BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion BMW M8 Launch Control "Chassis Stabilization Error"
      05-23-2021, 09:00 PM   #1
onebigv8
13
17
Drives: M8
With my Current BMW M8 2020 non Competition, Literally anytime I need to go into Launch Control I get into this Chassis Stabilization Error
My Settings are Sport+ Engine response, Traction Control off and Shift to first gear.
I've always driven my car for at least 15 miles before I try to Launch it.
It's literally a hit and miss... 80% of the time I get this error, the Car Does Launch eventually but with Reduced Power. Now Today this got on my nerve a Bit because I tried to Race few of my friends on the road and I always ended up with this error, so I tested by changing the Engine from Sport+ to Efficient and I noticed that this Error is almost gone in that mode....
One more thing I've always noticed is that when in launch control mode... The rear Tires Start to spin as if I'm smoking my tires.. not sure if this is related or not.
I'm not holding the throttle for too long ( 1.5 Seconds ) so I know this is not the reason... I hit the break, I hit the throttle and instantly this error is in my face...
let me know if any one has experience this before
      05-24-2021, 07:53 AM   #2
unfoundnemo
unfoundnemo's Avatar
1909
2,007
Drives: 2022 i4 M50
2022 BMW i4 M50  [0.00]
2022 BMW X7  [0.00]
No experience here with my F92, but I had the issue with my F80 the first time I made a right turn at slow speeds after startup. It just ended up being a stabilization sensor that needed to be replaced. There's a few things it could be, including the battery the sensors are drawing from, but it should be storing the codes so you likely don't need to recreate it for the dealer.
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC
      05-25-2021, 12:05 PM   #3
Resjudicata
Resjudicata's Avatar
1603
2,937
Drives: M850i convertible
It's possible you're over the limit for the new launch counter. There is a whole thread on the counter on the m5 forums.
      05-25-2021, 12:29 PM   #4
BMWGUYinCO
BMWGUYinCO's Avatar
4123
273
Drives: 22 M850 Convertible '23 X3 M40
I'm not sure if launch control is the exact same it was in the M550 as it is in an M8, but I don't believe you should have traction control set completely to off (the long press and hold of the traction control button).
Unless you mean you do the short press to turn off Stability Control and have the car in Dynamic Traction or whatever that mode is....
      05-25-2021, 03:41 PM   #5
onebigv8
13
17
Drives: M8
Do you have the Link to that Thread?
      05-25-2021, 08:29 PM   #6
Resjudicata
1603
2,937
Blank
I can get it for you, yes. Give me a minute.
I believe it is this one. If not, let me know. If so, let me know either way.
Limit on LC? https://f90.bimmerpost.com/forums/sh....php?t=1798332
Limits.
      05-25-2021, 08:59 PM   #7
onebigv8
13
17
Drives: M8
Limits.
Thanks a lot...mine might be a bit different of an issue... Today I've literally done 3 launches while engine =comfort mode= no issues
sounds like SPORT+is the issue.
      05-25-2021, 09:49 PM   #8
Resjudicata
1603
2,937
Limits.
Gotcha
      05-28-2021, 09:53 PM   #9
bloozemanAZ
bloozemanAZ's Avatar
4269
4,335
Limits.
Wow that thread is indeed an interesting read with limeypride being the sane voice of reason throughout it. I'm guessing I have 25 or less LCs with the M850i as I don't do them unless I'm on my desert drive in which I have zero concerns on the outcome vs doing them on the street.
It sounds like (based on the latest posts) that with a stage 3 TCU tune one can overcome the limit "somewhat" as ultimately the limit is on the transmission component vs anything else (if I understand the thread correctly). So that will only apply to pre-June 2020 builds as from my understanding at that point everything is locked.
limeypride4425.00
      05-28-2021, 11:23 PM   #10
limeypride
limeypride's Avatar
4425
4,109
Limits.
I've not seen anyone actually overcome this limiter—tune or otherwise. The nuance is that the car still displays and exhibits most LC characteristics such that most drivers won't notice… except one characteristic. And that "one" is the pivotal reason these cars can attain sub 3s to 60mph—without it, they simply cannot. The ZF's quick shift mode that enables this jaw-dropping launch (2.57s without the bullshit 1ft rollout on my last M5 <sub 2.4s with it> and 2.59s on my behemoth of an M8 GC) is gone—it shifts quickly but nothing like what is required for these numbers.
      06-09-2023, 12:18 AM   #11
alan1213
Drives: 2020 Bmw m8
2020 Bmw m8 owner
my M8 is giving me the same stabilization error message on my 2020 m8, anyone have this same problem and how did u fix the problem?
      09-03-2023, 11:41 AM   #12
F93rod
Drives: Bmw m8 comp
Help
Anyone figure this out yet?
      09-03-2023, 10:58 PM   #13
onebigv8
13
17
Drives: M8
Just launch in Sport instead of Sport+...
