04-12-2008, 06:46 AM | #23 |
96
Rep 1,337
some of you guys are missing the point because i specified PREmium... i understand if they use it on regular or something but i want to be able to buy 100% petrol somewhere. and there is no way ethanol is as explosive as gas, i don't care what some fake gov. report says.
If everything seems under control, then you aren't going fast enough"
04-12-2008, 07:16 AM | #25 |
10
Rep 1,035
If you want to drive in the Northeast in the winter, you don't have a choice.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
04-12-2008, 07:19 AM | #26 | |
10
Rep 1,035
Some of you people don't have the slightest idea what you are talking about.
04-12-2008, 08:19 AM | #27 |
1469
Rep 3,552
most CARB states only sell E10 year round. In NYC, all gas is E10, by law.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
04-12-2008, 02:09 PM | #28 |
342
Rep 1,325
Minnesota has had mandatory E10 for over a decade now in all grades of gasoline. I have never heard of an issue on a modern car that gets regular use. Just think if 1,000,000 cars in the midwest have been using it for 10,000 miles per year. Over the last 10 years that's 100 Billion miles of driving on E10, and still these issues you guys think are there, just aren't. It's safe.
The temperatures in the state range from -60F to 114F, and again, no issues. Now I have heard of it making old cars runs poorly (Mid 1970s and earlier) as well as lawn equipment; small engines on lawn movers, snowblowers, etc... Also, apparently the ethanol breaks down the fuel faster, so it can't be stored for long periods like pure gasoline can before it starts to break down. |
04-12-2008, 02:31 PM | #29 | |
29
Rep 1,381
Plus, there is more to worry about than just fuel lines. There are a lot of parts that SHOULD be changed for the long term running of E85. Perhaps they wont break down anytime soon, but over time they may. Some cars may even need a different gas tank as part of the conversion depending on what materials they are made with. It's not an incredibly hard process to convert a car, as you say, but it's not as cut and dry as you may think. |
04-12-2008, 03:31 PM | #30 |
Slow and low
59
Rep 636
The real issue is this (I'm a closet petrochemical engineer):
Ethanol has a much higher octane level than regular gasoline so a refinery can run their cracks for a slightly lower octane level of gasoline (one refinery manager recently told me they were running for 84 instead of 87) and then blend in 10% ethanol to take the octane level up to where it should be. This allows them to obtain a bit more distillate (jet fuel to you) and other valuable byproducts from the cracked barrel. But there's a catch, ethanol is much less fuel efficient than normal gasoline so you will get less MPG with E10 than non-E10 gasoline! However because our federal govt wants to help the farmer (who's getting rich now but admittedly had many many tough years in the 80s and 90s); this difference in MPG is tolerated and really unadvertised. |
04-12-2008, 03:32 PM | #31 |
Slow and low
59
Rep 636
04-12-2008, 04:49 PM | #32 |
124
Rep 4,172
I was using Sunoco 94 for the first 5 months I had my car; started having rough idles. It's a common issue with e46 M's too. For reference, Sunoco 94 uses ~10-12% ethanol. I swtiched to Shell 91 (0% ethanol here in Ontario), idle issues went away on the first tank. Maybe I am uneducated, but my experience with high ethanol gas doesn't exactly make me feel confident about using it.
(I am not saying it's not safe, I am saying that in my car and quite a few e46 M3/Mcoupes, people had rough idle/long cranks while using 10% ethanol gas, and don't with 0% ethanol gas). |
04-12-2008, 04:59 PM | #33 | |
137
Rep 1,243
ITS NOT GOING TO HURT YOUR CAR IN ANYWAY, ITS BEEN THIS WAY FOR YEARS AND YEARS. I have yet to hear of any issues with running 10%, you dont see all the expensive cars in AZ or other states breaking down because of it. And I dont get what you mean by explosive? By its nature gas is not that explosive since you want compression without premature ignition.. A quick google search will tell you that over 90% of gas sold today is has 10% ethanol. |
04-12-2008, 05:00 PM | #34 |
137
Rep 1,243
04-14-2008, 09:11 AM | #38 |
72
Rep 627
Ethanol IS a joke! It takes as much energy to produce it as it gives off. It also make our gas more expensive because of the extra process during refinery. It is an inefficient fuel, and it makes the price of food go up as well.
04-14-2008, 11:35 AM | #39 |
Racying Dynamics
118
Rep 4,391
All gasoline has to have an “oxygenate” to raise the octane number of the fuel that in most cases was up to 7.5% MTBE – Methyl Tertiary Butyl Ether – (a highly toxic and cancerous fossil fuel by-product). Today, in most cases at least, gasoline uses ethanol as an oxygenate to increase its octane rating w/o the environmental issues. 10% ethanol is simply a oxiginate that improves the octane rating of your gasoline (since ethanol has a rating of about 104). Nothing to fuzz about as it improves you gasoline at no real cost to you. I should add that most gasoline in the USA have used around 5% ethanol for several years now.
04-14-2008, 11:36 AM | #40 |
Racying Dynamics
118
Rep 4,391
Cheveron is way behind by the way!!! Your engine cannot only take that % ethanol easily, but will improve fuel combustion and increase the anti-knock capacity at the same time.
04-16-2008, 06:22 PM | #41 |
134
Rep 3,132
welcome to 2006?
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
04-21-2008, 03:49 AM | #43 |
Rep 40
In Ontario I have been using Sunoco's Ultra94 exclusively for around 13 years now. In the Toronto area, they started adding EtOH to Ultra94 around the mid to late 90's and I haven't had any problems with their fuel. Granted one does get less mileage from gas + EtOH blends because pure EtOH has around 1/3 less energy per litre than plain gas, but EtOH damaging cars isn't really an issue.
