09-04-2016, 09:04 AM | #45 |
11817
Rep 23,187
09-04-2016, 09:21 AM | #48 | |
122
Rep 278
09-04-2016, 09:23 AM | #49 | |
122
Rep 278
09-04-2016, 09:29 AM | #51 | |
122
Rep 278
If there's a defect, it'll not be up to me at all times. |
09-04-2016, 09:29 AM | #52 |
538
Rep 624
09-04-2016, 10:01 AM | #53 |
124
Rep 386
Drives: '07 328xic '11.0 M3 DCT
Just in general I learned in my camaro. First car. Dismal motor (anyone who knew the gm 305). Wet, snow, no TC (1989. Not even limited slip). After a couple years I could hold and pull out of almost any slide. It's just time and throttle control.
What are your tires? I would ease the throttle and use this as a chance to learn. Driving is more than mashing the right pedal. There is a lot to learn about controlled slide. You can learn to correct, save, and use oversteer to be a tool in your arsenal. It can help you get through a turn, pull out of understeer, and helps you understand driving dynamics more thoroughly. "Why don't you take every turn like that?!?!?" - the first time I took my brother for a ride completely sideways through a turn. As for Traction control on an ATS-V, no idea. I like my car to let me do what I want with it. Take a look under the car and make sure that everything is secure. If you go half throttle, does the rear move similarly? You should get some suspension shimmy when you go hard on a car like that. You'll feel a bit of torque that is not applied evenly. For example, both my RWD cars like to light the right tire up. They are right heavy. Now both will spin, but the right always gives a harder kick and seems to be the first to let go. When I drive hard, but not spinning, I can still feel an unequal torque to the right side when shifting.
2011.0 E92 M3 M-DCT ZCP ZTP ZPP Black Wrapped Jerez Black + 2007 E92 328xic 6MT 2007 YZF-R6 + 2001 Honda Shadow ACE 1989 RS Camaro - HO 350, Dynomax headers, flowmaster AT exhaust, 4.56 gears 2015 STI Launch Edition |
09-04-2016, 10:52 AM | #54 |
122
Rep 278
They did at the garage and said that everything is OK.
09-04-2016, 11:07 AM | #55 | |
122
Rep 278
Here is a clip from this morning on my way to work. In low speeds I was on a bad slippery road with half throttle and the car was actually slipping. Both my hands on the wheel trying stabilize the car. Only when I got to a better road I could press hard on the throttle. It was also in 80 KPH. |
09-04-2016, 11:47 AM | #56 | |
731
Rep 1,472
If you push to hard, your rear end will try to step out anyway. That last clip looks normal to me, the first one seems a bit excessive given your TC was on. |
09-04-2016, 01:40 PM | #57 |
122
Rep 278
09-04-2016, 03:25 PM | #58 |
dances with roads
4732
Rep 4,096
A buddy let me drive his Mustang back when I was young and impressionable. 1966, 289/271hp, 4spd. Looked ordinary when the hood wasn't open. Up until that time the horsepower I had at my beck and call at any given moment had been in the double digits. Oh and bias ply tires on the 'stang. Anyway, I was pulling away from a traffic light and had to turn a bit to go around someone turning left. When I pressed the gas the car snapped sideways like it was on ice. I was quite happy not to have paid any more for that lesson than a bit of embarassment.
Bbb34730.50 |
09-04-2016, 03:25 PM | #59 |
868
Rep 1,413
Drives: 2020 X3MC
Here is the bottom line...there is NOTHING wrong with your car. You simply don't have the skill level to control a high horsepower rear wheel drive car just yet. You've said it yourself that you need to learn more and that you don't know what you're feeling.
What you're feeling is a shitload of power in car that you're not used to. It's not embarrassing that you don't have the skill level yet but don't go blaming the car and looking for things that are wrong. Look in the mirror, take it easy driving and stop "mashing" the throttle and expecting the computer to save your ass. |
09-04-2016, 03:59 PM | #60 | |
731
Rep 1,472
With electronics"off" both clips show what I'd expect to see as a result of flooring the pedal of 500 HP rear wheel car. In the first clip it seems to me that TC catches it way past the point where BMW's "electronics" would interfere, maybe that's by design. Recently I spend some time behind the wheel of V8, 420+ HP manual Mustang GT, and even though not as "refined" as BMW's electronics I wasn't able to make the rear end move a lot with everything "on". I also drive my RWD all year round (nasty winters, snow covered roads) and with electronics on, and good winter tires it's perfectly fine. |
09-04-2016, 04:07 PM | #61 | |
2893
Rep 3,470
The stability control in my camaro was quite good. I would drive on ice sometimes here in Alaska and it would yank the car back in a straight line pretty well, basically the issue you are having, but without something to yank it back.
Bbb34730.50 |
09-04-2016, 08:31 PM | #62 |
2030
Rep 2,672
You are not providing enough info to get proper detailed feedback. You need to attend a high perf driving school and ask instructor to drive your car. Nobody here can help you remotely. Figure out whether it's a driver or car issue.
09-04-2016, 10:24 PM | #63 |
2893
Rep 3,470
Or take Cadillac up on their FREE PERFORMANCE DRIVING SCHOOL offer
09-05-2016, 12:49 AM | #64 |
122
Rep 278
Let me try and answer all of you.
I think most of us agree that this is something in between my driving skills and the car itself. Bbb34, if you are saying that with electronics on you never feel like you are on ice and I keep on claiming that I never turn off the electronics so something might be bad. I'm not sure as you can't be sure without driving my car first. James, let's please leave aside hard kick downs and relate only to the last clip. Belive me, squeezing the throttle at this point would definitely result in the first clip! I'm saying that again, I felt like I'm in ice. Smooth, I'll try that as well. For now, importer guys had supplied a professional driving instructor to tell me that the car is perfectly fine. This is not what am I looking for. I need someone without interests to tell me that. All the other responders, please read the thread. |
09-05-2016, 08:51 AM | #65 |
868
Rep 1,413
Drives: 2020 X3MC
Heres a thought.....go ask the guys that actually drive these cars. I am sure there is a Cadillac forum and I guarantee you that none of them have these problems. The problem is squarely you and your lack of command for the car.
Nobody here is going to drive your car so when people give you advice you can't tell them they're wrong because they haven't driven your car. Again this is simple....you don't know how to drive this car Wait let me get this straight....someone gave you a professional driving instructor and that professional told you the car was fine and you don't want to listen to him??? Is that what I am hearing because if so you really need to give up and go buy a Prius or something because you have no business driving this car. You are going to kill someone and thats not a joke. Fuck I can't believe this thread is this long |
09-05-2016, 10:24 AM | #66 | |
731
Rep 1,472
This was exactly my initial reaction when the thread stated, I can't lie I just keep going back to all "electronic nannies" being left "on". It's really hard to move the car that much (especially first clip) with everything "on", even on wet or snow covered roads. |
