01-12-2009, 10:40 PM | #1 |
1274
Rep 4,703
Autoshow - Which lens to take?
Hi All,
I'm heading to Detroit this weekend for the autoshow. What lens would work best in that situation / lighting? Ideally I want to take 1 lens so that I don't have to carry gear all day long. I have a Nikon D90, and here is the glass I own. NIKON AF-S 17-55MM F2.8 IF ED NIKON DX VR 18-200 F3.5-5.6 AF-S LENS NIKON DX NIKKOR AF 10.5MM F2.8 FISHEYE My co-workers also have lenses that I could borrow if none of the above apply. The show is pretty crowded and to get pics you will have to be pretty close to the cars. The 10.5mm fisheye is cool, very wide however I don't want every pic to look like that. The 18-200 is my general all purpose lens however due to the indoor lighting it may not be fast enough. I'm leaning toward the 17-55, it's wide enough, fast response time and a decent zoom for an autoshow. Thoughts? Thx |
01-12-2009, 11:34 PM | #2 |
635
Rep 24,685
Drives: '04 330i ZHP
+1 on the 17-55mm
fast lens and good so you can shoot a little closer to the cars w/o people walking in front of you. |
01-13-2009, 03:19 AM | #4 |
1571
Rep 29,202
Go with the 17-55 2.8 for sure.
01-13-2009, 07:09 AM | #5 |
143
Rep 346
I would take the 17-55 2.8
Short FL's should get you away with 1/20th without major shake issues. Ideally I would recommend an external flash too. I covered the whole London Motor Show with Canon's 24-105L f4L IS and even during dim points, f4 and IS/VR was good enough but that being said, was using an external flash also. Take them both, takes about 20 secs to change lenses. |
01-13-2009, 09:06 AM | #6 |
1274
Rep 4,703
Thanks for the input folks. Much appreciated.
I'm going to throw the D90 w/17-55 around my neck and enjoy the show The only downside to that lens is that it is pretty long. If for some reason I need to use the pop-up flash it will not work that great. The lens will block the flash resulting in a dark spot right in the middle of the picture I have an SB-600 however I don't think I will need to bring it as I should be able to adjust the camera settings to avoid using the flash in general right? Last edited by 2kaccordocoupe; 01-13-2009 at 09:37 AM.. |
01-13-2009, 10:42 AM | #8 | |
1274
Rep 4,703
01-13-2009, 02:38 PM | #11 |
143
Rep 346
I was gonna post some later but these are all external flash. No harsh shadows!
Press Day - London Motor Show 2008 Some you can tell where I bounced but I tend to use a bounce card also. All with a image stabilised lens and had an easy time. Only time I had to stop and rest was batteries in the flash. |
02-18-2009, 12:33 AM | #12 |
Aberry is a scammer
561
Rep 5,507
Drives: SGM E92 335i, AM E90 335i
I know its not mentioned in one of the OP's lenses but what about the 50mm 1.8? I'm going to the upcoming NY autoshow in april and the two lenses I have are the 50mm prime and 28-135mm
02-18-2009, 05:00 AM | #13 | |
143
Rep 346
With the 50mm once you have backed up, remember the amount of people that will walk through you view. |
