06-15-2020, 07:13 PM | #67 | |
1284
Rep 1,648
FlorinQCK-2.50 |
06-15-2020, 07:14 PM | #68 | |
16
Rep 10
FlorinQCK-2.50 |
06-15-2020, 07:16 PM | #69 |
1284
Rep 1,648
One other thing, if the stop start is not disabled it may affect the AC especially at lower speeds!
FlorinQCK-2.50 |
06-15-2020, 07:23 PM | #70 | |
16
Rep 10
I always disable auto on/off on all my cars as it drives me nuts, but interesting that you have observed that. Thanks for the suggestion. This is my 7th Bimmer. The 2018 M5 never had any problems. I wonder whether they have just over complicated the entire operating system with the last version of iDrive? |
FlorinQCK-2.50 |
06-15-2020, 08:43 PM | #71 | |
1284
Rep 1,648
I do know if you reset everything via idrive it may just do the trick like it did for me...
FlorinQCK-2.50 |
06-15-2020, 08:45 PM | #72 |
1284
Rep 1,648
For those mentioning their build dates, it would be great to add it to your sig or info, as this certainly won't be the last time we all may need to reference/compare them.
FlorinQCK-2.50 |
06-16-2020, 06:58 PM | #73 |
135
Rep 139
Adding another data point for the M8 vs M850i on the AC. I've got a relatively early 2019 build M850iC and the AC is flawless. I've always felt BMW AC really sucks. My wife's LX570 blows super cold and the last 5 BMW's I've had never came close, until I got the M850iC. Long trips, short trips, 115 degrees, it just works. And I am also knocking on wood, double skipping over lines in the sidewalk, etc. I don’t want to jinx it either, first 'real' AC I've had in a BMW.
But my previous F90 M5 was terrible. It was 'within specifications' which means you are hot when it's over 95. Max AC would barely make a sheet of paper wiggle in front of the vents. My M4 was also really bad. Both would dim the cooling on engine load. I never had it shut off like the OP, but it wasn't great. I wonder if that is a common M car trait. Can't believe the components wouldn't be the same for an AC across the model line, but who knows. |
FlorinQCK-2.50 |
06-17-2020, 10:03 AM | #74 | ||
1599
Rep 2,935
06-17-2020, 07:26 PM | #76 |
1284
Rep 1,648
Glad to hear it and this makes sense. I still for the life of me can't understand why BMW replaced the OP's car so quickly w/o doing this type of thing, and now he's having the same issue again and with no resolution
FlorinQCK-2.50 |
06-17-2020, 09:56 PM | #77 | |
4260
Rep 4,327
FlorinQCK-2.50 |
06-17-2020, 10:06 PM | #78 | |
4260
Rep 4,327
FlorinQCK-2.50 |
06-22-2020, 09:47 AM | #80 |
Ring Leader of G8X Haters
25076
Rep 8,762
Looks like the 8-series is not the only car affected but possibly all V8 BMW's (I4/6's use different compressors).
https://g05.bimmerpost.com/forums/sh....php?t=1729657
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
06-22-2020, 08:43 PM | #81 |
1284
Rep 1,648
It will be interesting to see the extent of the serial numbers/production dates affected in the TSB issued, as according to that link apparently there was a bad batch of compressors in a recent production run. In addition, apparently the condenser needs to be replaced as well due to the possibility of the bad compressor displacing metal shavings into the condenser...I read there's also another part possibly needed and sure hope it's not the evaporator as they normally require dash removal.
This again mystifies me why BMW replaced the OP's new M8 with another new M8 which had the same issue...does BMW know what the F-they're doing?
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible Last edited by RJC-1; 06-22-2020 at 09:06 PM.. |
FlorinQCK-2.50 |
06-23-2020, 03:08 PM | #82 | |
105
Rep 45
redhot47fla762.50 FlorinQCK-2.50 |
06-23-2020, 11:18 PM | #83 | |
1284
Rep 1,648
FlorinQCK-2.50 |
06-25-2020, 01:23 PM | #84 |
812
Rep 810
So we got our car back today from a software update (now 03.2020.58). Remote view now works too
According to our SA, there is an issue with the 8 series with S63 engine where either the evaporator or condenser freezes up and then the AC stops cooling even though equipment is working and Compressor is good. According to him, there is a software fix coming to address this. The text reads a bit different but here it is... |
06-27-2020, 11:35 AM | #85 | |
20
Rep 52
This will save wasted repairs for parts that are not needed as well as not currently available. Plus hopefully speed up the time to resolve. Its hot out there!! 😁 |
FlorinQCK-2.50 |
07-03-2020, 11:34 AM | #87 |
812
Rep 810
So, even with their workaround procedure the AC isn't working reliably. It works, then 30 minutes later during another drive it doesn't, then again it works.
90 degree plus with high humidity here right now so this is not cool. Wife is furious and refuses to drive the car. Spoke to our SA and he offered to give us a new 8 series coupe (no M) for a couple of weeks so we have something to drive while they figure this out. I truly appreciate the gesture (SA has been nothing but great) but it misses the point that we have a car that works unreliably with no immediate fix in sight... |
07-03-2020, 11:39 AM | #88 | |
25076
Rep 8,762
FlorinQCK-2.50 |
