10-19-2021, 03:31 PM | #2 | |
4540
Rep 3,507
To be sure its not serious keep eye on temp gauge if it goes high that is bad pull off tow it. Also you can pop hood look at the reservoir's there are two.
Resjudicata1603.00 |
10-19-2021, 05:32 PM | #3 | ||
Rep 2,937
Basically I didn't say, but I'm kinda asking can it wait 6 months assuming it's not overheating or do I need to go in now. We aren't driving much this year with things, and we were just in a wreck with other vehicles so I'd like to be able to walk and have 1 car out of the shop before the next one goes in. I think we're on the same page. See if it pops up again;and or if it overheating. |
10-19-2021, 06:17 PM | #4 | |
4540
Rep 3,507
The only concern here is enough is gone to trigger the sensor meaning it is yelling before anything bad happens, at that point I would rather swing by spend 30 mins or so getting it looked at.
10-19-2021, 06:28 PM | #5 |
250
Rep 268
Had this a couple weeks after I got my cpo. I bought a bottle of bmw coolant and cut it with water 50/50 in a plastic water bottle. It took the whole 16.9oz bottle before it got back to the recommended fill line. No issue since.
Tenac4539.50 Resjudicata1603.00 |
10-19-2021, 08:04 PM | #6 |
641
Rep 628
Drives: 2019 BMW m850i Coupe
I've had this issue too. These are the correct procedures. There are two coolant tanks that needed to be topped up.
Resjudicata1603.00 unfoundnemo1909.00 |
10-20-2021, 08:26 AM | #7 |
Rep 2,937
it showed again today. so now the million dollar question, do I remove the Racechip and pretend it's not there. or leave the Racechip and roll the dice ??
how bad could it get? |
10-20-2021, 09:39 AM | #8 |
1023
Rep 410
i had the coolant warning this summer. i topped it off, and a week later got prompted again. those tanks get burning hot and can crack. turned out to be a leak. take out the race chip, they will blame the overheating on it.
10-20-2021, 11:12 AM | #9 | |
1909
Rep 2,007
Drives: 2022 i4 M50
I had this pop up on a Saturday morning as I was about to drive 100 miles to a 50 mile cruise a couple months ago, so I wasn't feeling too great about letting it go and I didn't have any coolant on hand. Luckily it was 8AM and my SA gets in early, he just had me stop by right then and came out to the driveway with coolant in hand to do it himself, he didn't even check me in. FWIW, he said it happens pretty often with the V8s. There's not a lot of air circulation in the engine compartment, and it's pretty sensitive. Mine only took a few ounces of coolant to be happy again.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC Last edited by unfoundnemo; 10-20-2021 at 11:23 AM.. |
10-20-2021, 12:11 PM | #10 |
Rep 2,937
10-20-2021, 12:12 PM | #11 | ||
Rep 2,937
10-20-2021, 09:34 PM | #12 |
2018 M3CS Pittsburgh
600
Rep 758
Drives: 2016 528 , 2018 M3CS 2020 M8
Just happened to my M8..made them do a pressure test found a leak in the overflow hose..have to order it from Germany should be here next week
10-20-2021, 09:55 PM | #13 |
Rep 2,937
yikes. we are down to 1 car, and if this goes into the shop for a week, we will be in trouble. we live in a rural area where nothing is around for 5+ miles.
10-21-2021, 12:19 AM | #14 |
1195
Rep 2,908
Way easier to just get a bottle of coolant and distilled water and do yourself. Takes 2 minutes. If the warning comes back quickly, you have a leak.
10-21-2021, 02:10 PM | #15 | |
600
Rep 758
Back up..200miles not showing low yet..but the pressure test showed the leak. I recommend you have it done under warranty..then if something does happen They have a record |
10-21-2021, 02:57 PM | #16 | |
1840
Rep 1,487
He added non-BMW coolant and the dealer found out and charged him for the flush and other items, basically trying to void the warranty. Tread carefully!
Blessed Beyond Measure
10-21-2021, 03:40 PM | #17 |
Rep 4,335
Yep when I got the alert the main tank was low but thankfully the turbo charger tank was still up to spec.
10-21-2021, 03:46 PM | #18 |
Rep 2,937
guess I'm going to the dealership
10-21-2021, 03:52 PM | #19 | |
Rep 4,335
10-21-2021, 03:54 PM | #20 | |
Rep 4,335
https://f92.bimmerpost.com/forums/sh....php?t=1771900 |
10-22-2021, 09:50 AM | #21 |
1195
Rep 2,908
Well, I meant he should get a bottle of BMW coolant.
10-23-2021, 09:26 PM | #22 |
Rep 2,937
dealership checked it, pressure test and topped it off for free / included in warranty.
it only needed a few drops of coolant according to the tech. apparently it happened from the hot and cold temperatures here lately, fluctuations caused a slight drop and trigger the sensor. |
