06-03-2006, 01:06 PM | #89 | |
74
Rep 911
I'll challenge anyone with a US manual 330i to try get a time under 6. |
06-03-2006, 05:01 PM | #90 |
hotsand5
49
Rep 806
ward, what is the point of double clutching? Isn't that why we have syncros? Couldn't it just be easier using the heel and toe downshift where you rev match, but by not double clutching? I don't know if there is any advantage, so if you can tell me, I'd love to know the difference. thanks.
-2006 BMW 330i-Sapphire Black- Tera Leather-Aluminum trim- 6spd manual- Sport- Premium- Cold- Navigation- Euro. delivery
-2005 Yamaha Warrior 1700 102cu" |
06-03-2006, 05:21 PM | #91 | |
442
Rep 4,838
Only the US got that package. |
06-03-2006, 11:43 PM | #94 | |
155
Rep 6,158
it's a joke from fast and furious man |
06-04-2006, 12:50 AM | #95 | |
196
Rep 2,486
But since you wanna mention Mag Racing. Heres Mag racing for your ass... Info XR2 Information Specifications Pictures Lancer Information Specifications Pictures R32 Information Specifications Pictures XR2 (C) Information Specifications Pictures 306 (C) Information Specifications Pictures Links Saxo Information Specifications Pictures Volkswagen R32 - Specs Engine Type Six cylinder 'Otto' engine, 15° V6, DOHC, 24V Fuel System Multi-point fuel injection Capacity 3189cc Bore x Stroke 84.0mm x 95.9mm Compression Ratio 15.6:1 Max Power 240bhp/177kw @ 6250RPM Max Torque 236lb.ft/320Nm @ 2800RPM Drive System Type 4MOTION all-wheel drive system (Haldex) Brakes Type Power assisted 4 wheel discs, ABS, EBD, ESP Front 334mm ventilated discs Rear 256mm solid discs Transmission Type Manual 6-speed, floor shift 1st Ratio 3.36:1 2nd Ratio 2.09:1 3rd Ratio 1.47:1 4th Ratio 1.10:1 5th Ratio 0.86:1 6th Ratio 0.72:1 Final Drive 4.24:1 Clutch Dry single disc with diaphragm spring Steering Hydraulic Rack & Pinion with Power Assist Suspension Front MacPherson struts, lower A-arms, coil springs, tube shocks, anti-roll bar Rear Multilink, coil springs, tube shocks, anti-roll bar Wheels Wheels/Tyres 7.5" x 18" cast Alloy (225/40 ZR18) Fuel Tank Capacity 62 litres Weight Kerb Weight 1477kg Dimensions Overall Length 4149mm Overall Width 1735mm Overall Height 1444mm Wheelbase 2518mm Front Track 1511mm Rear Track 1491mm Turning Circle 10.9 m Performance 0-30 mph Not Available 0-60 mph 6.6 Seconds 0-100 mph Not Available Top Speed 153 1/4 Mile 14.8 s @ 94mph
06-04-2006, 01:11 AM | #96 |
74
Rep 911
Artz330, you must be the most emotionally unstable person I've ever come across. Chill out. You're entitled to your opinion but I have to add, whats the relivance of the numbers your showing me? Its a VW. Anyone ever mentioned you're an odd ball?
06-04-2006, 01:15 AM | #97 | |
196
Rep 2,486
Ohh and sorry but no one ever mentioned that. I just really know my shit, thats all. So I was just posting an Example.
