12-24-2018, 08:06 PM | #1 | |
1884
Rep 2,174
Nice Writeup on Engine Oils
https://540ratblog.wordpress.com/
As I have been saying for years: Quote:
12-24-2018, 10:25 PM | #3 |
BXR
575
Rep 636
"My advice is, ignore any critics of my Blog, because they have always been wrong, and cannot be trusted. "
Is a good way to get me to be very skeptical of your 'findings'
2012 135i M Sport Alpine White
Viffermike1753.00 |
12-25-2018, 06:09 AM | #4 |
16954
Rep 18,582
Conventional oils have been in use for decades prior to the widely accepted use of synthetics (for long drain interval applications).
12-25-2018, 08:58 AM | #5 |
1884
Rep 2,174
12-25-2018, 09:03 AM | #6 | ||
1884
Rep 2,174
Dackelone10512.00 |
12-26-2018, 12:57 PM | #7 |
7273
Rep 7,252
This guy is a nut and his method is not agreed upon as being the figure of merit for an oil.
chetrickerman10437.50 |
12-26-2018, 02:26 PM | #8 |
245
Rep 466
According to that guys testing method millions of cars should be broke. Vast majority of people use the cheapest oil and incorrect/longer oil change intervals.
In addition many of the oils he claimed are not capable of protecting an engine has had, IMO, superior testing in the form of a used oil analysis. In many cases owners have use "bad" oil for several oil changes over many thousands of miles without wear particles showing up in used oil testing. I would take it for whats its worth, just another measurement to factor with but not base solely on. |
12-26-2018, 04:32 PM | #9 | |
1884
Rep 2,174
What got my attention was 8. 5W30 Valvoline Full Synthetic High Mileage with MaxLife Technology, API SN, GM dexos 1 approved (silver bottle) = 123,470 psi Valvoline had a chart on their Website showing that this is their best oil for fuel economy and Horsepower. They also said this oil provided more anti-wear film strength than 5W30 Mobil 1, which is what I also found in my testing. He also found the the 0W-20 QS Ultimate Durability outperformed. the 5W-20 at higher temperature which is consistent the way additives fork in getting the 5W to 0W. I am a member of STLE (Society of Tribologists and Lubrication Engineers ) As an engineer it was pretty much my specialty as a Maintenance Engineer. I plan on using the 0W-20 in place of the recommended 5W-30 in my Forester XT. Of course I will suck out a sample at 2K miles to monitor the oil. If its good, I will do one at 6K and then decide if I want to drain or not. |
overlook637244.50 |
12-28-2018, 10:06 AM | #10 | ||
1005
Rep 2,239
Drives: 2007 328i / 2014 M235i
12-29-2018, 06:02 AM | #11 |
961
Rep 11,722
Nothing is 100% concrete. Something else come alone down the road and claim ‘this is the best’. What works for one may not work for another. That’s what I learned after owning several cars and do my own oil changes.
12-29-2018, 08:38 AM | #12 |
16954
Rep 18,582
I read most of the ancillary information 540 RAT wrote in the blog. He needs to edit the blog because he repeats numerous times he's a degree'd, patent-holding mechanical engineer and he is COMPLETELY INDEPENDENT, HAS NOTHING TO SELL, UNBIASED, and HAS NO AGENDA. Okay got it - just need to read it once. SCIENTIFIC DATA IS THE ONLY THING HE IS CONCERNED WITH. Okay got it. Yet he claims his test setup/equipment and procedures are proprietary, which when publishing any true scientific data, is never claimed by scientists. Any scientific published test data validates the data by explaining the testing methodology. If he is not publishing the blog for any PROFIT MOTIVE, then he should not be concerned about protecting his proprietary testing methodology. The test data is worthless if no one knows how the data was derived. My first question is what is his control methodology for the test samples (metal bearing surfaces) he uses. For one, does he test the material for consistency? And while I'm nit picking, he needs to organize the information better, like publish a table with the left column the tested oil and the right-hand columns the test data. And he stated aftermarket oil packages shouldn't be used, yet he tests several oils with additive packages and intermixes that information in with the straight oils tested; it's confusing.
I really wanted to see what Section 25 said about oil change intervals. He states for his daily driver, he goes no longer than 5,000 miles between oil changes. He also states" "• According to the USA motor vehicle Insurance Industry, the national average for vehicle mileage accumulation is 12,000 miles. Personal vehicles that are driven at continuous, extended, steady-state long distance cruising, totaling WAY MORE than that national average per year, are operating their vehicles under a condition that is much more ideal for an engine, than the start and stop type of driving experienced by normal daily driver vehicles. Operating an engine at continuous, extended, steady-state long distance cruising, allows for a somewhat longer oil change interval. But, due to a lack of data for that kind of operation, I don’t have a specific oil change interval recommendation for that. Though I would not recommend going more than a couple of thousand extra miles between changes. Because beyond that point, you could well be running into complete additive package depletion, along with all the other reasons for changing the oil." So the bold sections are close to what my E90 has seen as my daily commute for the past 11 years. My commute is 75 miles one way for a total travel time of 1 hour 45 min. to 2 hours. I sometimes stop twice, once to fill the fuel tank, and sometimes for an errand. But the engine doesn't cool by any means. But as far as scientific test, my commute is pretty good, because it is very consistent and I fill up at the same gas station (Shell) and same pump 98% of the time. My real-world test data is this, from 0 to 221,000 miles I followed the CBS OCI schedule until the CBS stopped calculating the interval (it's programmed to do that for some reason), from there on it's been 10,000-mile OCI. I've used only BMW 5W-30 LL-01 (both the original Castrol and the Penzoil/Shell new formula) and a MANN HU-816 filter. 361,000 miles on 28 total oil changes. Four (4) OCI were over 18,000 miles, four (4) over 17,000, two (2) over 16,000, one (1) at 15,386. Not ADVOCATING long oil change intervals, or use of BMW's products, for anyone else, just publishing scientific data...
Viffermike1753.00 |
01-02-2019, 12:43 PM | #13 |
1753
Rep 2,942
Engineers rarely possess the skills to write effectively. Heck: scientists rarely have those skills. The types of thinking and doing that go into each discipline are quite different from each other.
The fact that the man publishes on a blog and nowhere else tells you something. And the fact that he repeats himself. And the fact that his arguments aren't presented in a linear fashion -- actually, this is evidence that he's probably not a very good engineer, either, because that's one mode of thought that argumentative writing and scientific method share: linear procedure. Mmmmmmmeh. Oil threads bore me to sleep, anyway.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
01-02-2019, 02:42 PM | #14 | |
263
Rep 620
Drives: E90 335XI MSport, S2000
01-02-2019, 08:26 PM | #15 | |
16954
Rep 18,582
Viffermike1753.00 |
