BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion Question re: staggered setup /tires/wheel / spare
      03-05-2024, 10:14 AM   #1
italian926
27
80
Drives: 2022 530i
So I hit a pothole. Destroyed my runflat, replacing tire with used with similar treadwear. Wheel is a bit bent, getting replaced even though it still seals ok. I plan to use this wheel as a full-sized spare for when I go to non-runflats.
245/40/19 front
275/35/19 rear ~~Typo Correction ~~
So Questions
1) can the front wheel be used as a spare if I had to put it on the rear?
2) My current treadwear is around 7/32's , the used tire Im putting on is said to have 7.5 /32nds, that should be ok , right?
TIA
      03-05-2024, 11:58 AM   #2
__AD__
250
268
Drives: BMW M850ix GC
245/40/19 front
245/35/19 rear
So Questions
TIA
I posted that it should be fine but then saw that you have different diameters front to back? I would not put a 40/19 on the same axle as a 35/19.
      03-05-2024, 02:45 PM   #3
snowbimmer
snowbimmer's Avatar
5223
1,799
2022 M850 GC  [10.00]
italian926
Something doesn't jive here. Is your rear wheel a 20?
Otherwise, why would you be running a lower profile tire in back??
      03-05-2024, 03:46 PM   #4
italian926
27
80
Drives: 2022 530i
Woops ! Sorry, typo
245/40R-19 Front
275/35R-19 Rear
snowbimmer5222.50
      03-05-2024, 04:18 PM   #5
Qsilver7
Qsilver7's Avatar
4448
7,488
Drives: F06 650ix GC / F15 X5 50i
Prior to BWM switching most models to run-flat tires...when there was a staggered wheel/tire combo...around the 2003 model year-up...BMW started using either the front wheel/tire combo...and then started installing a totally different wheel/tire combo which was usually the smallest wheel/tire combo that was offered on that model or smallest wheel/tire combo that was allowable due to a larger/performance brake option.
My 2006 e53 X5 had a 17" wheel/tire in the spare compartment...but it came with 18" wheels. And even the models that came with 20" staggered wheels had the 17" spare unless it had a larger brake option which would then change out your spare to an 18" wheel/tire combo.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
