12 PM | #14 | ||
I am Gundam
186
Rep 1,211
06-06-2014, 06:50 PM | #15 | |
BMW Fan
449
Rep 725
See here... http://www.caranddriver.com/comparis...e-specs-page-6 And here... http://www.caranddriver.com/comparis...e-specs-page-5 |
06-06-2014, 09:29 PM | #16 |
16948
Rep 18,580
Who gives a crap about weight. Most all reviews of the ATS and new CTS indicate the Cadillacs have superior chassis as compared to their BMW counterparts. I can personally vouch for the ATS.
06-12-2014, 07:33 PM | #17 | |
Retired BMW Genius
2888
Rep 3,404
The 2015 Mustang Gains Less Than A Hundred Pounds
06-12-2014, 11:50 PM | #19 |
17
Rep 493
Gained 300 lbs? Suddenly lost interest in this car. That is a significant increase in weight. They must be using the same materials Jag used to build the F-type....
06-13-2014, 12:10 AM | #20 |
1309
Rep 2,787
The fact that they are not advertising or touting weight loss, is sign the car has probably gained weight.
How much? Has yet to be seen. So much for the rumors from a year or two ago, that it was shrinking drastically in size and losing major lbs. |
06-13-2014, 01:47 AM | #21 | |
Convicted Felon
733
Rep 2,180
