07-20-2023, 08:51 PM | #1 |
Rep 17
assisted driving hands free time reduced
Not sure if this is the right forum to post this, but I’ve noticed that when I turn on assisted driving, the hands free time has reduced greatly. Now the yellow steering wheel indicator turns on every 5 seconds which is kind of ridiculous. I was driving locally at 30-40 mph. Anyone else ever experienced similar issues?
07-21-2023, 03:51 AM | #3 |
2783
Rep 5,095
What’s changed then? It behaviour shouldn’t change if all things remain the same
As mentioned earlier if camera blocked that will reduce time. You should hear faint audible blip if you are looking away aswell Are you on different roads? Where are you based as I believe there are differences in markets. The use gets assisted driving plus mode which we don’t get in the U.K. (Regulations presumably) If you are on a motorway/freeway that seems to in general allow a longer time as it presumably detects both car in front and lane markings |
07-22-2023, 06:43 PM | #4 |
4269
Rep 4,335
First and foremost as always the question in play is what iD7 release is on the car? Granted BMW is not the greatest with release notes but up through 02/2023 the only change called out for full driving assistance is a reduction aka smoother lane change when in full assist.
I just did a 1.5 hour (one way) road trip for the 4th of July week holiday and when on boring stretches was in full drivers assistance. Hands off the wheel was much greater than 5 seconds before the yellow indicator would light up. In general I appreciate the function but always keep my hands on the wheel albeit one, i.e., my left hand as I'm left handed and it doesn't take too much pressure for it to recognize it. However, as I got a bit lazy obviously the pressure lightened and then I'd get the nag. I'm guessing at least 10 seconds if not greater but obviously not an empirical value. When it comes to the function in which the car prompts literally 100% assistance plus (based on the road, generally stop and go traffic and absolutely under 40MPH) it primarily depends on the LIDAR camera in the cockpit to ensure eyes on the road as you can completely take your hands off the wheel. I've only had this kick in twice when stuck in stop/go traffic on a main freeway here in Phoenix. It worked like a champ as although I had my hands off the wheel my foot was near the brake at all times just in case even though I've never had a single issue with the ACC on the car as it keeps the distance set for car lengths, speed, etc. to the point it will stop and restart movement as needed even when not in full assistance but ACC only. |
magicvii4.50 |
07-23-2023, 11:15 AM | #5 |
57
Rep 21
Drives: 2022 BMW M8 Competition
dumb question, but I am a newbie. Does driver assist mean hands free driving? If so, how do I set it.
07-23-2023, 02:58 PM | #6 |
163
Rep 184
07-23-2023, 04:31 PM | #7 |
57
Rep 21
07-23-2023, 07:44 PM | #8 |
4269
Rep 4,335
The car has to have Driving Assistance Pro in order to activate it. If your car has it the lower left buttons on the steering wheel engages it. Not sure if the models with only Driving Assistance have cruise control but if so it's old school vs AAC.
rdown197656.50 |
07-23-2023, 07:47 PM | #9 |
4269
Rep 4,335
Active Cruise Control which uses a camera in the front of the car to judge distance between it and any car in front. So for example if you put the ACC at 80MPH but approach a car in front within the same lane it will automatically lower the speed to whatever that car is doing, e.g., 75MPH. Plus you get to set how many car lengths of distance you want between you and the car in front.
rdown197656.50 |
07-23-2023, 09:39 PM | #10 | |
Rep 17
07-24-2023, 07:46 AM | #11 |
1399
Rep 1,070
Drives: 2022 M8cs
07-24-2023, 08:09 AM | #12 |
50
Rep 32
07-24-2023, 02:53 PM | #13 | |
907
Rep 1,154
07-24-2023, 09:12 PM | #14 | |
4269
Rep 4,335
Either way depending on the version I'll test out the full driving assistance mode and let you know what hands off the wheel time is with it in place. The paint may have messed up the ACC camera or they didn't pull the bumper before painting or didn't realign the cameras after re-installing. I say the that as I have a ding in my front bumper I've been living with as it's not really noticeable but did get an estimate from Penske collision after it happened. The bumpers are plastic and with the minimal damage they said they'd just remove the PPF and fill in what was necessary, shape it to match the factory spec (it's a bit of a gouge) and paint blend to match. Key though as they included labor for dropping the bumper and realigning all cameras if needed. The estimator said the latter may or may not be needed, i.e., the camera alignment after the bumper is reinstalled but included it just for full transparency on the potential total cost which I appreciated. |
08-16-2023, 10:29 AM | #15 | |
4269
Rep 4,335
Further testing using the stopwatch app on my cell phone it is indeed 5 seconds now vs the original 10. However, it feels like the red warning is the same amount of time and kicks in at 20 seconds (confirmed with the stopwatch app). So the update reduced the time before the yellow alert starts but left the amount of time it will run before the red alert kicks in. I'm guessing this was a "safety" enhancement. No changes to lane detection, ACC performance or oddball following the car in front out of the lane if it does so as per your experience. Hopefully your dealer helped resolve that and likely ties back to the bumper/grill work impacting the camera or sensors. |
magicvii4.50 |
08-16-2023, 10:32 AM | #16 |
4123
Rep 273
I've also noticed that the Driving Assistance Plus time has been greatly reduced (completely automated driving in slow moving traffic). No matter how intently I stare straight ahead and don't move my head from side to side, the system displays the "Stay Alert!" message after only a few minutes and forces my hands back on the wheel.
Annoying, as this defeats the purpose of the system. Last edited by BMWGUYinCO; 08-16-2023 at 12:00 PM.. |
08-16-2023, 07:37 PM | #17 | |
4269
Rep 4,335
08-16-2023, 09:27 PM | #18 |
Rep 6
08-16-2023, 09:31 PM | #19 | |
4123
Rep 273
08-17-2023, 07:12 PM | #20 | |
4269
Rep 4,335
Heading back after dropping her off there was an accident so I was in stop/go traffic for 20 minutes and about 10 miles. Plus engaged and worked flawlessly. I had set the ACC to 75 before hitting the blockage so once stop/go under 40 got the plus prompt and engaged. Stayed engaged the whole time until a little break in which the car hit 41 and then instantaneous red wheel alert and hands on the wheel. Stop/go again and plus engaged the rest of the way until passed the accident and traffic moved. Immediately at 41mph (I was monitoring) and red wheel alert, plus disengaged and left hand 2 fingers back on the wheel. I guess my only question would be why red vs yellow? Guessing to get one's attention plus is disengaged and time for hands on the wheel again. |
08-17-2023, 08:35 PM | #21 | |
1156
Rep 1,363
Rob |
08-17-2023, 10:26 PM | #22 | |
4269
Rep 4,335
