08-23-2023, 02:03 AM | #4 |
2811
Rep 5,127
Yeh tpms is as described above. TPWS ( tyre pressure warning system) is the lesser system that uses the abs sensors to detect a wheel running at a different speed and hence not at the right pressure or deflated.
08-23-2023, 10:57 PM | #5 |
1191
Rep 845
Audis measure by rotation. I hate those systems.
Accentu8705.00 |
08-24-2023, 02:59 AM | #6 |
4492
Rep 7,535
It depends…since the OP is from Canada…the TPMS system (option 2VB) is not required…they can have the FTM system in Canada. Post a pic of your Vehicle Status screen that shows which tire monitoring system you have.
If it says something like TPM/RDC at the bottom of the screen…then you have the TPMS system which has sensors in each wheel. If you pull up the tire monitor screen in iDrive and it says something like FTM/RPA…then you have the flat tire system which uses tire rotation to determine if a tire has low pressure. TPM/RDC = SENSORS FTM/RPA= NO SENSORS
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-24-2023 at 03:09 AM.. |
KillerBlackRhino538.50 |
08-24-2023, 01:08 PM | #7 | |
268
Rep 846
Tw questions since we are talking tire pressure. I noticed the BMW app as well as the iDrive gives tire pressure recommendations for front and rear which are higher than what's on the driver side door. The label on the car for M850 states 42 PSI front / 44 PSI rear. What tire pressure should one have? The second question, what is the reason for the M850 to have a lower tire profile than the M8C? I noticed all M8C are 35s front/back vs 30s for the M850. Thanks
08-24-2023, 04:29 PM | #8 |
4492
Rep 7,535
The tire pressure chart on the door jamb is for COLD tire pressure reading (tires have not been warmed up by driving/rotating/etc). The iDrive chart takes into account that the tires have been rotating...thus heating up and adjust the suggested PSI accordingly.
08-24-2023, 07:29 PM | #9 | |
4300
Rep 4,365
Before going on a performance drive in which I'll hit over 100MPH I'll always check to ensure the tires have properly heated up and at the iD7 recommended pressure before doing so. Yep, going to have to get the compressor out tomorrow for some inflammation on the front and rear left tires while cold.👍 |
08-24-2023, 08:56 PM | #10 |
268
Rep 846
I do understand how they tire pressure changes between cold and warm. My question is why the iDrive at times recommends higher value even when the tires are warmed up? As an example, the door jamb specifies 42 front/44 back when tires are cold. Once you start driving and the tires warm up the front might go up to 43 or 44 and the rear for 45 or 46, iDrive would recommend higher numbers than the actual temperature which doesn't make sense! I will take a picture to show you what's happening.
08-25-2023, 06:32 AM | #11 |
2811
Rep 5,127
Ambient temperatures . So even if the tyres are “cold” ie the car has been sitting still for a reasonable length of time, the ambient temps will have a bearing on matters
So if the weather suddenly gets cold, you may see the pressures in your tyres being a little lower than previously and need increasing a bit I have a shortcut button that points to tyre pressures so I can keep an eye on it every journey and should the weather change significantly I know that I’ll probably have to make an adjustment to the pressures. |
08-25-2023, 07:25 PM | #12 | |
1159
Rep 1,364
BMW voice recognition doesn't seem to have a command to directly show tire pressure. The best I could do was get to tire settings where it asked if I wanted to see tire pressure and temperatures and I would have to reply "yes". Rob |
08-25-2023, 08:13 PM | #13 | |
268
Rep 846
Sure it does, ask BMW for tire pressure, it will bring the screen up with the info. That's how I check it every time.
08-26-2023, 06:30 AM | #14 | |
1159
Rep 1,364
Rob |
