03-03-2006, 11:22 PM | #1 |
235
Rep 2,059
2006 Mercedes Benz SLR McLaren
(from Mercedes-Benz Press Release) The new Mercedes-Benz SLR McLaren is an impressive testament to the competence and experience of Mercedes-Benz and our Formula 1 partner McLaren in the development and production of high-performance sports cars. The two-seater, with its striking swing-wing doors and styling elements borrowed from the Formula 1 Silver Arrows, builds on the legacy of the famous SLR race cars of the 1950s. Equipped with cutting-edge race car technology and ground-breaking new Mercedes developments, designed to ensure a high standard of safety and suitability for day-to-day use, the new SLR creates a distinctive image for itself as a 21st-century Gran Turismo ・a thrilling synthesis of tradition and innovation.
The newly developed V8 supercharged engine delivers an output of 460 kW/626 hp and accelerates the sports car from 0 to 100 km/h in 3.8 seconds. The top speed is approximately 334 km/h. The body of the new SLR, like those of the Mercedes-McLaren Formula 1 race cars, is made from carbon fibre composites ・lightweight materials which demonstrate exemplary energy absorption, hence ensuring the highest standard of occupant protection. The SLR is the world's first series-produced car to have a front crash structure manufactured entirely from carbon fibres. Adaptive airbags, newly developed kneebags and sidebags, belt tensioners, high-performance ceramic brake discs and an automatically adaptive airbrake in the boot lid round off the range of safety equipment on board the Mercedes-Benz SLR McLaren, setting new standards in this vehicle class. Technology way ahead of its time and an abundance of power ・these were the hall-marks of the legendary SLR race cars in which Fangio, Moss, Kling and other Mercedes drivers achieved spectacular victories in all of the major road races in 1955. The new SLR demonstrates the same characteristics, its groundbreaking technical innovations distinguishing it as the Mercedes-Benz among high-performance sports cars. Two Longitudinal Members made from Carbon Fibre Composite Absorb Energy in a Head-On Collision The 21st-century Gran Turismo is made almost entirely from carbon fibre composite. This lightweight yet extremely rigid material originated in the aeronautical and space industries and has also proven its benefits in today's Formula 1 race cars. The weight advantage of the high-tech material over steel is around 50 percent, and the carbon fibres, on impact, are characterised by four to five times higher energy absorption than steel or aluminium. Mercedes-Benz exploits these qualities by incorporating two 620-millimetre longitudinal members made from carbon fibre in the front structure of the new SLR. These absorb the entire energy of the crash in a defined head-on collision, leaving the passenger cell largely undamaged. It is also made entirely from carbon fibre composite and therefore offers a very safe survival zone in side-on or rear-end collisions too. Mercedes-Benz has introduced new material technology to the manufacture of the brake discs too. They are made from fibre-reinforced ceramic and are characterised by high fade-resistance and a very long life. In collaboration with the electrohydraulic braking system, Sensotronic Brake Control (SMC・, they allow outstanding deceleration figures too, impressively underlining the motor racing heritage of the Mercedes-Benz SLR McLaren. 460-kW/626-hp V8 powerplant with Cutting-Edge Compressor Technology In the interests of optimum dynamic handling and high stability on braking, the new Mercedes-Benz SLR McLaren has a front mid-engined design. The high-performance V8 engine, mounted on a robust aluminium frame, is installed at a low level which allows a low centre of gravity for agile handling. With its 5.5-litre displacement, the supercharged engine develops a peak output of 460 kW/626 hp and delivers its maximum torque of 780 Newtonmetres from 3250 rpm ・a figure which remains constant across a broad engine speed range of up to 5000 rpm. This means that the SLR 8-cylinder is among the most powerful engines currently available in a series-produced roadgoing sports car. This high-performance car takes just 3.8 seconds to sprint from 0 to 100 km/h, it passes the 200 km/h mark after 10.6 seconds, and from a standing start it takes just 28.8 seconds to reach 300 km/h. The top speed is 334 km/h. Water-type charge-air cooling, dry sump lubrication and four metal catalytic converters are further special features of this powerful engine ・an engine which already meets stringent EU 4 exhaust gas regulations which are not due to come into force until 2005. The 5-speed automatic transmission, fitted as standard, is also designed for high performance. It allows the driver to choose between three programs with different shift characteristics. When "Manual" is selected, the five gears can either be shifted using buttons on the steering wheel or using the selector lever's Touchshift function. In this mode the driver can also select between three shift stages ・ "Sport", "SuperSport" and "Race" ・significantly shortening the shift times still further for an even sportier drive. Aerodynamic Concept uses Expertise from the World of Formula 1 The body design of the Gran Turismo with the Mercedes star takes classical styling elements from the legendary SLR race cars of the 1950s and blends them masterfully with the sophisticated, avantgarde design language of both the latest Mercedes passenger car models