05-23-2024, 10:34 AM | #1 |
Rep 7
New tires, tires pulsating- whobing at low speed
Hi folks
I know there are some threats like this. But here me out I drove my car with Continental at the front, and pirellis at the rear. No problem. Then I bought new tires for the rear and kept Continental at the front. Because of the potholes, I had around nine or 10 flat tires at the font. So the font tires are newer, and didn’t need new tires But as soon as I put the new tires at the back, I have the same pulsating, whobing, sensation at the back. It happens at low speed, when i give gas, when there is torque. When there is no acceleration, or when it’s just cruising then its fine It’s obviously the tires but why woild it be ok with Pirellis at the back- continentals at thr front But not ok with goodyears at the back and continentals at the front? Or is it something else ? |
05-23-2024, 12:04 PM | #4 |
75
Rep 33
Stiffer sidesways on one tire vs. the other? Bent rim and one time is more sensitive than the other? I presume same tire pressures, but maybe play with tire pressure to see if that helps?
____________
2024 BMW M8 Gran Coupe Competition Black Sapphire Metallic 2018 Porsche 911.2 Turbo Guards Red |
05-23-2024, 12:09 PM | #5 |
Rep 7
Long time ago, I had a little crack, on a rim i got it it fixed and rotated the tires on same axles. And the problem went away. But this time the rimms are OK and there are no cracks…. So its’s not that either
05-23-2024, 11:36 PM | #6 |
1782
Rep 1,319
Drives: 2022 M8cc
Can you post the tire sizes please. Or percent difference in diameter
05-24-2024, 05:38 AM | #7 |
Rep 7
05-25-2024, 12:43 AM | #8 | |
6178
Rep 2,026
OEM Rear Dia: 26.50" Here's some good sites for tires https://www.willtheyfit.com/ https://www.discounttire.com/learn/tire-size-calculator |
mimarsinan310.00 Dr Thrillride1782.00 |
