06-01-2006, 02:18 AM | #45 |
Bimmer Manual all the way
66
Rep 1,811
actually the only way to smoke the 350z in a beemer would be in a m5, m6 or e46m3. you could also try the jap rocket 320 hp Mitsu evo9- 5 sec flat century sprint car. but the 350z would be clever not to provoke or race with u if u were driving the cars in my ' kick ass ' list. the new 335i would be a candidate to match the 350z too when it arrives.
________ Michigan Medical Marijuana ________ Free adult streaming ________ Redhead Cams ________ Video review Last edited by climkt; 04-22-2011 at 02:41 AM.. |
06-01-2006, 02:41 AM | #46 |
Good MAN....
21
Rep 483
Bmw got the better ride quanlity and better conering,it all depends on the driver's skill. I think 330i can beat 350z,but not easy. Horse power is not everything for cars.
Parting out!!! sub, sub box, N2, and Module wheels. :rocks:
06-01-2006, 02:46 AM | #47 |
61
Rep 616
PRESTATIES
topsnelheid 250 km/h acceleratie 0-100 km/h 5,8 s 6, in V-vorm kleppen per cilinder 4 cilinderinhoud 3498 cm3 boring x slag 95,5 x 81,4 mm compressieverh. 10,3:1 max. vermogen 221 kW (300 pk) 6400tpm max. koppel 353 Nm 4800tpm sorry for the language |
06-01-2006, 07:12 AM | #50 |
15
Rep 272
2005 Ford Mustang GT conv 2005 Nissan 350Z Roadster
Powertrain/Chassis Drivetrain Layout Front engine, RWD Front engine, RWD Engine type V-8, alum block and heads V-6, alum block and heads Valvetrain SOHC, 3 valves/cyl DOHC, 4 valves/cyl Displacement 281.0 cu in/4606cc 213.5 cu in/ 3498cc Compression ratio 9.8:1 10.3:1 Redline 6250 rpm 6600 rpm Power (Sae Net) 300 hp @ 5750 rpm 287 hp @ 6200 rpm Torque (Sae Net) 320 lb-ft @ 4500 rpm 274 lb-ft @ 4800 rpm Specific output 65.2 hp/liter 82.0 hp/liter Weight to power 12.3 lb/hp 12.3 lb/hp Transmission 5-speed manual 6-speed manual Axle/final-drive ratios 3.55:1 / 2.41:1 3.54:1 / 2.81:1 Suspension, front; rear Struts, coil springs, anti-roll bar; live axle, coil springs, anti-roll bar; anti-roll bar Control arms, coil springs, anti-roll bar; multilink, coil springs Steering ratio 15.7:1 15.9:1 Turns lock-to-lock 2.8 2.6 Brakes, f;r 12.4-in vented disc; 11.8-in vented disc, ABS 11.7-in vented disc; 11.5-in vented disc, ABS Wheels 17 x 8.0 cast aluminum 18 x 8.0 cast aluminum Tires 235/55ZR17 98W Pirelli P Zero Nero f: 225/45R18 91W; r: 245/45R18 96W Bridgestone Potenza RE040 Dimensions Wheelbase 107.1 in 104.3 in Track, f/r 65.7 / 63.6 in 63.0 / 63.7 in Length x Width x Height 188.0 x 73.9 x 55.7 in 169.4 x 71.5 x 52.3 in Turning circle 38.0 ft 35.4 ft Curb weight 3690 lb 3517 lb Weight distribution, f/r 51 / 49 % 53 / 47 % Seating capacity 4 passengers 2 passengers Headroom, f/r 38.8 / 36.3 in 39.2 in Legroom, f/r 42.7 / 30.3 in 42.6 in Shoulder room, f/r 55.4 / 45.0 in 53.6 in Cargo capacity 9.7 cu ft 6.8 cu ft (w/temp, spare) Test Data Acceleration to mph 0-30 2.0 sec 2.1 sec 0-40 3.0 3.2 0-50 4.1 4.4 0-60 5.4 5.8 0-70 7.2 7.8 0-80 9.2 9.8 0-90 11.4 12.4 0-100 13.3 15.3 Passing, 45-65 mph 2.8 3.0 1/4 mile 13.9 sec @ 100.8 mph 14.2 sec @ 98.2 mph Braking, 60-0 mph 126 ft 119 ft 600-ft slalom 63.4 mph avg 66.2 mph avg Lateral acceleration 0.81 g avg 0.87 g avg Top gear rpm @ 60 mph 1900 rpm 2250 rpm Consumer Info Base price incl dest $31,175 $37,330 Price as tested $33,905 $41,110 Stability/traction control No/yes No/yes Airbags Dual front, front sides Dual front, front sides Basic warranty 3 yrs/36,000 miles 3 yrs/36,000 miles Powertrain warranty 3 yrs/36,000 miles 5 yrs/60,000 miles Roadside assist period 3 yrs/36,000 miles None Fuel capacity 16.0 gal 20.0 gal EPA city/hwy fuel econ 17 / 25 mpg 20 / 26 mpg Recommended fuel Unleaded regular Unleaded premium |
06-01-2006, 07:23 AM | #51 |
17
Rep 259
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/9CpujJDW9nY"></param><embed src="http://www.youtube.com/v/9CpujJDW9nY" type="application/x-shockwave-flash" width="425" height="350"></embed></object>
06-01-2006, 09:16 AM | #54 |
61
Rep 158
0-60 times are done by professional drivers on closed tracks over and over again, so the average "red light racer" is at least .5 to a full second under that "magazine" time.......