and of the modern-day Silver Arrow race cars which took the McLaren Mercedes team to Formula 1 World Championship glory in 1998 and 1999. The design's concept, in other words, thrillingly spans the divide between past and present, whilst at the same time showing the way forward for the sports car designs of tomorrow. In order to meet the highest of standards in terms of handling at top speed, directional stability and the cooling air requirements necessary for high-performance cars of this kind, Mercedes-Benz worked with McLaren on developing this model's superlative aerodynamics, ensuring exemplary roadholding plus the on-road safety standards typical of Mercedes. Following extensive wind-tunnel tests, the Mercedes-Benz SLR McLaren was given a virtually smooth underbody with a special six-channel diffusor under the rear. Both features are familiar design principles from Formula 1. They ensure that the airflow beneath the vehicle is virtually unimpeded and that negative lift, or downforce, is produced at higher speeds. The distinctive sidepipes on each side of the vehicle are also the result of this high-performance sports car's aerodynamic underbody concept: a conventional exhaust gas system would have disrupted the smooth line of the underbody. At the rear of the SLR an adaptive spoiler provides additional downforce. From a speed of 95 km/h, it automatically adopts a 10-degree position, increasing the contact pressure at the rear axle. The spoiler also doubles as an airbrake: when the driver brakes heavily, it rises to an angle of 65 degrees, not only ensuring increased aerodynamic drag but also shifting the aerodynamic centre further towards the rear. This lends the SLR excellent stability when braking from high speeds. Functionality and Luxury Stylishly Combined It is the very high levels of practicality and luxury that truly make the interior of the SLR stand out. Individually padded carbon-frame seats, a multifunction steering wheel with race-car-type buttons for manual gear selection, clearly arranged chronometer-style instruments and high-grade materials define the atmosphere inside the high-performance sports car. Alongside carbon and aluminium, the Mercedes designers have used "Silver Arrow" leather, specially developed for the SLR, which is available in the distinctive red of the legendary 1950s SLR race car.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive" Last edited by BMW0; 03-03-2006 at 11:42 PM.. |
03-04-2006, 12:25 AM | #3 | |
277
Rep 3,924
2011 E92 M3 - IB/Beige/Sycamore Wood/6MT/EDC/ZPP2/Nav/PDC/Heated Seats/iPod-USB/Enh. Audio
2008 E92 335i - Montego Blue/Black/Gray Poplar/6MT/ZPP/ZSP/Nav/PDC/Heated Seats/HDRadio/iPod-USB - Sold 2006 E90 330i - Mystic Blue/Black/Aluminum/6MT/ZPP/iDrive/PDC/Heated Seats/Sat. Prep - Sold 1994 E36 325i - Boston Green/Beige/Automatic/ZPP/Heated Seats/Premium Sound - Sold |
03-04-2006, 12:43 AM | #5 | |
235
Rep 2,059
http://www.seriouswheels.com/top-Mer...LR-McLaren.htm Your welcome.
"Freude am Fahren" = "Joy to Drive" |
03-04-2006, 02:31 PM | #7 |
262
Rep 2,576
I saw 2 of them in person at my MB dealer today, they are amazing. A silver one which is nice but the black!!!!! omfg its amazing
03-05-2006, 12:35 PM | #9 | |
235
Rep 2,059
03-05-2006, 05:08 PM | #10 | |
Rep 469
http://www.netcarshow.com/mercedes-b...4-slr_mclaren/ See for yourself. Same text and pics, and note the date: Nov 20, 2003. I'm not here to prove you wrong or anything. It's fine by me that you like the SLR, just make a thread and tell us how much you love it. Don't waste bandwidth by posting old news/making up new press release, it's pointless. Ciao. |
03-05-2006, 05:33 PM | #11 |
570
Rep 6,750
That car is so beautiful. I generally don't much care for MBs, but this one is exceptional.
03-05-2006, 05:54 PM | #12 |
3563
Rep 9,788
I saw one at the dealer- MSRP was $560k + $120k Mark up= $680K. Holy crapppp!!! It looks soo nice, kinda like a batmobile hehehe. If I have that car it'd be my pimpsmobile.
03-05-2006, 07:26 PM | #13 |
Rep 56
I believe they quit producing this car last year before completing the planned production #. You may still be able to get a new one on the lot (if you have several hundered thou. to spare).
03-05-2006, 08:41 PM | #14 | |
235
Rep 2,059
03-06-2006, 05:11 PM | #15 |
One of my two dachshunds:
53
Rep 663
Saw one cruising in La Jolla a month ago and it could most likely be last year's model (which looks nearly the same as above). I don't usually gawk at cars since there are Bentleys, Ferraris, Lambos, Maseratis, and 911 Turbos crowding the city but this ride definitely was a looker.
I would like to see an Enzo on the road.
I'm sorry about my outlandish behavior - there's too much blood in my alcohol system.
03-06-2006, 06:33 PM | #16 |
235
Rep 2,059
Squawks I saw an Enzo in Bellevue, Washington near Bill Gates House in Medina. Lucky me. The Enzo is truly superb. I could not believe it at first, it took me several glances to make sure I was not dreaming. Wow, what a beautiful car we all can appreciate.
03-13-2006, 05:59 AM | #17 |
262
Rep 2,576
ehh im not too empressed with the ENZO, i goto aspen ever year and see this red enzo and its a nice car and all but not my type its just meh to me.
03-13-2006, 02:19 PM | #18 |
235
Rep 2,059
I bet it makes you take second looks, because Enzo wants you to
03-13-2006, 03:15 PM | #19 |
262
Rep 2,576
i mean its a ferrari of course your going to give it the good ole double take, its an amazing car, its just not for me (even if i had the money, which i dont )
