BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion Limeypride F93 M8 Competition GranCoupe Build by RG Sport (PICTURE HEAVY!!!)
      04-05-2020, 01:00 AM   #177
Wolfman64
Wolfman64's Avatar
812
810
Originally Posted by limeypride View Post
Agreed. I did the math before I made the change. However, I did't consider interior-top wheel-arch rubbing (as opposed to edge-arch rubbing which is NOT a problem).
Stock tires + H&R M550 springs == no issues.
Upgraded tires as mentioned earlier == no issues rear. Initially, no detectable issues front. Eventually, I started to hear rubbing during slow, tight maneuvers. So I setup a tight turn test and listened intently. The most pronounced running was driver-side from 75% lock... possibly because it's the side I'm closer to. Physical examination doesn't reveal much. Regardless, it's severe enough for me to decide to switch them out for their lower-profile counterparts.
Just saw that you have 295's in the rear. If you go back to 275's, there is a 1.8% difference. That's minor IMO.
Have had several MB's that have 19" in front and 20" in rear. Our GTC has a 3.4% difference in circumference and that is factory...
      04-05-2020, 01:04 AM   #178
Wolfman64
Wolfman64's Avatar
812
810
Agreed. I did the math before I made the change. However, I did't consider interior-top wheel-arch rubbing (as opposed to edge-arch rubbing which is NOT a problem). It's the increased tire-wall/profile that is causing the problem. This has not been an issue with my prior Ms because I've never gone for a 35% profile before.
Upgraded tires as mentioned earlier == no issues rear. Initially, no detectable issues front. Eventually, I started to hear rubbing during slow, tight maneuvers. So I setup a tight turn test and listened intently. The most pronounced rubbing was driver-side from 75% lock... possibly because it's the side I'm closer to. Physical examination doesn't reveal much. Regardless, it's severe enough for me to decide to switch them out for their lower-profile counterparts.
The only difference will be visual. The rear already looks beefier with the wider tire and the 11mm spacer. Might need to go up a bit on the front spacer...
Had some weird double-post. The website stops responding from time to time for me.
      04-05-2020, 01:19 AM   #179
limeypride
limeypride's Avatar
4425
4,109
Interesting... I've been wrestling with that solution especially since it only requires I replace 2 tires. The problem I face is there's no data and nobody at BMW willing to answer, "what is the tolerance?" Given that, I'm kinda stuck because getting it wrong is something likely to break some major drivetrain components (transfer case, etc.).
Each 4WD solution seems to be different--Audi's, for example, on my RS7P had a near-zero tolerance requiring a square setup where I ran 295s all-around--that was kinda like driving a bobsled on most freeways.
Which GTC are you referring to?
      04-05-2020, 01:20 AM   #180
limeypride
limeypride's Avatar
4425
4,109
Yup, the visual doesn't bother me so much--I can fix that.
Likewise on non-responsive--that happens to me a lot.
      04-05-2020, 11:54 AM   #181
Wolfman64
Wolfman64's Avatar
812
810
You're right. Didn't think about the AWD aspect of its. Even then I don't think it's an issue.
Factory 275/285 staggered setup: Difference in circumference: 1.1%
Your 285/295 staggered setup: Difference in circumference: 0.7%
275/295 staggered setup: Difference in circumference: 1.8%, so 0.7% more than factory.
The other option is to stay with the 285 in front, increase the spacer to 18mm since you mentioned the rub occurs on the inside liner. This pushes the wheel out 3mm which is close to the 5mm increase of tire width on the inside.
Here is the AMG GTC I was referring to
Nevermind. Upload window is going blank when pressing upload. It's in the garage...
      04-05-2020, 12:08 PM   #182
limeypride
limeypride's Avatar
4425
4,109
That's an interesting point now that I understand what you means about increasing the size the spacers. I'll go take another look and see if that would work.
Thanks!
      04-05-2020, 04:11 PM   #183
Ehloo
549
944
Drives: 15 x5 m
So what’s your thoughts about the race chip. Did you end up getting one?
Thanks!
      04-05-2020, 04:15 PM   #184
limeypride
limeypride's Avatar
4425
4,109
Yes, I have them both installed simultaneously and can switch between them at will from my phone.
I needed to eliminate my traction problem to test them properly and, having now done that, I've got a rubbing problem so pulling 1/8th mile launches back-to-back doesn't feel wise so yet again I'm delayed. I'll try and fix the tire problem tomorrow one way or another
      04-07-2020, 04:24 PM   #185
limeypride
limeypride's Avatar
4425
4,109
A few interior pics when dark:
Belugs318.00
      04-07-2020, 05:39 PM   #186
Wolfman64
Wolfman64's Avatar
812
810
Now play some music so that the speakers light up
      04-07-2020, 05:42 PM   #187
limeypride
limeypride's Avatar
4425
4,109
Ooooh, you're soooo right.
      04-08-2020, 12:55 PM   #188
limeypride
limeypride's Avatar
4425
4,109
Just another pic that I rather like:
Appreciate 3
r33_RGSport12971.00
Neptune71432.50
POBA272.00
      04-09-2020, 03:11 PM   #189
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
7,593
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Paint color is sick!
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
limeypride4425.00
      04-09-2020, 09:25 PM   #190
josec70
josec70's Avatar
4074
5,233
Drives: 22' Individual Chalk M5C
Thanks!
Running 275 / 295 with no issues on my M5C , 21" wheel setup w/ no issues.
I think Hockeytime's running same setup.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
limeypride4425.00
      04-09-2020, 09:54 PM   #191
limeypride
limeypride's Avatar
4425
4,109
Thanks!
Thanks.
What's your exact tire front and rear?
      04-09-2020, 09:58 PM   #192
josec70
josec70's Avatar
4074
5,233
Thanks!
Thanks.
275/30 ZR 21
295/30 ZR 21
Mich PS4S
No issues with any rubbing.
limeypride4425.00
r33_RGSport12971.00
      04-09-2020, 11:46 PM   #193
limeypride
limeypride's Avatar
4425
4,109
Thanks!
Thanks.
275/30 ZR 21
295/30 ZR 21
Mich PS4S
Looks AWESOME! Glad to hear that setup works.
What color is that, black, right? // private joke, folks
      04-10-2020, 06:48 AM   #194
josec70
josec70's Avatar
4074
5,233
Thanks!
Thanks.
275/30 ZR 21
295/30 ZR 21
Mich PS4S
TY sir!!! Black, gray. Purple .... u remember the good ole days ..
      04-11-2020, 03:19 PM   #195
Wolfman64
Wolfman64's Avatar
812
810
So did you fix the front wheel rubbing situation? What was the solution, if so?
      04-11-2020, 03:36 PM   #196
limeypride
limeypride's Avatar
4425
4,109
Ordered bigger spacers as suggested. They were scheduled to arrive yesterday but were delayed; arriving Monday.
I'm also looking at going back to 275s front since others with F90s are already running that setup without causing the 4WD system to throw a hissy.
      04-23-2020, 07:19 PM   #197
limeypride
limeypride's Avatar
4425
4,109
Resolved: 11mm rear and 15mm front. 295s rear and 285s front. I just had to wait long enough for the tire to file down the inner wheel arch. Perfect now.
r33_RGSport12971.00
      04-23-2020, 07:20 PM   #198
limeypride
limeypride's Avatar
4425
4,109
Tints done today (lost my patience so Coronavirus-defensed up, I ventured out):
r33_RGSport12971.00
josec704074.00