06-01-2006, 10:01 AM | #55 | |
196
Rep 2,486
06-01-2006, 10:13 AM | #56 |
33
Rep 1,770
Horsepower isn't everything boys. I don't think 3 series is built for a true racer/spring cars (except for the M series of course)
2006 330i Steptronic/Alpine White/Black Leather/Burl Walnut Trim/Premium Package/iDrive/Heated Seats/Winter: STYLE 159 Blizzak LM-22 RFT/Summer: TBD
2004 X5 Steptronic/Alpine White/Grey Leather/Poplar Trim/Premium Package/Heated Seats/iPod Adapter |
06-01-2006, 10:48 AM | #57 | |
35
Rep 263
2012 F10 535i | Alpine White | Black Dakota Leather | Dark Wood Trim | Anthracite Headliner | ZPP | ZSP | Tech | Rear Sunshades | SiriusXM |
06-01-2006, 10:51 AM | #58 |
15
Rep 272
Which one you like best?" The question came from one of the locals in southeast Ohio who'd stopped to check out our quartet of silver and red sports cars. He wasn't the first to ask, and he wouldn't be the last.
We were having a hard time coming up with a definitive answer. It would have helped to pick a clear winner if we'd had an obvious loser. Unfortunately, with the BMW Z4 3.0i, the Honda S2000, the new Nissan 350Z roadster, and the Porsche Boxster, there wasn't one in the bunch. So, over three days of driving, our answers kept changing, as one car and then another nosed briefly into the lead. It also would have been easier if we'd stuck to one venue: the skidpad, the racetrack, the back roads, or the Interstates. But we'd hit 'em all, and what we found was that all four cars excelled in at least a few areas, that none was best in all, and that differences in personal preference were as strong as differences in the cars' relative merits. Its another championship ? |
06-01-2006, 11:00 AM | #59 | |
Client Advisor/Radio DJ
172
Rep 1,293
Drives: 2006 bmw 330xi/2019 bmw 230i
f22 230i delivered 12/27/18/Seaside Blue/Oyster Sensatec/Manual/Heated front seats, Track & Handling package/CF mirrors and rear spoiler/M Sport front bumper/Shadowline trim/M Performance shift knob/1 Series (f21) M Sport steering wheel
06-01-2006, 12:15 PM | #60 | |
196
Rep 2,486
The X drive does not loose much through the system. BMW drivetrain is very efficient compaired to other auto makers. Gearing is everything. the 330i has a 3.15 differential, in the Automatic for Example the loss through the transmission is compansated with a lower gear ratio in a 330i Auto or XI auto with a 3.64 rear diff. the 325i has a 3.73 rear in the automatic. and 40 LEss HP. my girl drives a 325 I, and I can tell you. From a Roll 5mph start, she can hang with me on my rear door till about 70-75 mph when the extra 40 HP starts to kick in for me. TQ = Low End, HP = Top End
06-01-2006, 01:20 PM | #61 | |
Rep 11
06-01-2006, 02:12 PM | #62 |
15
Rep 272
287 hp with stick, lol and who is the challenger, Z4 perhaps but 330 no way.
