03-19-2021, 03:19 PM | #1 |
9
Rep 13
*reposting from incorrect thread*
Hi all, just flipped my i8 for a 2019 850i with pretty low miles (~11k), love the tech and performance of this car! Question on wheels/aesthetic. I really like the look of a full wheel well. Not much gap. I see a number of pics posted here with that look. I'm wondering if that is just the model? M8? And/or newer gran coupe? Just kind of feel like my rear wheel looks small for the car. Car is 245/35r20 front, 275/30r20 rear. Seems like this is standard when I look at this year/model on tire rack etc. I received feedback that many are running 35 in the rear. If so what is the full spec? Can I go 275/35r20 rear and not impact car performance or programming etc, odometer? I'm not up on all of the impacts. Full car pic is what I think is ideal, I saw this posted to a different thread by the owner. Thanks!! |
03-20-2021, 11:19 AM | #4 |
9
Rep 13
I'm giving it a shot today. Will post an update. Took it to local bmw dealer. They noted the standard response that on the surface it won't impact warranty but they can't guarantee an inspector/adjuster wouldn't try to blame some issue on it. I guess thats a fight for another day
Resjudicata1607.00 Jim-Bow130.50 |
03-20-2021, 01:45 PM | #5 |
606
Rep 909
With that setup the FRONT wheelwell will be filled out by extra 12 mm. You will also have a slight negative scrub radius (about -4 mm) and there will most likely be a slight variance in the speedometer readings.
As for the REAR, the same appllies for speedometer readings, whereas the wheelwell will be filled out by extra 14 mm and the negative scrub radius will be about -5 mm. I would always follow the last word of a professional tire shop in terms of being recommended or not. Look forward to pictures once it's all said and done. |
cd338.50 Resjudicata1607.00 |
03-20-2021, 04:31 PM | #6 | |
9
Rep 13
03-20-2021, 04:48 PM | #7 |
119
Rep 163
For those who desire their wheel wells to appear "filled" it is common practice to use wheel spacers. Lowering the car using lowering springs also improves the appearance. I would personally go this route rather than experimenting with tire sizes other than oem.
2020 BMW M8 Competition Coupe
2021 Nissan GTR Premium 2020 Audi R8 V10 Performance (sold) |
cd338.50 |
03-20-2021, 05:21 PM | #8 |
606
Rep 909
I don't know the formulas for calculating the variance. Your professional tire shop should at least know the new adjusted PSI level to consider when inflating them. "Generally" speaking tires with taller sidewalls (higher aspect ratio) require lower pressure than those with shorter sidewalls. However you may read contrasting views on this as other variables come into play and for that reason especially I would always ask my tire shop who mounts the wheels and should know.
cd338.50 |
03-20-2021, 07:01 PM | #9 | ||
1607
Rep 2,937
I forget what stock is or the tire recommended but keep it well under 50 psi. |
03-20-2021, 08:02 PM | #10 | |||
9
Rep 13
https://tiresize.com/pressure-calculator/ Here's a few pics I tried to compare before and after. And a few full body after shots. I think it's noticeable and looks better. My wife rolled her eyes at me ha! |
BigMofoFrog187.50 Van_bimmer113.00 |
03-20-2021, 09:06 PM | #11 |
452
Rep 859
looks much better, should've came like that factory setup
03-20-2021, 11:08 PM | #12 | ||||
1607
Rep 2,937
I think the convertible says 32 front 38 rear; but I'll check it again. In any event, if the calculations say 34&33; then I would keep it there, or do a max of 36/35. No more than 2-3 psi cold because they heat up quick and easily can have 5-10 psi on the track or a hot day. |
cd338.50 |
03-21-2021, 06:15 AM | #13 | |
606
Rep 909
Here you can get a good schema too for the M850i: https://tirepressure.com/bmw-m850i-x...20and%20safety. |
03-21-2021, 12:23 PM | #14 | |
5346
Rep 1,846
Resjudicata1607.00 cd338.50 |
06-06-2023, 07:01 AM | #15 |
12
Rep 3
Drives: Bmw M850i
Hello , can you tell me please if you have some problems or some error after this time ? Thanks