The coupé version is already SA's best-selling sports car by a wide margin and the car has earned so many 'Car of the Year' and other accolades worldwide that Carlos Ghosn might have to build a trophy house just for the Z car. Not only is it the best roadster around; it also sends a clear signal to those upper-crust carbuilders BMW and Mercedes that they ain't as good as they think they are and that goes for Chrysler too. Building in more and more gadgets and electronic goodies and billing the buyer isn't the way to go anymore – building something as honest and straightforwardly bloody good as the 350Z is. To those of you out there for whom quality equates with price (or vice versa) well, pardon me, but crap! Here's how it pans out with the competition: Chrysler Crossfire – R455 000 Audi TT – R465 000 BMW Z4 R470 000 Mercedes SLK 320 – R470 000 Nissan 350Z – R425 000 (R428 000 if you want the only available option, ventilated orange seats) The car's grip, with 225/45 rubber at the front and 245/45 at the rear, is phenomenal. There's no automatic option, and for me that puts the 350Z on a pedestal. Just a really good, fast and feel-good six-speed manual – no pretty buttons, paddles or flip-it-side-to-side autoshifters that do what the damn well want and only when they want to. The 350Z is like steak is to veal – real, growed-up meat you can get your teeth into and get our teeth into it we did on one of the greatest driver's roads in South Africa, the humdinger that runs from Gordon's Bay along the False Bay coast to Betty's Bay and on to Hermanus. The tar snakes and weaves, new and smooth, to match the bulges of the mountains. No serious gradients, just gently banked bends, short and snappy straights – then more bends and the inviting ocean several hundred feet below just begging you to make a mistake. The Z is a driving tool, not a fashion statement – though it's still for my money one of the best-looking cars we've got – and its body rigidity is class-leading. Not a quiver, not a tremble, of the "scuttle shake" that still exists on more expensive roadsters despite them also having a reinforced chassis and body. Under the bonnet is an all-aluminium 3498cc V6 capable of 206kW at 6200rpm and 363Nm of torque at 4800rpm and all of it loves to be used. Power is transmitted to the rear wheels through a carbon-fibre strengthened plastic drive shaft and a limited-slip differential and you can get 320kW and almost 300km/h if you talk to Rob Green in Johannesburg about a supercharger. That should make your eyes water but we're talking about the standard car and that will zap to the metric ton in 5.9 seconds and howl (yes, those twin drainpipes at the back sing a beautiful song and it boomed back brilliantly as we set the Bridgestone Potenzas to work on the coastal scenic route) on to 250km/h. The car's grip, with 225/45 rubber at the front and 245/45 at the rear, backstopped by a stability control system and Brembo ventilated discs all round, is phenomenal. If you love cars, and driving them, then the Z and its whole persona just can't be ignored – poseurs, piss off. Three roof locks Essentially, the 350Z Roadster has all the key performance features of the 350Z coupé but with a power-operated soft top with a glass rear window and demister – two cars for the price of one, the roof doing the transformation in only 20 seconds. It's held in place by three locks, one of them requiring manual release; retracted, Nissan says, the Z has the least cabin turbulence of any convertible, thanks in part to a tempered glass wind deflector fitted behind the seats and between the rollover bars. Nissan also says normal conversation is possible at speed; nice try guys. But the top-end Bose sound system can easily overcome the road and breeze noise – Nissan supplied a CD of Sixties and Seventies classics with the car so we cranked up the volume, pushed down on the gas and created our own symphony of song and exhaust with an overlay of whining rubber. But the Z isn't all macho muscle and sweaty leather: there's a good dose of hedonism in there too. Power seats (only two, of course, no pretence of being a four-seater here), remote-controlled central locking, powerful air-conditioning (for those rare times when the hood exposes itself), Bose sound system with six-stacker CD, leather seats, lining and covers for the steering-wheel and gearshifter, really simple-to-use cruise control on the right-hand horizontal bar of the tiller, flashing red light that shouts "Change gear!" and power for the windows and external mirrors. Crash bags, of course, with pre-tensioners and load limited on the seat belts. The only factory options are those ventilated seats with orange leather and dark net (with orange leather on the gearshifter) in Silver, Gun Grey, Sunset Orange and Black roadsters. The hood is available in two colours: black for all body colours or blue if you choose Silver, Gun Grey or Blue paint jobs. A roadster with his pairs but under 911 or 996 coupés, but below s 2000. |
06-01-2006, 02:52 PM | #64 |
196
Rep 2,486
lol. I love how people post up mag racing. Mag racing doesnt mean shit. . (To some extent it is ok.)
For example. They could have tested the 350Z in Maine at 50 Degree weather and got better times because of the conditions. on the other hand the 330i may have been tested at 110 Degress in Arizona in the middle of the summer and got shitter times because of the heat. Real world is where it counts. Same Light, Same street. Same Conditons, alt. wind, ground temp, air temp, Ect. Now you can compare the 2. Dont show me magazine times as it is done by, different people, different drivers, different times of the year, and in different parts of the world.
06-01-2006, 04:17 PM | #65 |
15
Rep 272
http://video.google.com/videoplay?do...695173920&q=m3
Even so its logical 350 Z against M3 never against 330i. Last edited by N1; 06-01-2006 at 05:32 PM.. |
06-01-2006, 05:58 PM | #66 | |
9
Rep 147
The pro will probably be, on average, .1 to .3 seconds faster than the "average red light racer", but no way is it a full second.
2017 540i MSport
2014 535i 2011 335i 2006 330i |
